Brake controller affecting rpm
Discussion in 'General Tundra Discussion' started by 9am53, Jan 1, 2021.
  1. Jan 1, 2021 at 11:05 AM
    9am53
    9am53 [OP] New Member
    adam
    2015 Black RCLB 4x4
    2020 PRO headlights and grill
    Hey guys. I noticed this morning that when I’m cruising in my truck and I squeeze the brake controller button I can feel my truck doing something and my rpm goes up slightly (like 100 or 200). I don’t know if this is normal and what exactly is happening. For context I have a 2015 rclb 5.7L 4wd, I was not towing this morning ( squeezed it just because and noticed my truck reacting to the button squeeze) and I have a tekonsha unit wired into the trucks plug behind the dash. Any advice?
  2. Jan 1, 2021 at 11:08 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Pulls more power from the Alternator?? best I could think of that can impact RPM
  3. Jan 1, 2021 at 11:12 AM
    9am53
    adam
    2015 Black RCLB 4x4
    I considered that but since I don’t have a trailer plugged in the circuit is open and not drawing anything. Does the brake controller gently apply my trucks brakes too?
  4. Jan 1, 2021 at 11:16 AM
    blackdemon_tt
    umm no, the controller needs power from something, unless you got it using the force or batteries, the only place it could draw power from is the battery or the alternator... its impacting your rpm then controller draws power from the alternator raising your rpms.... Idk, if I'm breaking it down, or I'm beating around the bush, lol... its normal since the alternator has to make more power for the controller..
  5. Jan 1, 2021 at 11:28 AM
    9am53
    adam
    2015 Black RCLB 4x4
    So your truck does this too?
  6. Jan 1, 2021 at 11:34 AM
    blackdemon_tt
    no, I don't have a brake controller, but just like power steering and AC, when you turn the steering wheel the rpm will rise and fall like turning on and off the AC engine load output increases and decreases as needed.
  7. Jan 1, 2021 at 11:38 AM
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
    Never noticed a RPM change. I’ll try it today
  8. Jan 1, 2021 at 11:45 AM
    Vizsla
    Vizsla 2 = 2.5
    Activating the brake controller should light up the brake lights. Truck sees brake applied and unlocks the torque converter :notsure:
    landphil likes this.
  9. Jan 1, 2021 at 11:56 AM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Brake controller extra rpm hidden mod/ Easter egg :D
    Leo's first and 9am53[OP] like this.
  10. Jan 1, 2021 at 12:20 PM
    9am53
    adam
    2015 Black RCLB 4x4
    SUPER beast mode...activate a double shot of brake controller!
    Dalandshark[QUOTED] likes this.
  11. Jan 1, 2021 at 12:27 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Yup!
    Hold the brake controller lever long enough without raising your right foot and the engine RPM will drop to idle too, thanks to the brake override programming.
  12. Jan 1, 2021 at 12:29 PM
    9am53
    adam
    2015 Black RCLB 4x4
    When I hit the button my rpm goes up...you’re saying it will eventually go down?
    so my truck is acting normally?
