Bottle jack?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Walther1978, Jan 23, 2020.
  1. Jan 23, 2020 at 8:21 AM
    Walther1978
    Walther1978 [OP] New Member
    2019 Tundra TRD DC
    I kept a 3 ton floor jack in my old Tahoe as I tow a trailer and boat fairly often and didn't want to deal with using the OEM jack if something were to happen.
    With my 2019 Tundra DC I have the underseat rear storage and want to throw a bottle jack in there. My question is how much lift do I need to get the front and rear tires off the ground in an event of a flat? Is it safe to lift under the rear diff? Not worried about the boat or trailer as the axles sit low to the ground. Does anyone carry a bottle jack, if so what kind?
    Harbor freight sells a 4 ton for under $20 that has a 15in max height and weighs 7lbs
    Northern tool sells a 8 ton for under $30 that will reach 17in and weights 14lbs.
    If I can get by with the 4 ton's height I'd prefer to do so.
  2. Jan 23, 2020 at 8:34 AM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    Don’t look just at max height, look at total amount of lift. A block of wood can increase max height, but can’t do anything to increase the amount of lift a jack provides.
    Pinay and NewImprovedRon like this.
  3. Jan 23, 2020 at 8:37 AM
    Walther1978
    2019 Tundra TRD DC
    4 tons is plenty of lift. I thought about throwing in a 4x4x12 piece of wood to go along with the jack for underseat storage.
  4. Jan 23, 2020 at 9:50 AM
    daw5spd
    daw5spd New Member
    Dave
    Eastern Oregon (Greater Idaho)
    2019 Cement Off Road DC
    Undercover SE tonneau TRD Rear Sway Bar AJT trim pieces Console wireless charger Drivers side grab handle Meso lights
    Look closely at any you buy, the cheaper ones have a tendency to leak fluid.
    NewImprovedRon likes this.
  5. Jan 23, 2020 at 11:02 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    The "lift" @DividedSky is talking about is the jack travel from fully collapsed to fully extended. For most bottle jacks, that may be 4+". Bottle jacks often have a threaded ram that can be height adjusted, but that will provide no help with the overall lift or jack travel.
    In some cases, too much bottle jack height can be a disadvantage. For example, the jack probably needs to be short enough to get under LCA, steering knuckle, or other suspension components. From that perspective, the low profile of a floor jack is a definite advantage over a bottle jack. If the jack is placed safely under the suspension, the travel of the jack goes completely into getting the wheel off the ground. A bottle jack short enough to get under the suspension will work. If any jack is placed under the frame, then most of the jack travel will be used simply stretching out the suspension before the wheel is lifted. Depending on the vehicle, and the jack, a bottle jack placed on the frame may not have enough lift or travel to get the wheel off the ground,.
  6. Jan 23, 2020 at 11:03 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Safety 1st or 3rd? Might wanna consider a jack stand or two also...perhaps already did....
  7. Jan 23, 2020 at 11:26 AM
  8. Jan 23, 2020 at 11:34 AM
    excavator78
    excavator78 New Member
    2015Tundra CM Limited
    DAP Tuned
    You can raise your whole world with this:
    https://safejacks.com/collections/frontpage/products/12-ton-rv-jack-kit
    Overkill, yes but I understand having a quality tool when you need one. Not all will need something of this level (myself 95% of the time) but if it saves your ass one time it is worth every penny. I wouldn’t trust it over a jack stand though.
  9. Jan 23, 2020 at 11:49 AM
    Johnsonman
    Austin
    Sequoia
    That is exactly what I went with because after a 1.5" body lift, the OEM bottle jack wouldn't lift high enough anymore, besides it's obvious lack of safety in any situation other than level concrete.
    Forgot to add, then I place a 2x that is wider and longer for added stability and height range....
    Thanks for posting.
  10. Jan 24, 2020 at 3:16 AM
    Paulismydog
    Paulismydog New Member
    2020 Black Limited Double Cab
  11. Jan 24, 2020 at 4:48 AM
    Vizsla
    Vizsla 2 = 2.5
  12. Jan 24, 2020 at 5:09 AM
    Rebel Tundra Man
    Rebel Tundra Man New Member
    Tyler
    Western Kentucky
    2016 Black Limited CM
    4" RCX Lift, 20x10 Fuel Coupler's, 35x12.50x20 Nitto Ridge Grappler's, Color Match Front End, LED Bulbs, RCX Tube Steps, Green LED Underglow
    I have the 4 ton bottle jack from harbor freight under my seat and I keep a 6x6 about 10" long in the bed all the time too. haven't had to use it yet though, I do like the bottle jack / jack stand combo thing though.
  13. Jan 24, 2020 at 6:56 AM
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
    Got this a couple of years ago. Used it to lift my TT but haven’t had to lift the truck yet. Like the wide base and locking jack stand. F8C1711F-848E-4C49-9631-D49A09C5B2FE.jpg
    porkitt likes this.
  14. Jan 24, 2020 at 7:22 AM
    That's the one that I posted LOL. I'm thinking about getting one myself. They seem to be liked by others.
    TacomaLC likes this.
