Broke down on side of road currently
Discussion in '2nd Gen Tundras (2007-2013)' started by kenomouth64, Apr 15, 2019.
  1. Apr 15, 2019 at 6:36 AM
    kenomouth64
    kenomouth64 [OP] New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    Well, I am currently broken down on the side of the road. The Tundra lost all power while driving about 40mph.
    I am waiting on a friend to bring me some tools and a gas can, as I am betting I know the issue.
    My Tundra has run out of gas before, when it said it had 1/4 of a tank.
    This time it has 1/3 of a tank. I had been watching the fuel mileage thinking I was getting better than normal. So fingers crossed that I just ran out of gas and the gauge needs to be fixed.
  2. Apr 15, 2019 at 6:42 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Interesting, same year hear but no issues yet.
    Good luck!
  3. Apr 15, 2019 at 6:43 AM
    :popcorn: hope nothing serious
  4. Apr 15, 2019 at 6:52 AM
    I remember you having a sending unit issue.
    Personally, I would set a realistic mileage (200 miles empty, 125 miles towing) and fuel up at that mileage if there are no plans to fix this issue.
    Fuel injection systems don’t like running out of fuel. One vehicle I was test driving ran out of fuel and cost the dealership over 1000.00 plus a tow.
    Black Wolf and 15whtrd like this.
  5. Apr 15, 2019 at 9:19 AM
    kenomouth64
    Tetrus
    Indeed, I recall us talking about this issue around a year ago. Normally I fill up around 1/3 of a tank. However, I suppose that is not the best metric to go by, lol. It took 4 Gallons of gas and disconnecting the battery to get it to get going. I am a cheapskate so I likely will not fix it until my fuel pump goes and needs to be replaced (no telling when that might be...).
    I am just going to start marking the Trip A and gassing up close to 200 Miles to avoid this. I also am going to strap down 2 - 5 Gallon Jerry cans in the back. I might build some kind of box/armor for them as I don't want them to get damaged. You have any recommendations for this?
    15whtrd likes this.
  6. Apr 15, 2019 at 9:28 AM
    15whtrd
    15whtrd Mr. Blonde
    Sounds like a good plan but after all that work why not just drop the tank and fix it? Or both LOL
    JohnLakeman, Trooper2 and Black Wolf like this.
  7. Apr 15, 2019 at 10:18 AM
    n2deep
    n2deep Pavement Princess
    bad fuel sending unit - had the same issue. If you go the gas can route use ethanol free gas as it last longer and doesn't go bad as I have been told. Everyone I know stores Ethanol free gas for their generators.
    kenomouth64[OP] likes this.
  8. Apr 15, 2019 at 12:37 PM
    kgb4187
    kgb4187 New Member
    Kick the tank and see if it sounds empty
    15whtrd likes this.
  9. Apr 15, 2019 at 12:42 PM
  10. Apr 15, 2019 at 12:50 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    you need to be waiting with this guy...
    then you can go ahead and get into this truck...
  11. Apr 15, 2019 at 12:56 PM
  12. Apr 15, 2019 at 12:57 PM
    Grumpy Uncle
    Pat
    CO
    Aaaand hope you don't hear this!
  13. Apr 15, 2019 at 1:15 PM
    And you definitely don't want to get into one of these cuz you won't get anywhere fast.....
    :rofl: :hattip: :stirthepot:
  14. Apr 15, 2019 at 1:23 PM
    15whtrd
    15whtrd Mr. Blonde
  15. Apr 15, 2019 at 1:26 PM
    15whtrd[QUOTED] likes this.
  16. Apr 15, 2019 at 1:44 PM
    Padj
    Padj Life is what happens when you're making plans
    Denver, Colorado
    2019 Limited CM TRD MGM
    Black Wolf and 15whtrd[QUOTED] like this.
  17. Apr 15, 2019 at 1:53 PM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    Good luck, get a real NATO/Jerry can and it won't have one of those nanny spouts.
  18. Apr 15, 2019 at 1:54 PM
    Wutachampion
    Wutachampion New Member
    DFW
    used to own - 2016 MGM SR5 CM Texas Edition
    I just did this and realized I have at least two more double chins than James Franco and not the same look happened.
  19. Apr 15, 2019 at 1:55 PM
    15whtrd
    15whtrd Mr. Blonde
    :rofl::rofl:
  20. Apr 16, 2019 at 7:54 AM
    kenomouth64
    Tetrus
    That is good to know. It makes sense when someone tells you, but I never would have thought of it otherwise.
    LOL, everyone always gets the same impression of me, whether it is at work or socially.
    smslavin[QUOTED] likes this.
  21. Apr 16, 2019 at 8:02 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    So what was the problem? Did I miss it?
  22. Apr 16, 2019 at 8:46 AM
    kenomouth64
    Tetrus
    The truck ran out gas, despite the gauge showing it had 1/3 of a tank. The issue is a bad fuel sending unit.
    NewImprovedRon likes this.
