Broken rear window
Discussion in '2.5 Gen Tundras (2014-2021)' started by acb0000, May 19, 2019.
  1. May 19, 2019 at 5:10 PM
    acb0000
    acb0000 [OP] New Member
    2019 4x4 crewmax 5.7
    hi there, new to the site. Just purchased a 2019 crew max 4x4 5.7. Oldest son just put a bungie strap through the rear window. It’s the full slide down window, not sure if there is another type... but looking to see how much this is going to cost. Safe Life can’t fix it and the dealers are closed. I’ll call in the morning, but trying to prepare myself for what it’s going to cost. Thanks.
  2. May 19, 2019 at 5:21 PM
    womprat57
    womprat57 BABE the Big Blue Ox
    NH
    2014 SR5 DC 4x4
    Guessing half a grand?
  3. May 19, 2019 at 5:31 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Looks like it is $370 for the OEM glass plus labor. Ima guess bumpin $600.
  4. May 19, 2019 at 5:34 PM
    Blueknights75
    Ron
    Clayton, NC
    A member here just replaced his and did it himself....hopefully he will see this thread and chime in. If I recall he ordered the glass from Toyota and said it wasn’t hard at all to replace...
    TheBeast likes this.
  5. May 19, 2019 at 5:50 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
  6. May 19, 2019 at 5:53 PM
    TheBeast The Beach
    yep..rear is DIY. order oem Toyota then get to work...or your son :)
  7. May 19, 2019 at 5:58 PM
    dochanson
    dochanson New Member
    Gabe
    I just did this. I ordered the glass from "Pro Auto Glass" on ebay. It was $160. Very easy straight forward install.
    Roll rear window down about 3/4, remove back seat, take access panel off (about 14 10mm bolts), window is held in with 4 10mm bolts. Disconnect rear defrost mechanism, clean out old glass.
    Insert new glass in at an angle (30-45 degrees) gently lower into place. Have helper (oldest son would be good:)) put the four bolts to attach to track...reassemble.
    Total time for me was under an hour.
    1UPPER, Trooper2, Migraine and 3 others like this.
  8. May 19, 2019 at 5:59 PM
    dochanson
    Gabe
  9. May 19, 2019 at 7:39 PM
    acb0000
    Thanks for all the great replies! I’ll look into ordering the glass tomorrow for a DIY. We will see how it goes.
  10. May 19, 2019 at 7:51 PM
    YeeYeeTundra
    YeeYeeTundra Earl Dibbles III incarnate
    Ohio
    2018 Quicksand CrewMax Limited TRD
    Extang tri-fold tonneau cover, havoc hs2 steps, A1 tow mirrors, TRD RSB, weathertech mats, 24' Puma BH travel trailer, Yeti 75, LineX
    Don't forget to locate your 10mm wrenches/sockets before you're holding a big piece of glass... Good luck! Let us know how it goes.
    Migraine likes this.
  11. May 19, 2019 at 11:53 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    The most important part!
  12. May 20, 2019 at 5:47 PM
    acb0000
    Well got glass from a local place, $250 and installed ourself. Not hard at all, getting all the glass picked up with the shop-vac took the most time. Thanks to everyone for the advice. Oh, dealer quoted me at $359 for the install and $540 for the window....
  13. May 23, 2019 at 6:10 PM
    acb0000
    Hi again all, wondering if someone knows where to find the torque values for the rear seat bolts, labeled with an “11” I think. And also the 4 bolts for bolting the window to the rails. I don’t really want to go back in there, but yesterday when rolling up the window it sounded like it was grinding on something, maybe just loose glass. Can’t recreate it, but figured if it happens again I’ll go back in and make sure one didn’t come loose. Also want to check the seat bolts for safety... I guess. Safety 3rd.
  14. May 24, 2019 at 3:22 PM
    womprat57
    NH
    2014 SR5 DC 4x4
    I love it! Snug em dont gorilla em! Some blue Loctite too. DIY is awesome and you learn something new! Dealers are smoking crack these days, mine wanted a grand for brakes, Under $200 and did them myself, smooth as glass. Get it! HAHAHA just remember glass doent like to flex, it goes BOOM sooner than you might think it will.
