Brakes and Rotors
Discussion in '2nd Gen Tundras (2007-2013)' started by WhitmanTundra, Oct 18, 2019.
  1. Oct 22, 2019 at 11:46 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    considering doing the powerstop calipers also when i do my brakes...have stop tech cryo rotors, ebc yellow pads and 6 stainless crown performance lines waiting to go on now...how long have the powerstop calipers been on? no issues? have read mixed reviews on them on different brand vehicles, no feedback on tundras. i've always had good luck with their rotors and pads.
  2. Oct 22, 2019 at 12:26 PM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    No Issues, been on about 2 months, about 5k miles so far, in that time I had to travel from MA to VA and back towing a double axle cargo trailer, the brake pedal feels firmer than before, brakes come on sooner, could just be the new pads and rotors and clean fluid. It was a pretty easy job only tricky part was threading the line into the from calipers, it is not a banjo bolt it is a hard line with a I believe tapered threads, you cannot thread it on by hand as you cannot spin the male fitting by hand because it is tight on the line. You have to use a wrench to start it, I was concerned about cross threading but it came out fine. I bled the brakes with a vacuum bleeder, started at the passenger rear, then driver rear, passenger front and driver front, fluid looked very good for being 10 years old. They have the calipers in black and red I chose the black.
  3. Oct 22, 2019 at 12:46 PM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    thanks for the reply!
