Brake Control Error?
Discussion in '2.5 Gen Tundras (2014-2021)' started by TexMedic, Feb 1, 2023.
  1. Feb 1, 2023 at 7:36 AM
    TexMedic
    TexMedic [OP] I ask a lot of questions…
    2017 Dark Gray DC Tundra 4x4
    E7C2C228-BB2F-42E1-B38B-BFE8CA5C55B3.jpg I was out driving in the now ice, and got stuck. As I was trying to get out, I started to slide. Once I stopped, this screen popped up, along with every other light on my dash. I was in 2 wheel drive with traction control off.
    I’ve turned my truck off and then back on, and this screen still pops up. Any explanation?
  2. Feb 1, 2023 at 7:49 AM
    Notarobot
    Notarobot Jagged lines!
    2013 CM
    Check your brake sensors and wiring to them.
  3. Feb 8, 2023 at 8:41 PM
    Endothecosmic
    Endothecosmic New Member
    BLACK 2016 TUNDRA SR5
    RC 6 inch lift Air bags Opt 7 underglow Back cab utility panel
    Pull your wheel speed sensors and check for metal flakes. It could be a bad wheel bearing. You can stop by a shop that can read that type of code and find out what sensor is causing the issue for fairly cheap. Firestone charged me 10$. I have had this happen twice to my tundra and have now replaced both rear wheel bearings.
