Broken piston
Discussion in '2.5 Gen Tundras (2014-2021)' started by Kenz, Feb 4, 2025.
  1. Feb 5, 2025 at 10:47 AM
  2. Feb 5, 2025 at 11:25 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Saltyhero13 likes this.
  3. Feb 5, 2025 at 7:07 PM
    CasperTheFriendlyTundra
    CasperTheFriendlyTundra New Member
    You might want to tell XAT Racing that lol: Screenshot_20250205_220041_Chrome.jpg
    To my knowledge, there is nothing special about the block, or any other part of the 5.7. It can be machined like any other engine.
  4. Feb 5, 2025 at 7:29 PM
    centex
    centex New Member
    Makes zero sense. These blocks aren’t adamantium. And clearly companies are reusing blocks for new builds.
  5. Feb 5, 2025 at 7:39 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The liners are very thin. You can get away with maybe 0.005” hone. But that’s it. Anything more than that and you no longer have a liner and you’re just using aluminum. You also can’t really deck the blocks because of the way the liners basically floating in the aluminum casting. You can resurface heads you just have to run thicker head gaskets. But unfortunately, you can’t do much for the block
    That being said, I’m sure they can probably be sleeved, but I don’t know if anybody that’s tried it
  6. Feb 5, 2025 at 7:43 PM
    empty_lord
    05 rollover special
    https://www.lextreme.com/forums/threads/3urfe-engine-exposed.9701/
    old post from 2008 when it first came out, but it appears somebody has measured how thick the line is and confirms. It is very thin on the 5.7 like most modern aluminum block engines. What XAT is doing is probably running darton sleeves on everything which involves cutting the entire cylinder out of the block
    blanchard7684 likes this.
  7. Feb 5, 2025 at 7:54 PM
    I think the design has cylinders that are independent of the block, like inserts.
  8. Feb 5, 2025 at 11:49 PM
    empty_lord
    05 rollover special
    The deck is open, but the cylinders are connected to the block at the base. The liners are present as the aluminum is poured into the cast. The liners are spiny on the backside and the aluminum forms around them. Including over the top. Heads off you can see the iron to aluminum seam in the block. The AR series and GR series engines I play with are the same setup
    the darton sleeves replace these completely. To do the darton sleeves a machine has to cut out all of the cylinder and bore the lower half of the block to accept the sleeve which is fitted with multiple o rings
    standard sleeving might be possible? But I’ve never seen or heard of it done in these. you’d lose a fair bit of rigidity in the open deck design by removing the original liner to add a traditional friction fit liner
    Rdrcr and KNABORES[QUOTED] like this.
  9. Feb 6, 2025 at 1:37 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Oh man, didn't try to hijack OPs thread, just throwing out another option vs a junkyard motor that may or may not have other issues as a result of whatever put the vehicle in a salvage yard to begin with. They're gond motors and despite there being a lot of inventory, they are not cheap, and it would suck to go through a swap only to them fight unknown issues.
    Getting a used block with warranty is probably best. The XAT is a performance focused rebuild, but it's a rebuild none the less, and is why I shared it.
    Sorry OP!!!
    empty_lord likes this.
  10. Feb 17, 2025 at 6:38 PM
    threetime
    threetime New Member
    09 Tundra 5.7
    If piston not moving, broken connecting rod. I would sale truck as it's a unicorn!
