Brake Light - 2011
Discussion in '2nd Gen Tundras (2007-2013)' started by Kbienk16, Feb 27, 2020.
  1. Feb 27, 2020 at 5:43 AM
    Kbienk16
    Kbienk16 [OP] New Member
    Kyle
    2011 Platium Tundra
    Other than the brake fluid being low or the parking brake is engaged, what are the other causes for the dash brake light to be on?
    I recently did a 2 inch lift (leveling kit) to the front and the light turned on unexpectedly. All brake functions feel normal; pedal, stopping ability, etc.
  2. Feb 27, 2020 at 5:55 AM
    A leveling kit wont cause it to come on. Try setting and releasing the parking brake and see if it goes out.
  3. Feb 27, 2020 at 6:10 AM
    Kbienk16
    Kyle
    2011 Platium Tundra
    Yes, tried that several times. No success
  4. Feb 27, 2020 at 6:18 AM
    Maybe disconnect the battery for a few minutes?
  5. Feb 27, 2020 at 12:44 PM
    Kbienk16
    Kyle
    2011 Platium Tundra
    Thanks, I just pulled the terminals and put them back on and it did the trick.
  6. Feb 27, 2020 at 2:21 PM
    TheBeast The Beach
    read the codes next time it comes up.
  7. Feb 27, 2020 at 6:18 PM
    :thumbsup: Hopefully it doesn't come back.
  8. Feb 28, 2020 at 11:11 AM
    RCdadfor2
    RCdadfor2 New Member
    Jeff
    2008 Tundra DC
    none yet
    Sometimes the sensor in the brake fluid reservoir goes bad need to change the reservoir. not hard to do and can be done with out bleeding the system. the other thing could be the brake switch on the actual brake pedal. on my previous truck i replace the switch first because cheap and easy. but ended up being the sensor so i changing the reservoir and it was fixed.
    It started intermittently coming on once a month or so and would reset every time I shut the truck off, towards the end it would come on right away as the sensor got worse.
  9. Mar 1, 2020 at 12:08 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Happens to me all the time, I push the pedal up from the bottom of the pedal and it goes away. I sometimes do this repeatedly after first starting it and within 3-4 blocks after leaving my home.
