Bottom Door Seals
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by freerider8, Mar 23, 2023.
  1. Mar 23, 2023 at 8:49 AM
    freerider8
    freerider8 [OP] Trucks Rule
    Fairview PA
    2014 Tundra, Lift Kit aftermarket wheels and tires. One Badass Toy!!
    Fuel Wheels. Lift Kit. Duel Exhaust.
    So I am needing to replace my bottom door seals on my 2014 Tundra Double Cab. Trying to find some reasonable factory replacements without going OEM if I can. They are easy enough to replace since they just snap in with the plastic clips. The issue is trying to find them online to be able to purchase some. Anyone buy these before and where at?
    Thanks
  2. Mar 23, 2023 at 9:30 AM
    Tundra234 Mods, mods, and more mods
    Maybe RockAuto carries them. :notsure: On Sparksparts I see the CrewMax seals that are about $35 each. You would have to search foe the DC.
  3. Mar 23, 2023 at 10:05 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Do the oem ones cost an arm and a leg or something?
    freerider8[OP] likes this.
  4. Mar 24, 2023 at 8:23 AM
    freerider8
    Fairview PA
    I did find something that I think is the seals I need on a toyota parts website for OEM parts. I am not sure if what I found is the correct part exactly, but I am going to check with the local dealership on the part number and see if it is correct. The price for them weren't terrible at around 35 each. I expected much more than that from them. If I can confirm the part number then I may be able to find them for less from another source. I will post what I find later.
    MadMaxCanon likes this.
