Brake Booster Pump Assembly with Accumulator
Discussion in '1st Gen Tundras (2000-2006)' started by Sierracoco, Oct 1, 2024.
  1. Oct 1, 2024 at 9:10 AM
    Sierracoco
    Sierracoco [OP] New Member
    I own a 2004 Toyota Tundra SR5 double cab 4x4 with stability control. I noticed it doesn't have the large round brake booster. Instead, it has a brake booster pump assembly with accumulator. Can anyone advise how this works. I noticed my brake fluid was low after changing my brake fluid and bleeding all the brakes. Some website indicated fluid could be leaking into the booster. When I went to check the booster I noticed the afore mentioned set up. Thanks.
  2. Oct 1, 2024 at 10:22 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
  3. Oct 1, 2024 at 10:33 AM
  4. Oct 1, 2024 at 10:36 AM
    NickB_01TRD
    Nick
    KY
  5. Oct 1, 2024 at 10:43 AM
    If that's the case, I know very little about the setup, so I would encourage @Sierracoco to click HERE, then click the 'download' button to grab the FSM for his truck, and get reading.
    I know little to nothing about that setup and how to manage, but that '05-'06 FSM will probably help. I'm linking that because I don't think I've ever seen that VSC/AutoLSD setup in an access cab, and the 05-06 FSM has more info on double cabs.
    I want to say this is something I've seen @BubbaW give advice on in the past, but I dunno if he gets my tags these days. He was on here as recent as yesterday.
    NickB_01TRD[QUOTED] likes this.
  6. Oct 1, 2024 at 6:33 PM
    Sierracoco
    Thanks shifty that's the one in my truck. I wish it wasn't since it seems more complicated. I appreciate the link.
