Brakes for heavy towing?
Discussion in 'Towing & Hauling' started by grundletaint, Mar 29, 2017.
  1. Mar 29, 2017 at 11:05 AM
    grundletaint
    grundletaint [OP] New Member
    2012 MGM platinum crewmax
    I'm about to replace my suspension and figure it may be a good time to do brakes so I won't have to deal with it later on.
    I'm on OEM 76000 miles and they've already been machined. There's a little vibration now.
    Any recommendations on a kit or source for something that will handle a lot of heavy towing? 2012 4x4
    Thanks!
  2. Apr 1, 2017 at 6:40 PM
    grundletaint
    Anybody? Good pads/rotors for towing?
  3. Apr 1, 2017 at 6:47 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Try powerstop slotted rotors. Heard good things about their rotors. OEM pads seem to be the best way to go from what I'm told.
    grundletaint[OP] and GNTundra like this.
  4. Apr 10, 2017 at 8:44 AM
    BigCountry
    BigCountry New Member
    Garrett
    Edmond, ok. (Arkadelphia, Arkansas, school)
    2009 5.7L flex fuel, 4wd, sr5.
    Leveling kit, 20" hostage fuel rims, mangmum flow dual pipe, and bull guard.
    I hear ARB have great slotted rotors. Slotted is the best way to go, espcicially if your getting her dirty.
    grundletaint[OP] likes this.
  5. Apr 13, 2017 at 10:40 AM
    JerseyTundra1260
    JerseyTundra1260 08 Silver streaking!!!!!
    Marc
    New Jersey
    08 Silver Tundra DC Limited 4x4
    Too many to list.....
    Centric anti corrosive rotors with Hawk pads :thumbsup:
  6. Apr 16, 2017 at 9:52 PM
    Wes07
    Wes07 New Member
    Wes
    Colorado Springs
    07 tundra
    I'm looking at the power stop kit with calipers since my right front needs replacing. Not sure about the rear.
  7. Apr 17, 2017 at 12:05 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    If wanting the best stopping power, a BBK is the way to go. If wanting OEM size, I'd go with Disc Italia from Brakeworld.com with some heavy duty pads. Disc Italia will most likely be the way I go when I need to replace rotors.
  8. Apr 17, 2017 at 4:05 AM
    I did Centric premium rotors and their matching pads. The ones on my Tundra were slotted. Only improvement was wet braking.
    Since then I have just used Centric premium rotors and the Centric matching pads on both my Lexus and Tacoma from autoanything.com
  9. Apr 17, 2017 at 6:18 AM
    Wes07
    Wes07 New Member
    Wes
    Colorado Springs
    07 tundra
    I'm trying to get a buget performance set since I already have a lot of rust and need at least a front right caliper. My rear I will probably just go basic oe in the rear. Best way to bleed that front right without messing with the abs system?
    ColoradoTJ likes this.
  10. Apr 17, 2017 at 6:56 AM
    I would do a Centric Premium and pads.
    You do know the calipers are rebuildable right? Kits are 12.00, unless the caliper is just really rusted and pitted.
    Bleed the brakes like normal. Start with the caliper that is furthest from the master cylinder and work your way in. (Pass rear, drivers rear, pass front, driver front)
    NewImprovedRon likes this.
  11. Apr 17, 2017 at 11:53 AM
    Wes07
    Wes07 New Member
    Wes
    Colorado Springs
    07 tundra
    I'll look into the rebuild kit, the slider pins are really bad and not letting the inside piston return and one of the boots is torn.
  12. Apr 17, 2017 at 1:50 PM
    Well if you need help, we live in the same city.
    040Tundra likes this.
