Brakes!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Pupule Mike, Feb 10, 2020.
  1. Feb 10, 2020 at 10:17 AM
    Pupule Mike
    Pupule Mike [OP] New Member
    2015 Tundra Limited Crew Max
    Last month I was at the dealership, they told me I need brakes on all four corners, the quote was $350.00 per axle, so $700.00 for the whole truck, and maybe rotors if needed. Does this sound about right? Rotors were $175.00 ea.
    I spoke with an independent mechanic that specializes on Toyotas, he told the average Tundra usually wears out pads at 30K. Does this sound right? My Tundra has 74K on it now.
  2. Feb 10, 2020 at 10:21 AM
    BlueDream
    BlueDream New Member
    2015 Tundra Dbl cab SR5 5.7
    6" procomp stage 3 lift, Method NV 18x9, Cooper STT pro 305/70R18, AFE air cleaner, LED fogs, Ranch hand Grille guard, Rhino liner, retrax bed cover, Flowmaster Duals, 15% Tint, vinyl chrome delete
    Typical dealership rippoff.
    Tundyfundy and Pupule Mike[OP] like this.
  3. Feb 10, 2020 at 10:37 AM
    IBJC
    IBJC New Member
    2020 tundra sr5 crewmax Cavalry Blue
    You can do it yourself for a third of that If you're mechanically inclined
    Tundyfundy and AlbertaBeef like this.
  4. Feb 10, 2020 at 10:41 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    NO!!!
    Tundyfundy likes this.
  5. Feb 10, 2020 at 11:08 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    If you are mechanically inclined at all I would suggest changing them yourself. I changed mine recently. $112 for the front and rear pads from the dealership, and the part that took the longest was removing and installing the wheels. The front pads only need some metal spring clips removed and 2 pins pulled out. Super easy
  6. Feb 10, 2020 at 11:11 AM
    Chucho
    Chucho New Member
    Rob
    Salem, OR
    2017 MGM DC Tundra SR5 TRD 4X4
    Tuff Country 2" Level spacer Kit up front Paired with KYB Mono Max shocks all around. Roadmaster Active Suspension HD kit 1mm gap 275/70R18 Falken Wildpeak A/T3W mounted on some MB352 18X9 + 25 Cobra 19DXIV CB radio.
    I'm going on 80K miles and am still on original pads from the factory.
    I bought my truck new and everything is still good.
    Sumo91 likes this.
  7. Feb 10, 2020 at 11:18 AM
    RickC
    RickC NOT a new member
    Rick
    Knoxville TN
    2017 CrewMax Platinum 4x4 5.7
    SCS Wheels, Line-X, WeatherTech, UnderCover Flex bed cover
    You can do them including rotors for about 100.00 a corner. I buy my parts from conicelli because they discount them and have never had an issue. 175.00 for the rotor is ridiculous. Here is a link to the parts and prices: https://parts.conicellitoyotaofcons...a--limited--5-7l-v8-flex/brakes--front-brakes
    If your truck doesn't vibrate or pulsate when braking, you more than likely don't need rotors which means only the pads need replacing. And if that is the case, then what Sumo91 said is exactly right. You don't even have to pull the caliper to replace the pads.
    Check out youtube but if you know which end of the wrench to hold, then you can replace the pads yourself. Not difficult at all.
    Tundra_361 and Sumo91 like this.
  8. Feb 10, 2020 at 11:36 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    If the OP is on the original rotors and pads at 74k, then he's done pretty well. My pads were toast at 47k and the rotors were getting pretty thin. I replaced my rotors and pads with a powerstop kit for about $400 all in. The job isn't too difficult unless the calipers are rusted on. Then you have to break out the heat. Doable DIY.
  9. Feb 10, 2020 at 11:41 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    I only find stealerships useful for Warranty work and OEM parts that I want, otherwise..... I DIM or find a mechanic I trust....
    AlbertaBeef likes this.
  10. Feb 10, 2020 at 12:48 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Interesting, I've never replaced pads without taking the caliper off but I've also never replaced pads on a Tundra.
  11. Feb 10, 2020 at 12:54 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Watch YouTube videos. I changed all rotors to OE rotors and trd brake pads for about $500 in parts, shipped. Changed them all myself in a day, I’d say about 4 hours, taking my time and running into a small issue with one of the rear rotors and parking brake. After that was resolved, the other side was easy peasy.
  12. Feb 10, 2020 at 5:36 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Just did pads and rotors at 74K. Never had any vehicle brakes last that long. I tow too.
  13. Feb 10, 2020 at 6:15 PM
    RickC
    Rick
    Knoxville TN
    focal and Joe333x[QUOTED] like this.
  14. Feb 10, 2020 at 7:02 PM
    AKJ78
    AKJ78 New Member
    Aaron
    San Diego
    2016 Silver Platinum 4X4
    3/1.5 lift. TRD sway bar. Bakflip V1 cover. Fuel wheels w/BFG A/T.
    This setup was $154 when I purchased 2 months ago. Hard to tell if they’re better than stock since stock were in bad shape when I replaced them. I will say braking is excellent. No complaints after 1500 miles so far. Took about 3 hours to do all 4. Very easy compared to other vehicles I’ve worked on.
  15. Feb 10, 2020 at 7:35 PM
    I just did front and rear StopTech Sport slotted rotors (cryo treated for the front) and PosiQuiet ceramic pads. 600 miles so far and I'm happy with them. I ran Powerstops prior. No more vibrations.
  16. Feb 10, 2020 at 8:37 PM
    Joe333x
    Joe333x Member
    Boston
    Thanks for the video. Personally I think I'd just take the caliper off though. That looks like a great way to mar the rotors, you can see marks he left on them in that video. What I do is use large C clamp pliers to compress the old pads down with the caliper off. Plus that what I can apply some WD40 to the caliper bolts since I had one seize on in a car before due to the amount of salt corrosion we have here.
  17. Feb 10, 2020 at 9:07 PM
    ski
    ski New Member
    Interesting. Conicelli is in the next town over from me. Didnt know they had an online parts store.
    RickC[QUOTED] likes this.
  18. Feb 12, 2020 at 5:34 PM
    RickC
    Rick
    Knoxville TN
    Yep, been buying my 4runner parts from them for years and I just replaced the brakes on all 4 corners including rotors on my Camry just a few weeks ago. Great bunch to deal with regarding parts.
  19. Feb 12, 2020 at 5:38 PM
    RickC
    Rick
    Knoxville TN
    I agree. I have never done it this way and thought the same thing when I watched it. I was just showing that it can be done and probably with the right tools instead of using a screw driver, one could push the pistons back in without damaging the rotor. I have always removed them and used c clamps and one of the old brake pads.
    Joe333x[QUOTED] likes this.
  20. Feb 12, 2020 at 7:41 PM
    kevine0001
    kevine0001 New Member
    Kevin
    I'd also say even if you're NOT mechanically inclined, watch a youtube video and do it yourself. Get good pads, and if necessary, good rotors. Or jack it up on stands, take all four rotors to get them turned (about $10/rotor) and install new pads yourself. It's really easy. For basic pads, probably $75/pair (per axle). You can get really good pads for probably $100+ per axle. So under $250 and you're done. New rotors are probably $150 per axle. But you'd still save money.
  21. Feb 12, 2020 at 8:01 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I don't like turning rotors, it's easier to warp rotors after turning. I will do pad and rotor at the same time. it's a cheap insurance. You never know when you need to haul big load, and that's when that turn rotors get warp.
  22. Feb 13, 2020 at 8:15 AM
    kevine0001
    Kevin
    Winning, I agree that turning increases chances of warping since you are technically making the rotor thinner by removing a layer. But warping sometimes is due to pads that have uneven patches of friction material (cheap pads) that causes warping.
    I don't haul with my truck. It's basically for hunting and camping so I don't have concerns of pulling a heavy load, etc. Thus turning a rotor once for my type of driving I don't believe runs that much risk. However, I typically won't turn a rotor more than once before tossing. After that, then the risk of warping increases significantly.
  23. Feb 13, 2020 at 10:27 AM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    I just bought rotors for all four corners and pads from Roman at Cool Springs Toyota for I around $472 shipped to me. My dealership tried to quote me almost $900, then tried to tell me it was because I truck is lifted... my Tundra is not lifted at all.
  24. Feb 13, 2020 at 1:28 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    That’s not bad for brake job only 900 when parts almost 500 with beers... BMW is close to 2k.
  25. Feb 13, 2020 at 6:59 PM
    omgboost
    East Coast
    Having both a BMW and Toyota, BMW parts seem to be a bit cheaper and depending on who you order from, you get free shipping and lifetime warranty.
