Bought a Tundra, drove 500 miles home... and then
Discussion in 'New Member Introductions' started by GeoJoe, Jan 22, 2018.
  1. Jan 22, 2018 at 5:26 PM
    GeoJoe
    GeoJoe [OP] 2018 Tundra SR 4x4 5.7L Looooooooong Bed
    3/1 lift on 20" OZs with KOs, LED fogs, steps and a handle
    Hey Guys....
    I'm a new owner of a 2010 Tundra 4x4 CrewMax 5.7L with about 99k miles so far.
    I found a "great" deal in Tampa. Had some credit on Delta so flew down, looked her over and drove home back to Atlanta. Drove strong and straight all the way... 7hrs - 500miles!
    It's got a 3" lift, intake, wheels and some semi-style lights across the top (not a huge fan of those.. but whatever) Near the intake I see a couple of Transformer stickers, so I'm trying to determine what more has been done in that area.
    It seems I have some issues now that I've spent some quality time in my new ride.
    Simple stuff...
    • seat cushion on drivers side torn - $175 estimate from local upholstery shop.
    • fog light bulb out... figured I'd upgrade to LEDs or something better anyway
    • brakes seem squishy.. not as tight as I'd like, but pads seem to be new.
    Major stuff...
    • although my inspection showed no leaks, 500 miles later it seems I have a blown steering rack. Fluid all over passenger wheel well. Two estimates so far in the $2k range, and one mechanic that tells me to pour a bottle of Lucas ATF sealer in it.:eek:
    • now that I've seen multiple threads on rust, I'm wondering how much I have, and should I be concerned. Some rust under bed cover and light stuff underneath (I hope)
    Here's my first pic... glad to have a new addition and looking forward to any advice you guys have.
    Casper3, Areith762, Les7311 and 5 others like this.
  2. Jan 22, 2018 at 5:31 PM
    Welcome from CO. @csuviper has info on replacement steering rack. Get some decent seat covers. Surface rust is not a big issue either. Just make sure its surface rust. Easy to treat.
    Law323 and rons23 like this.
  3. Jan 22, 2018 at 5:32 PM
    Oh. . I forgot...white is the fastest color.
  4. Jan 22, 2018 at 5:34 PM
    GeoJoe
    :mudding::mudding::mudding:
  5. Jan 22, 2018 at 5:39 PM
    jstrenn
    jstrenn New Member
    2017 Toyota Tundra Double Cab 4X4 TRD Off Road
  6. Jan 22, 2018 at 5:40 PM
    GeoJoe
  7. Jan 22, 2018 at 5:43 PM
    jstrenn
    jstrenn New Member
    Worst case senario... You end up changing out your steering rack! I never had any issues using it. My son even used it on his Honda Civic and fixed his leak too. That was about a year ago.
    15whtrd likes this.
  8. Jan 22, 2018 at 5:46 PM
    GeoJoe
    Good point... I was wondering about the pump. I've seen one post that mentioned the thick consistency might make the pump work harder.
  9. Jan 22, 2018 at 5:56 PM
    Frkypunk
    Frkypunk "If a man is to be a street sweeper"
    2010 Tundra limited...2015 highlander limited
    Seat cushion is always torn on drivers side....unless you play for the Harlem Globetrotters. Or have foot rail to help get in. I am just over 6’ tall and have to leap in mine(no lift)
  10. Jan 22, 2018 at 6:02 PM
    Welcome from Texas! Love the cab lights!
  11. Jan 22, 2018 at 6:02 PM
    GeoJoe
    Need to add rails. Once I get these issues worked out... that's the first mod. I'm open to suggestions on those too!
    Glad to see you're a fan! Growing on me I guess...wondering about potential leaks.
  12. Jan 22, 2018 at 6:05 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Welcome from Obx
  13. Jan 22, 2018 at 6:10 PM
    Frkypunk
    I bought some online they are built well easy to install...and now my short wife and kids can get in.7428CCB9-DCE8-452C-950A-A13AC491FC72.jpg They were about 250 bucks...well worth it.
    Black Wolf, PBH, blue16 and 1 other person like this.
  14. Jan 22, 2018 at 6:10 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  15. Jan 22, 2018 at 6:17 PM
    GeoJoe
    Black Wolf likes this.
  16. Jan 22, 2018 at 6:19 PM
    csuviper
    Broomfield, CO
    Huge money saver on the parts for sure. Unfortunately the labor is expensive
  17. Jan 22, 2018 at 6:23 PM
    GeoJoe
    Nice option!
  18. Jan 22, 2018 at 6:24 PM
    Welcome from Ohio!
  19. Jan 22, 2018 at 6:27 PM
    Frkypunk
    Probably looks better on a lifted truck. Mine is used for hauling...so it will stay stock.
    Les7311 and Black Wolf like this.
  20. Jan 22, 2018 at 6:36 PM
    Why in Hell has no one suggested to convert the OP's trucker convoy lights to brighter LEDs??? I kind like the look. They are already there... .
  21. Jan 22, 2018 at 6:47 PM
    plrod
    plrod New Member
    18 DC LTD 4WD
    I just put those on my truck and find that they are helpful for getting in but kinda difficult when exiting the truck. It's not high on my list right now but if I come across another set of oem boards I like I'll probably change them out.
  22. Jan 22, 2018 at 6:50 PM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    Welcome... Silly question... Are you 100% sure it's the rack? I had a CV boot with a tiny tear in it and it covered the wheel well. Much cheaper to repair
  23. Jan 22, 2018 at 6:53 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
  24. Jan 22, 2018 at 7:05 PM
    GeoJoe
    I sure hope it's this... getting it checked out soon and then I'll know.
    Thanks!
    I'll keep that under consideration...good point.
    Thanks again!
    TXMiamiFan[QUOTED] likes this.
  25. Jan 22, 2018 at 7:10 PM
    Welcome from CO. Post up photos of any questionable rust so we can help determine if it’s surface. Humidity in FL, as you know can begin rust. That being said, if it’s small- may just scrape off and then get the undercarriage treated with fluid film.
    TXMiamiFan likes this.
  26. Jan 22, 2018 at 7:12 PM
    GeoJoe
    Great idea! I'd like to swap as many bulbs as possible to LED.
    Will do...
  27. Jan 22, 2018 at 7:14 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome from Ca.
  28. Jan 22, 2018 at 7:15 PM
    plrod
    plrod New Member
    18 DC LTD 4WD
    btw I like the running lights just the way they are, the light color matches the parking and mirror lights. while it's not something I would add - since they're already there, I'd let them be.
  29. Jan 22, 2018 at 7:20 PM
    Steve6
    Steve6 New Member
    Tucson
    Welcome from Arizona.
  30. Jan 22, 2018 at 7:52 PM
    Areith762
    Areith762 Go Avs!!!
    39.944182, -104.760113
    2017 Blazing Blue 5.7L CM SR5 4X4
    DAP Tune, Katskin interior leather, ESP rear under seat storage, door sill protector, door edge protector, TRD Pro shift knob, heated seats, all weather Tundra floor mats, driver side a-frame handle, Tundra trucks center console emblem, clear bra protection, Bushwacker fender flares, paint match front bumper caps, paint match rear bumper caps, paint match mirror caps, ProComp 3/1 lift, 20" Fuel wheels, 33-11.50/R20 Falcon tires, black TRD Pro badge's, black Tundra tailgate badge insert, TRD Pro headlights, Recon smoked tail lights, Recon smoked 3rd brake light, Roll N Lock tonneau cover, Line-X bed liner, Tundra bed mat, Cobra led remote alarm/remote start, N-fab tube steps, factory match window tint, TRD Pro grille -paint matched, paint matched hood bulge, TRD dual exhaust, Black out exhaust tips, led interior lights, led plate lights, Spyder smoked fog lights, TRD Cold Air Intake
    Welcome from CO!
