Brake help
Discussion in '2nd Gen Tundras (2007-2013)' started by TundayFunday, Jul 18, 2023.
  1. Jul 18, 2023 at 12:25 AM
    TundayFunday
    TundayFunday [OP] New Member
    2007 Tundra SR5 5.7
    Anyone experience the dash vibrating heavily from braking at high speeds? I’m thinking rotors. It’s not really my steering wheel that shakes though. Heavy middle dash vibration. Not like the dash is loose though.
  2. Jul 18, 2023 at 1:31 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I'm sure you know Tundras are notorious for warping rotors... Very high likelihood this is the source of the problem, however it's not absolute.
    I don't recall seeing approximate current mileage in your post... and since it's an '07, I'd strongly encourage a thorough inspection of the front components; w/particular attention to wheel bearings, lower ball joints, and the rack.
    If you're not going to be the one doing the inspection, I'd make sure it's being looked at by someone you trust that is extremely thorough. It takes a little bit of time to be done right and should not be done by the average lube tech. If you don't have someone you trust, consider adding a request for recommendations to your post for your specific area; good off-road shops usually know what to look for as well and can be a good resource.
  3. Jul 18, 2023 at 6:01 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I would second warped brake rotors. Not sure about anyone else, but my OEM ones lasted to 217k, just hot pad swap. I don't brake much nor ride the brakes; I do enjoy coasting as well as enraging whoever is following close behind me... I replaced my original ones with OEM ones which lasted 1 year, a trip through Santa Cruz mountains did them in. After that I went with Stop Tech slotted Cryo treated rotors all around to prevent warping. I want to say I'm about 3 years into them, maybe a little more, so far I'm happy with them. I'm having issue with my front calipers and need to be replaced. I'm at 280k+ sor far.
    TundayFunday[OP] likes this.
  4. Jul 18, 2023 at 7:41 PM
    TundayFunday
    2007 Tundra SR5 5.7
    Thanks y’all
  5. Jul 18, 2023 at 8:39 PM
    CTB Mike
    CTB Mike It's RED? My rods and cones must be screwed up!
    Southern Arizona
    2011 Red Rock Warrior
    Your problem may not be warped rotors, but you may have hot spots. These are generally visible in the center of the rotor since this is where the the heat is greatest. The difference in the fix is that warped rotors may be able to be turned (machined on a lathe) whereas turning rotors with hot spots will not be successful as the hot spots will quickly return. I speak from experience, since I was a longtime brake mechanic in a prior life. Your best fix will be new good quality rotors and pads. What kind of driving do you mostly do? I installed a Powerstop Z36 kit all around because I tow my travel trailer a lot, and I am very satisfied with the performance even when I'm not towing.
  6. Jul 19, 2023 at 4:51 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    And don’t forget to bed in the new pads to the rotors when you’re done
