Broken antenna / threads on antenna assembly gone
Discussion in '2.5 Gen Tundras (2014-2021)' started by reefcomber, Jan 13, 2022.
  1. Jan 13, 2022 at 4:14 AM
    reefcomber
    reefcomber [OP] New Member
    New England
    2018 Platinum
    Hi, antenna broke off at car wash. Retained piece of bolt on antenna assembly. Tried to get it out with left handed drill bit, but ended up filing down the threads in the assembly.
    I see that a new assembly can be purchased for $180 and some change, but first wanted to find out if anyone knows if just the part that the antenna screws into can be replaced or if in fact, the entire assembly would need to be changed out.
  2. Jan 13, 2022 at 4:23 AM
    Sparks has it for $135 but it looks like it is one piece. Look on YouTube to see if you can find the removal. I have heard that it is a royal pain.
    https://www.sparksparts.com/v-2018-...um--5-7l-v8-gas/electrical--antenna-and-radio
  3. Jan 13, 2022 at 7:01 PM
    handyman
    handyman New Member
    2016 Crewmax Limited in Sunset Bronze Mica
    BFG All-Terrain TA KO2 Tires, Pillar Grab Handle, Curt Front Hitch & Winch Mount, Smittybilt XRC-8 Winch, Escort Solo S3 Radar Detector, Tekonsha P3 Brake Controller, Galaxy DX 2547 CB Radio, Center Console Organizer & Tray, ESP Rear Seat Storage, SumoSprings, Pop & Lock Tailgate Lock, AMP Bed Step, AMP Side Steps, BacFlip G2 Tonneau Cover, and more pending.
    It's a one-piece assembly - coax, mount, and plug. A friend replaced his and said it was a real pain to do. Good luck.
  4. Jan 13, 2022 at 7:42 PM
    KK6PD
    KK6PD 2 1 yr. retired . . . after 42 yrs
    ROAD
    Upper Los Angeles Foothills
    2003 AC Tundra . . . . 7th owner
    New Tires, Stereo & Speakers,Uni-Strut Tie Down Continue watching THIS SPACE FOR FUTURE DEVELOPMENTS
    Isn't the car-wash somewhat responsible? I would think they should be letting their insurance take care of this.
    I would bet if you let Toyota take care of this, what 5, 6 hundred bucks? Good Luck, let us know how this comes out!
  5. Jan 13, 2022 at 7:54 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    If you have replace the whole thing including coax I would just splice the coax cable. Not hard to do.
  6. May 21, 2022 at 8:29 AM
    brigand80
    brigand80 New Member
    Roman
    2017 Limited CM MGM 2WD
    Its Always A Work In Progress...Because Its A Labor of Love!! - aFe Pro Dry Filter + TRD Intake Flow Accelerator + Carbon Filter Delete - nFab Podium Steps - TRD Rear Sway Bar - TRD Pro Grill - Color Matched Hood Bulge, Front Bumper End Caps, Mirror Caps, Door Handles - Nightshade "Limited' Badges & Others De-badged - NSV LED Lightbar - Desert Eagle Offroad Catalytic Skid Plate - Craven Speed Untenna - Diaz Fabrication TEQ Trailer Hitch Cover - Klearz 3rd Brake Light Smoked Lens - Winjet Renegades Smoked Tail Lights - Headlight Revolution GTR Lighting LED Bulbs - Morimoto 4 Banger HXB LED Fog Lights (White) - XD 847 Outbreak 18x9 +12 5x150 - Gorilla Black Spline ET Lugs - AJT TRD Key Fob + Interior Chrome Delete Kit - TRD Shift Knob (Black) - JimmyRigged ToYoda Steering Wheel Emblem Overlay - JRT Tech 12 Front Dash JL Audio Speakers - K&N Cabin Filter - Chalk Bag Mod - Weather Tech Mats - Ceramic Window Tint
    WILLINH likes this.
  7. May 21, 2022 at 10:17 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    My local car wash has a sign warning you that antennae and other aftermarket parts that project from the car can be damaged during the wash, and they accept no liability. My guess is the OP drove past the sign and just didn’t think about it.
    Just get a stubby antenna. They look better anyway.
    WILLINH likes this.
  8. May 21, 2022 at 5:11 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I don't use automatic car washes. Changed the oil on my daughters RX350 the other day and she washed it. I clay barred and ceramic coated the hood and fenders. I showed her what automatic car washes do to black paint.
  9. May 21, 2022 at 6:09 PM
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    That was the first job I had to do on mine when I bought it. It was easy but this is the chap that stripped and rebuilt his old Ford Explorer Sport Trac transmission, as with any job it helps if you have the right tools for that job. I didn't have to mess around with the coax cable or antenna and I hope I never have to. The little plastic replacement part was obtained as an aftermarket part from a well known auto factor store, it was cheap and doesn't fit very well but it does the job.
    However, I get the impression that the OP doesn't just have a broken wing mount, so I'm probably not much help.
  10. Jul 22, 2023 at 11:20 AM
    Nickels9
    Nickels9 New Member
    Eric
    Tucson, Az
    2016 Crewmax
    Did you ever replace it? Did you do it yourself or have the dealer do it? My wife wanted to be nice took my truck through the car wash and it snapped.
  11. Jul 22, 2023 at 12:01 PM
    reefcomber
    New England
    2018 Platinum
    I was able to get the broken piece out. I tried using a screw extractor, but I could never get a good bite.
    I pulled out my corded drill though and then was able to get enough metal cored out of the broken screw, and then was finally able to get the extractor to get a good bite.
    Good luck!!
  12. Jul 22, 2023 at 1:41 PM
    TheBrit
    Mark
    Well, poo! Your posting again on here seems to have made my truck jealous and it has lost it's antenna bezel - for the second time, looks like they must have a 5 year life span in the Deep South.
  13. Jul 22, 2023 at 4:17 PM
    reefcomber
    New England
    2018 Platinum
  14. Jul 22, 2023 at 8:16 PM
    panicman
    Eric
    I am back to kick myself in the ass and share knowledge. Last year I relented and went through the car wash, probably only the second or third time. The brushes ripped that stubby antenna off like a damn scab. I replaced it, but I’ll get out and remove it if I have to go through a wash again.
  15. Jul 23, 2023 at 5:27 AM
    ChrisLopez
    ChrisLopez New Member
    Christian
    Chicago,Illinois
    2018 Tundra SR5 TRD off road Crew max
    I did same. Screwed it even more by using extractor set. I barely use the radio so I’ll be ok without it.
