Brake Upgrade items
Discussion in '1st Gen Tundras (2000-2006)' started by Jbhoops, Aug 13, 2022.
  1. Jun 1, 2023 at 7:08 PM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    maybeillbuyit and Mustanley like this.
  2. Jun 1, 2023 at 7:16 PM
    Jasont
    Jasont New Member
    05double cab
    2.5 rough country
  3. Jun 2, 2023 at 1:47 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Seems like the double cabs have less issues with the mushy brake pedal issue.
  4. Jun 2, 2023 at 7:34 PM
    Jasont
    Jasont New Member
    05double cab
    2.5 rough country
    Possibly, I haven’t heard that
  5. Jun 14, 2023 at 9:10 AM
    maybeillbuyit
    maybeillbuyit New Member
    2006 AC V8 SR5
    I haven't heard of this upgrade before. Does anyone have pics of the machined calipers? Just wondering what exactly needs doing.
  6. Jun 14, 2023 at 9:15 AM
    https://www.tundras.com/threads/2000-2006-tundra-big-brake-upgrade-kit-14wa-calipers.61231/
    Reality is, if you've got one of the earlier trucks that doesn't have the 13WL calipers found on the later trucks, you'll get just about as much bang vs. buck using the bolt-on-ready 13WL brakes rather than the expense of properly milling 14WA calipers from other Toyotas.
    While most of the complaining about brake ineffectiveness seems to be in the earlier year trucks, and among DC owners, you'd be shocked at how many people don't have their rears dialed in properly, which is a huge source of ineffective braking. #1 on the list is improperly adjusted rears and/or faulty or missing rear e-brake system, and #2 would probably be improper bleeding. Adjusting your rears is so critical to good braking with these trucks, there's an entire sticky thread dedicated to the topic which has solved problems for a huge swath of people.
    PS - don't trust just anybody to do the machine work. At least one person here ended up throwing away basicall new brakes because the shop screwed it up. There's a reason people use Jim Smola or whoever to do the work - he knows exactly what needs to be done and exactly how to do it.
    AmericanKing06 and Bmktw2 like this.
  7. Jun 14, 2023 at 12:24 PM
    maybeillbuyit
    2006 AC V8 SR5
    Shifty, Thx for the informative response. I already have the later 13WL calipers that I just replaced with new including new hoses, full flush etc. And properly (I hope) adjusted rears with all new parts including drums. Braking is great for now but I find these calipers are problematic as time goes by. I've also had a bought of warping rotors ( fixed by replacing the calipers). What does Jim Smola charge for machining? At $200 for the Callahan calipers ( Amazon)plus a reasonable machining cost it sounds cheap enough to me. I'll continue to read up. Thx again.
  8. Jun 14, 2023 at 12:42 PM
    Not sure on machining. One of the guys in the other thread would need to answer, you basically ship the parts from Toyota to him. I don't know if Jim works on non-OEM calipers, the castings would be different, thus the work different.
    I know for a fact many people on this forum have had problems with aftermarket brake parts, *especially* rotors and drums being out-of-round, straight out of the box. With that in mind, brakes on these trucks are just one of those places where I wouldn't be buying Callahan or any other brand besides OEM (or Denso, or Aisin). And with how many confirmed counterfeits scAmazon has shipped people across the various forums I've been posting on the last couple decades, I sure as hell wouldn't buy any replacement parts. Hell, I've gotten a handful of counterfeit/whitebox/non-genuine parts there myself. fleaBay isn't much better these days. They've all turned into Alibaba.
    Depending on which booster/MC combo you have, you may also find poorer braking on your truck. Seems some setups for certain cab types/options were worse than others. I feel like it's often the guys with auto-VSC/traction control crap that tend to bitch the most about poor braking response, we also see it from the '00-'02 or '03 crowd.
    You may want to go into your profile and in the 'Vehicle one-line description' field, input your truck's year/cab-type/engine/drivetrain where engine is just V6 or V8 and drivetrain is 2WD or 4WD. Like, "2005 DC V8 4WD" where DC is double cab, AC is access cab, RC is regular cab or write "Sequoia" with the year if that's the 1st gen you've got. It may help others help you in the process, since there's so many variations.
  9. Jun 14, 2023 at 1:57 PM
    2006Tundra
    Lou
    Long Beach, CA
    Jim machined my calipers July of 2022, he charged me $170 for machining and shipped to me with a really fast turn around, maybe a 3-4 days. I absolutely love the upgrade. Stops my truck with 34's with ease.
    maybeillbuyit[QUOTED] likes this.
  10. Jun 14, 2023 at 2:01 PM
    maybeillbuyit
    2006 AC V8 SR5
    I see 912 further up the thread here used the Callahans and had them machined by Jim Smola so I guess he does. As for different castings, they'd have to be pretty close to originals to fit in the first place, No?
    As for rotors warped out of the box I've had a few and the worst by far were the Toyota ones from my local dealer. Unfortunately I had them on a shelf for over a year, installed them , found to be warped and warranty was up so Toyota wouldn't replace them. Mmmmm
    I'll take a look at my profile and add some info. Thx again
    shifty` likes this.
  11. Jul 2, 2023 at 6:41 PM
    Jasont
    Jasont New Member
    05double cab
    2.5 rough country
    I’m all in like 600 700 bucks. That’s the calipers Smola recommended, I found oem rotors and pads from a Lexus dealer in Scottsdale. Shipped to Vegas. Cheaper than any of the Toyota online places and cheaper than Napa. 4 new springs the ones to keep the pads away from the rotor. And new “shims”. I also did new rear shoes, and steel lines front and rear. Couldn’t be happier. I chased warped rotors like crazy. Until this
  12. Apr 18, 2024 at 10:03 PM
    TacticalAnt
    TacticalAnt New Member
    2006 Tundra DC
    Where do I find Jim Smola contact info? Does he have a website? Is he a member here?
  13. Apr 19, 2024 at 4:41 AM
    If you search this subforum for "smola" you can find his instagram and contact info.
  14. Apr 19, 2024 at 5:12 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Will the 13WL calipers work with stock Patrick wheels on a 2000 AC?
    JasonC. likes this.
  15. Apr 19, 2024 at 8:18 AM
    TacticalAnt
    2006 Tundra DC
    I was afraid of that. Instagram is confusing to me. I was hoping for an old guy contact solution.
    noahrexion and FrenchToasty like this.
  16. Apr 19, 2024 at 8:30 AM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    You can contact him through Facebook (Messenger) if you're into that.
    des2mtn likes this.
  17. Apr 19, 2024 at 8:36 AM
    TacticalAnt
    2006 Tundra DC
    Thanks, that i was able to do.
  18. Apr 19, 2024 at 8:44 AM
    2006Tundra
    Lou
    Long Beach, CA
    Jim’s cell
    +1 (864) 205-6175
  19. Apr 19, 2024 at 8:51 AM
    #49
    TacticalAnt
    2006 Tundra DC
    Sweet, just texted him!
    2006Tundra[QUOTED] likes this.
  20. Jul 24, 2024 at 12:59 PM
    #50
    Nik Lick
    Nik Lick New Member
    Nik
    2001 Tundra v8 limited
    emu 2.5" lift. Arb bull bar.
    I cannot find a source for stainless steel brake lines, for the brake upgrade. Preferably with the banjo bolt swap.
    I also would like to be certain that I do or do not need wheel spacers. with stock 17s
  21. Jul 24, 2024 at 1:34 PM
    #51
    TacticalAnt
    2006 Tundra DC
    I got 2 sets of stock 17’s. On a 30mm offset, the other 15mm. They both cleared the calipers, barely by 1/8”. But the 30mm offset got too close to my A-arms, so i went with 15mm.
  22. Jul 25, 2024 at 11:46 AM
    #52
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I found some stoptech steel lines on Napa that were pretty reasonable and I had good luck with them on my last truck. No banjo fitting though.
