Broken Lower ball joint
Discussion in 'Suspension' started by Jackson, Jul 18, 2018.
  1. Jul 18, 2018 at 5:13 PM
    Jackson
    Jackson [OP] New Member
    Theron
    WY
    2001 Black Tundra SR5 AC
    Do wheel spacers put a lot of stress on your ball joints!!?? Luckily, I was only backing in to a parking spot, but I just got off the HWY doing 65. :annoyed:
    831Tun likes this.
  2. Jul 18, 2018 at 5:49 PM
    Professional Hand Model
    Hand Protectors
    Bummer man. Glad nobody was hurt. Let us know how your repair goes.
    Tundra2 and Jackson[OP] like this.
  3. Jul 18, 2018 at 5:54 PM
    Jackson
    Theron
    WY
    Thank you. Yes, this could have easily been disastrous and it makes me literally nauseous just thinking what I could have caused to others.
    Tundra2 likes this.
  4. Jul 18, 2018 at 5:56 PM
    Hand Protectors
    Did you do the factory recall on the ball joints way back in 2005?
  5. Jul 18, 2018 at 7:06 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I don't think this is a very common failure. How many miles on those BJs? Did you have any warning? I would think there would've been some indication in the steering or a noise at least before it got to the failure point?
    joonbug likes this.
  6. Jul 18, 2018 at 7:42 PM
    Jackson
    Theron
    WY
    No, I just bought it back in March of this year. Found it sitting in the weeds and I don't know too much about it. I still need to replace the timing belt as well. No sticker under the hood and I am at 190k. Great little pickup. But, this has really, really bothered me and I guarantee you that I am getting everything replaced on the suspension because of what I could have caused today had it happened at a high rate of speed! However, I will check on the recall and see if my truck is under it. I did see that the recall was for '02s thru like '04s. I also saw that this must be a common problem because I read my same situation over and over today on CarComplaints' website.
  7. Jul 18, 2018 at 7:50 PM
    Jackson
    Theron
    WY
    I did pull over today because something didn't feel right. I wiggled the wheels back and forth and couldn't figure out what it was. Now I know. I went to CarComplaints' website and read where many people had the same thing happen to them with the 01's.
    831Tun[QUOTED] likes this.
  8. Jul 18, 2018 at 7:53 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Guess I've just never heard of it. 190k sounds like a good time replace the ball joints. I wonder if the owners manual states a time frame for replacing 'em?
    joonbug likes this.
  9. Jul 18, 2018 at 8:21 PM
    Jackson
    Theron
    WY
    I bet it does. And, I wish I would have changed them out once I bought it. My front-end wouldn't be sitting on the ground on top of a mountain, 6 hours away from home and tools.
  10. Jul 18, 2018 at 8:36 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Oh man! That just sucks! Best of luck with this predicament.
    Jackson[QUOTED][OP] likes this.
  11. Jul 19, 2018 at 4:47 AM
    Hand Protectors
    Sounds like time for:
    New front upper and lower ball joints
    New CV axles
    New lower control arms
    New shocks
    New timing belt/water pump
    Your insurance should cover towing to a local service shop. Rental too.
    Tundra2 likes this.
