Brake master cylinder went out
Discussion in '1st Gen Tundras (2000-2006)' started by Jake92, Jul 5, 2020.
  1. Jul 5, 2020 at 9:27 AM
    Jake92
    Jake92 [OP] New Member
    2000 Toyota Tundra SR5 4x4 TRD
    So yesterday as I was driving my 2000 Tundra Sr5 4x4 to Borrego Springs from San Diego I noticed my brake light come on. I thought it might be a sensor going bad or something. I was wrong when I got to Borrego springs I had really no pedal left. No brake fluid left in the reservoir. The brake master cylinder is leaking and brake fluid is running down the booster. I was wondering if anyone have replaced them before and knows the brake line but size so I can get some flared wrench’s to fix it when the part comes in. I’m just glad my brakes didn’t give out going though all those curves.
  2. Jul 5, 2020 at 9:44 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    That's one hell-of-a-place to have a brake issue. Good luck with your repair and keep us posted with your results.
    Jake92[OP] likes this.
  3. Jul 5, 2020 at 9:52 AM
    Professional Hand Model
    Hand Protectors
    I bought a 12mm and 10mm Combo Wrench for the wheels brakes bleeders. Ended up getting an 8mm for my new (smaller aftermarket) bleeders valves. I’ll check for you later, but it might make sense to buy an 8,10,12mm just so you have them for later brake work. I’m assuming you need to bleed all your lines/wheels/prop valve anyway. Flare wrenches are nice.
    Jake92[OP] and YardBird like this.
  4. Jul 5, 2020 at 1:12 PM
    Jake92
    Thank you @prof
    thank you. I appreciate it. I’ll buy a set.
  5. Jul 6, 2020 at 3:20 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    You only need the flare wrenches for removing/installing the lines. Use a 6 point socket on the bleeders -- you'll get a better bite. But if you can afford it, it's never a bad idea to have a full set. They come in handy for working on A/C, power steering and transmission lines. When you don't have the full set, you tend to try to make due with an open end wrench... which can lead to a rounded fastener.
