Brake Controller Installation
Discussion in 'Towing & Hauling' started by hikerdonovan, Apr 7, 2017.
  1. Apr 7, 2017 at 4:32 AM
    hikerdonovan
    hikerdonovan [OP] New Member
    Silver 2015
    P3 Brake Controller
    I just finished installing a brake controller on my 2015 1794. It was simple, but since the instructions were not specific to any vehicle, this post might be helpful if you are about to install a controller.
    I bought a Tekonsha P3 and I also bought a wiring harness from etrailer. They shipped both to me via 2 day UPS for just 8.29 so all in I paid 152.43.
    I don't especially care for the shiny cheap screws. It would be sharper if it came with black panhead screws so it blended in better. But I leave tomorrow with a trailer and am glad I was able to get it up and running.
    This part of the dash just pops out and it's a whole lot easier than unbolting the whole dash.
    I decided this was the most practical place to put the controller.
    The most challenging part was figuring out how to tighten this screw.
    All Done! Took about an hour.
  2. Apr 7, 2017 at 11:49 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
  3. Apr 7, 2017 at 12:48 PM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    Just bought this same setup. ESP component should be here tomorrow.
  4. Apr 14, 2017 at 10:16 PM
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    Would love to see pictures of the ESP after install!
  5. Apr 15, 2017 at 2:40 AM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    Check Tundra's live, I have an installed picture there. Might have to jump back a few pages.
  6. Apr 15, 2017 at 7:51 AM
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    So I pulled my TT for the first time with my 17 CM. I have my P3 left over from my 13 CM.
    Should I be able to just plug and play and instead of a mounting am.i able to lay it on my console and remove when not in use?
    Thanks.
  7. Apr 15, 2017 at 11:47 AM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    I'm not one 100% sure what your asking here but the P3 can be disconnected and removed at the controller if you just screw the mount into the lower dash. I do know that the P3 controller needs to be mounted in the direction of travel as it has an internal inertia sensor. Hope this helps.
  8. Apr 15, 2017 at 2:23 PM
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    I did not want to secure it to the truck. I want to disconnect the factory controller, plug in mine and when not towing unplug and take out. Then when using the P3 just lay it flat on the middle of the dash. Also, will it plug right in where the factory controller connects? I hope this makes more sense.
    Thanks.
  9. Apr 16, 2017 at 4:46 AM
    hikerdonovan
    Silver 2015
    P3 Brake Controller
  10. Apr 16, 2017 at 4:55 AM
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    Thanks.
    It looks like I could lay it on my dash as long as it stays still and flat.
    Now, will it plug right up where the factory controller connects using the same plug from a 13?
  11. Apr 16, 2017 at 5:39 AM
    hikerdonovan
    Silver 2015
    P3 Brake Controller
    I think it must be mounted because when you hit the brakes the internal sensor adjusts the trailer brakes accordingly. If you had to stop hard and the controller where to slide forward, you may end up without brakes on the trailer, or perhaps they could be applied with too much force. It has the potential if your load where heavy enough and you were in a turn to get you in real trouble.
    If you have ever had the helpless feeling of nearly rolling over or sliding on ice, you know what it will feel like if the brake controller is not operating properly. I wouldn't redneck this thing but instead would make sure it is setup exactly the way it is supposed to be.
    The P3 is billed as being perfect for your situation in that you can program it for multiple vehicles. You just need a mount and wiring harness for each vehicle.
    Sorry, I can't speak to the compatibility with your existing harness. I would call or go online to etrailer and find out if the same harness they sell works on both the 13 and the 17. If it requires 2 different harnesses then you know it won't work...just my guess though so take that with a grain of salt.
    Surely the aftermarket brake controller and the Toyota plug utilize the same plug...
  12. Apr 16, 2017 at 7:44 AM
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    Thanks for the detailed information. I did check online and the wiring harness isn't compatible.
    I will try working with my factory controller a little more.
    NewImprovedRon likes this.
  13. Apr 16, 2017 at 7:56 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
  14. Apr 16, 2017 at 8:40 PM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    The controller works good, tow a 30' 9200lb trailer for my church and I don't get pushed to hard when stopping. I'm still fine tuning the settings.
  15. Apr 18, 2017 at 2:04 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Boom
  16. May 14, 2017 at 2:12 AM
    Gman
    Gman New Member
    Toyota tundra crewmax
    What keeps it in place and not fall out could you show a picture of the back.
  17. May 14, 2017 at 6:43 PM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    It's a very tight fit and the mounting screws on the controller keep it secure. It's a permanent mount.
