Brake pads
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1Tundra5, Dec 1, 2022.
  1. Dec 1, 2022 at 5:27 AM
    1Tundra5
    1Tundra5 [OP] New Member
    Junior
    2015 White SR5
    Why does my break pad have that wear? It’s almost like as if the middle got used more, is this normal?9ED729DB-05E1-4B8B-8B46-F66CE007A83C.jpg
    Would that be a rotor or caliper issue? It seems as if there’s a slight wave wear pattern
  2. Dec 1, 2022 at 5:40 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    I don’t have an answer as to why this happens (a more experienced member will probably chime in on this) but I have seen the exact same wear on a many of the Toyotas I have owned. Don’t know if it is normal or not…
    Recently on my wife’s 216 Highlander. Hers were a lot worse than yours. That little lip towards the edges was rusted away.
    However when I have seen this wear, it has been after many many miles or like my wife’s car after many years (7).
    1Tundra5[OP] likes this.
  3. Dec 1, 2022 at 5:51 AM
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    I’m no expert. My guess is prolonged higher temps is causing the part of the rotor under the middle part of the pad to swell slightly.
  4. Dec 1, 2022 at 6:21 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I would say its heat warping as well. The OEM brakes in my opinion suck, partially because the truck is a pig, but if I ride the brakes a little too long without holding a lower gear coming down a mountain pass, I can feel it start vibrating and fading. Only have 20k miles. Cant wait to upgrade.
  5. Dec 1, 2022 at 7:59 AM
    Terndrerrr
    Music City
    6UR-FE
    Yeah, these brakes are a common complaint. But I will gladly feed my 6,000 lb truck pads every 40k or so if they stay quiet and don’t accumulate dust. It stops well given its size IMO. I often slap the shifter over to S4 or put it in tow/haul mode to help deceleration when exiting the highway. At almost 36k miles, I have no fade or vibration yet.
    If I were towing at or near max often, I would absolutely upgrade the brakes.
  6. Dec 1, 2022 at 8:03 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    This. I like to do the same.
    Except I had warped rotors by 35K miles. Replaced pads and rotors at 42k miles and pads still had meat on them.
    Terndrerrr[QUOTED] likes this.
  7. Dec 1, 2022 at 8:13 AM
    Terndrerrr
    Music City
    6UR-FE
    Did you go aftermarket on pads and/or rotors?
  8. Dec 1, 2022 at 8:15 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Aftermarket. Admittedly cheaper ones too. So far not a single issue and performance has been the same as OEM.
  9. Dec 1, 2022 at 8:43 AM
    1Tundra5
    Junior
    2015 White SR5
    Do you think I should also buy new rotors?
  10. Dec 1, 2022 at 8:44 AM
    1Tundra5
    Junior
    2015 White SR5
    L
    how could you tell that the rotors were warped? With Christmas around the corner I’d like to save my money if I don’t need to buy new rotors
  11. Dec 1, 2022 at 8:53 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Every time I applied the brakes, I had a pulsation in the steering wheel. Very pronounced. If you have a slight pulse, you could save some bucks by having the rotors turned.
    1Tundra5[QUOTED][OP] likes this.
  12. Dec 1, 2022 at 12:36 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I would buy new rotors for sure. Cryo treated cost a little more but are worth it for Tundras and their finicky brakes.
  13. Jan 25, 2023 at 9:10 AM
    Carolina Peej
    Carolina Peej Hey can you hold the light for me real quick?
    North and South Carolina
    2022 Midnight Black Metallic 4x4 Tundra Platinum 5.5 w/ load leveling + AVS, HUD, and Power Running Boards
    Me too. 18k miles brakes pulse and fade after a few highway speed braking events.
    Searched all night last night for upgraded rotors and pads. Can't find anything. Anyone know who has new rotors for these 6 lug 13.9" rotors?
  14. Jan 25, 2023 at 9:43 AM
    MadMaxCanon
    Cryo treated would be the way to go but not sure if anyone offers them for the 3rd gen yet.
  15. Jan 25, 2023 at 11:38 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I use the shifter to downshift whenever I anticipate having to brake a little hard. I also use on the ranch roads where I hunt to keep my speeds down and not have to brake as much.
