Bro lean
Discussion in 'Suspension' started by power80, Sep 26, 2018.
  1. Jun 17, 2019 at 1:28 PM
    #61
    15whtrd
    15whtrd Mr. Blonde
    Miss you Connor
  2. Jun 17, 2019 at 2:27 PM
    #62
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Someone on the Texas fishing forum referred to it as the bulldog look when I described a F250 wannabe
  3. Jun 17, 2019 at 2:32 PM
    #63
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I like this one but hyper as heck. She can scoot. New name is "Skunk Killer"
  4. Jun 18, 2019 at 12:36 PM
    #64
    wigburner
    wigburner New Member
    09 double cab 5.7
    does this help
    it has settle down in the front a bit.....
  5. Jun 18, 2019 at 12:37 PM
    #65
    15whtrd
    15whtrd Mr. Blonde
    Perfect. It looks like they set up the spring perch properly so you can rule that out. Thanks for the picture.
  6. Jun 18, 2019 at 12:42 PM
    #66
    15whtrd
    15whtrd Mr. Blonde
    For comparison I have the TRD pro suspension in the front and rear with +2 coachbuilder shackles and my truck has just a slight amount of positive rake. I’d say maybe 3/4”-1” of rake. Haven’t had a chance to find some perfectly level ground to measure it on. Even then it seems like it might be inconsistent.
  7. Jun 18, 2019 at 1:01 PM
    #67
    wigburner
    09 double cab 5.7
    thank you.
    right now the passenger side is sitting 40" from ground to top of fenders on front and read.
    on drivers side I'm measuring 40.5 in the front and 39.5 in the rear..... maybe the CB SHIM should be removed and jammed on my rear leaf spring ;)
    15whtrd[QUOTED] likes this.
  8. Jun 18, 2019 at 3:28 PM
    #68
    15whtrd
    15whtrd Mr. Blonde
    It almost sounds like you didn’t even need that shim. If it’s a quarter inch shim that equals about a half inch at the wheel of lift. Also re-check your measurements from the center of the wheel to the fender that’s more accurate then to the ground because of tire bulge and pressures. It just takes out any discrepancies. Finding perfectly level ground is the hard part.
