Brake Replacement Options
Discussion in 'Towing & Hauling' started by Buckaroo, Nov 27, 2021.
  1. Jan 20, 2022 at 8:29 AM
    aceman1741
    aceman1741 New Member
    Robert
    2019 Toyota Tundra Crew Cab 4x4
    Lifted, 35x12.5xR20LT Ridgegrapplers
    Will do thanks.
    I found on previous forums with the 2010 models and thereabouts, the oem breaking system was under powered and would cause severe braking wobble/shimmy in which we unfortunately found out for ourselves on our first trip with it. I upgraded to the TRD rotors and brakes and problem was solved. Now we have a 2019 and I guess Toyota solved that problem.
    I guess I was over thinking the problem to the 2019 model but I will post back once I change the pads on my next brake service.
  2. Jan 20, 2022 at 8:31 AM
    aceman1741
    Robert
    Yes there is
  3. Jan 20, 2022 at 8:35 AM
    aceman1741
    Robert
  4. Jan 20, 2022 at 8:36 AM
    Rubberdown
    Yeah I know those exist. I have them in my garage. But there are no “trd style rotors” that come on tundras. There are TRD rotors for a big brake kit. There ARE trd pads that work with the stock rotors. So... whatcha talking bout Willis.
  5. Jan 20, 2022 at 8:39 AM
    aceman1741
    Robert
    That's what I was talking about. On the 2010, the oem brake system was under powered. I went to these, which the rotors and brake pads were changed out. So yes, TRD did make these. This system helped us out quite a bit and fixed the problem we were having under braking.
    Lastly, no need to be rude, Willis
  6. Jan 20, 2022 at 9:01 AM
    Rubberdown
    Jeez people are sensitive Sally’s. I wasn’t being rude at all. I’m confused what you’re saying. Re reading with all this context you put the TRD big brake kit on your truck. Neato! I bought those for my truck but am not willing to go with 20s so there they sit.
  7. Jan 20, 2022 at 9:04 AM
    aceman1741
    Robert
    Great
    YoungManTan likes this.
  8. Jan 20, 2022 at 9:12 AM
    Rubberdown
  9. Jan 20, 2022 at 9:23 AM
    timsp8
    NY
    The $2700 big brake kit is far from standard oem.
  10. Jan 20, 2022 at 3:12 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    The stock pads don't have brake dust, but the TRD pads generate tons of dust. I had the stock ones before I changed to the TRD pads and can't really feel the difference between the two. I may end up going back to the stock pads because I don't want to deal with brake dust.
    CMikeB likes this.
  11. Jan 21, 2022 at 5:12 AM
    Bigmax
    Bigmax New Member
    Wilmington, NC
    2017 Sr5 Tundra crew max 5.7L
    Toytec coilovers with Bilsteins, 20x10 Fuel Assualts, 33x12.50 Toyo RT.
    I have a 2017 sr5 and like the oem pads since I don't tow and low dust. I've been looking and have found some on ebay and went to the Toyota site but come up with 2 different part numbers. Can anyone help me with the correct oem part number? Here are the 2 numbers I've found. dealer 044650C020
    EBAY 04465-AZ220
    Is there a difference? Also need rear brakes too thanks
  12. Jan 24, 2022 at 5:17 AM
    Buckaroo
    Buckaroo [OP] New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    So what did they say?
  13. Jan 24, 2022 at 6:18 AM
    timsp8
    NY
    They require 20” or larger wheels.
  14. Jan 24, 2022 at 8:24 AM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    This is not a correct statement. 07-10 Tundra did not have slots for cooling in the dust shield and toyota issued a tSB to replace them. After the modification you did not get any new hardware except two new dust shields with air vents.
    Whomever told you that you needed to buy 20" rims and that $3K big brake kit took your money and is a jerk. As they flat out lied to you.
    If you aren't going to go 20's then sell those no longer in production from Toyota (see Brembo) that replaced them big brake kit.
    or i'd happily take them off your hands. Just can't justify 2700 bucks for a larger rotors.
  15. Jan 24, 2022 at 11:06 AM
    bgdv1
    bgdv1 New Member
    Dave
    Butler,Pa
    2019 Limited CMSB
    PowerStop will do nothing. I purchased thru a vendor and have to contact them with any issues. I was planning to run over there last Saturday and ended up with covid on Thursday. I haven't reached out to Summit yet.
  16. Jan 24, 2022 at 5:22 PM
    ATHiker
    ATHiker New Member
    Tom
    2015 DC SR5TRD 5.7L 4X4
    My PowerStop Z36 front rotors glazed. I purchased thru Amazon, but I called PowerStop and they provided a new set of rotors and pads.........
  17. Jan 26, 2022 at 9:09 PM
    aceman1741
    Robert
    My truck already has 20 inch rims on them so going with the bigger TRD brakes was a no brainer.
  18. Jan 26, 2022 at 9:14 PM
    aceman1741
    Robert
  19. Jan 27, 2022 at 1:08 AM
    #49
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I second the Stop Tech slotted Cryo treated rotors.
    I paired with TRD brake pads and braided steel brake lines. I love the setup. The braking is smooth and progressively aggressive as you get your foot into the pedal. Such a good feeling over stock.
    These rotors:
    https://www.buybrakes.com/stoptech-126.44157csr-cryo-sport-slotted-brake-rotor-right
    These Pads:
    https://parts.freemantoyota.com/oem...nmllG9umhE76Xb8qDHEb_cqHVHJ9aBMYaApIrEALw_wcB
    These brake lines:
    https://www.tirerack.com/brakes/bra...Stop+Brakeline+Kit&group=G-Stop+Brakeline+Kit
    after feeling the difference I would never go back to stock
    Vr0ck likes this.
  20. Jan 27, 2022 at 5:43 AM
    #50
    WXman
    WXman New Member
    Kentucky
    2016 Tundra SR5 Crew Max 4x4 5.7L
    My new to me truck had new brakes put on it right before the original owner traded it in. I noticed the rotors are drilled and slotted and the pads seem to have a lot of thickness left in them. However, they pulsate at times and they dust like hell! I don't know what brand they are but in the future I'm going back with all OE equipment on my brakes. Either that or I'll buy the AutoZone rotors and pads because they do a lifetime warranty on them. Buy once and you're good for the rest of the life of the truck. That's what my father does. He drives a 1-ton because he uses it for a living. Goes through brakes about once every 18-24 months due to miles. Just takes the stuff back into AutoZone and they give him all new stuff.
  21. Jan 31, 2022 at 10:57 AM
    #51
    Half track
    Half track New Member
    Rob
    Western Nevada
    2020 Silver Tundra SR5 TRD, 38 gal tank
    Tow Mirrors
    Why not buy OEM brakes and rotors.
    My ford f250 diesels brakes lasted 9 yrs and 200k miles, they were still good when I sold the truck.
    I would pull my 8,000 lbs trailer 1000 miles a year.
    If I replaced brakes every 24 months that would be like 5 brake jobs. Where is the savings in that?
    My old 1/2 ton GMC truck I went through Brakes every 25k miles, after the fourth set I sold the truck.
    I was only pulling my small 4k trailer at that time.
  22. Mar 8, 2022 at 6:33 PM
    #52
    RoughRoad
    RoughRoad New Member
    14' Tundra 1794
    Bags on the back, TRD sway bar
    Got my first Tundra 4X4 1794 in 14' eight plus years ago. I replaced the OEM with EBC 3 or 4 years ago as I drive hard and was sick of warping my rotors. We bought a Lance 2465 trailer July 2020, last year I decided to upgrade the whole braking system with PowerStop Z36 Truck and Tow, also replaced brake lines with braided lines. So far I've towed the trailer weighing around 8,000 and change about 5,000 miles since upgrade and so far I feel they are definitely an upgrade with the double cylinder calipers. I have not noticed any scorching and trust my I drive hard. No chance I replace what I have now and I agree the EBC pads spew dust heavily. These ProStop pads don't put out nearly as much dust. I will be keeping an eye to see if I see any scorching of the rotor or if I notice any sponginess in the pedal.
  23. May 1, 2022 at 5:23 PM
    #53
    Buckaroo
    Central Ohio
    So I installed the PowerStop Z36 Pads & Rotors and drove 6500 miles to Arizona and back to the midwest over 6 weeks towing my 8,000 lb camper. The brakes performed very well with no pedal pulsation at any point and handled all the grades including the climb up to Davis Mountains State Park and down to the bottom of Palo Duro Canyon in Texas. Had a great time and stayed in San Antonio, Sedona, Zion and Santa Fe to name a few places. I just did my post-trip maintenance which included a tire rotation so took a good look at the rotors and pads. Everything looked really good - no evidence of any discoloration, streaks or stripes on the rotors. Some small amount of dust in the slots but no abnormal build up on the wheels.
    Very satisfied so far with the PowerStop Z36 brakes on my Tundra. So much so that I have switched to PowerStop for recent brake installs on the rest of the vehicles in the family "fleet". Just installed PowerStop pads & rotors on the rear of an '05 T4R and rear of an '02 Camry.
  24. Jul 22, 2022 at 8:00 AM
    #54
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    I've had the PowerStop Z36 Pads & Rotors for about 6 years now (~40k miles). In my opinion, their braking performance is on par with the stock pads and rotors under normal driving conditions, but much better at delaying heat related brake fade when towing on steep grades. I've also replaced all of the rubber brake lines with stainless steel braded lines, upgraded to DOT 4 brake fluid and replaced the stock calipers with PowerStop calipers that use epdm o-rings for better heat tolerance.
    The pads and rotors work well when they're new, but the rotors corrode and wear quickly. The cross-drilling and slots start out substantial and distinct, but after about a year they get filled with a lot of rust scale and brake dust. I've had to change the pads 3 times so far and the pad wear indicators (squealers) have not worked on any of them. That's ruined 3 rotors so far because the first indication of trouble has been grinding and pulsing sensations through the pedal.
    Since you can't buy individual rotors I've now replaced the front rotors once and the rear rotors twice since the original installation. Each time, the outer pad was less worn than the inner pad which isn't completely abnormal. The outer pad had about 1/3 thickness left, but the inner pad was worn down to the backing plate and was galling on the rotor. The caliper floating pins were all well lubed and moved freely so the immediate problem was that the pad wear indicators (squealers) didn't make any noise before the pad was spent and the rotor was ruined.
    But even the parts of the rotors that haven't been damaged by a spent brake pad seem to only last as long as the first set of pads here in the Northeast. The non-wear surfaces (including the cross-drilling holes and slots) have been covered in thick, scaly rust within a single year. The rust scale fills the cross-drilling holes and slots so that they can't cool the rotors or vent the friction gasses between the rotor and pad so I may as well have a normal smooth rotor at that point.
    Maybe I'll try the StopTech slotted rotors even though they are much more expensive than the PowerStop rotors.
