Boost Auto Tow Mirrors
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2020Platinum, Apr 11, 2021.
  1. Sep 2, 2022 at 7:41 PM
    #181
    SFTundra
    SFTundra New Member
    Jimmy
    thanks @RobertD, that helps a lot :)
    RobertD[QUOTED] likes this.
  2. Sep 2, 2022 at 10:00 PM
    #182
    SFTundra
    SFTundra New Member
    Jimmy
    Did anyone purchase the black version? I curious what’s the black one compared to paintable version? I’m assuming the paintable one is primed. If I end up getting the black version, that should also technically be paintable too right? Or does that have a rough grit to it and would need to be prepped prior to painting it?
  3. Sep 2, 2022 at 11:00 PM
    #183
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Paintable caps are smooth plastic (not primed). I presume the black with be mildly textured.
    For like $50 or so, they sell replacement caps so you can get painted ones later
    SFTundra[QUOTED] likes this.
  4. Sep 2, 2022 at 11:07 PM
    #184
    SFTundra
    SFTundra New Member
    Jimmy
    thanks , maybe I’ll just get black and also replacement paintable as spare Incase I want to paint it in the future
  5. Sep 23, 2022 at 5:46 PM
    #185
    someguyinhtx
    someguyinhtx 2018 Lifted 4x4 CM
    Lifted 2018 Black 4x4 SR5 Crewmax
    6" Pro comp lift
    black mirrors
    mav7021234 and Cpl_Punishment like this.
  6. Oct 1, 2022 at 1:56 PM
    #186
    Tundrasfkjr
    Tundrasfkjr New Member
    2020 Tundra TRD SR5 4x4
    Where is the circuit breaker located? Boost Auto sent me a replacement due to passenger side mirror stopped power folding. Thanks!
  7. Oct 1, 2022 at 2:01 PM
    #187
    someguyinhtx
    6" Pro comp lift
    It’s tucked INSIDE the mirror assembly.
    Tundrasfkjr[QUOTED] likes this.
  8. Oct 1, 2022 at 2:16 PM
    #188
    Tundrasfkjr
    Thank you sir! Hopefully this fixes the problem. I already replaced the switch and it was still not folding...:(
  9. Oct 1, 2022 at 2:20 PM
    #189
    someguyinhtx
    6" Pro comp lift
    It should fix it. I was skeptical too.
  10. Nov 19, 2022 at 5:51 PM
    #190
    someguyinhtx
    6" Pro comp lift
    Assume this worked?
  11. Mar 21, 2023 at 7:15 PM
    #191
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Just received a set of Boost Auto tow mirrors and so far not happy. Right out of the box the top corner tip of the big triangle outside mount section was broken off. I don’t really have time to wait for a replacement so I figured I’d glue it back on at some point and call it good. Install of the mirror assembly was easy enough, but that joke of a styrofoam gasket they provide is basically pointless. I reused the factory gasket, fits fine. Then during the wiring install we brought the DIY power folding harness through the door jambs and up to the mirrors and… no plug. Probably should have noticed this when I was installing the mirrors but I wasn’t really thinking about the wiring at that point. I pulled the mirrors back off thinking I just missed it and nope… figured out they wired the power fold wires into the factory harness, as if I had factory power folding mirrors. I even checked my order to make sure it wasn’t my mistake… it wasn’t, plus they provided the wiring harness so they should have put two and two together before shipping them out. Luckily there was a plug in between the motor and harness, so easy enough to unplug and pull it through and reinstall the mirrors, but doesn’t give much confidence that everything else is wired correctly. Then when we went to install the fuse tap and test for power I got nothing. Pulled the fuse tap and found a crumbled broken fuse was installed in the fuse tap. I had to get a new fuse anyways since the factory fuses don’t fit, so luckily I had a spare, but dang, they didn’t notice the fuse breaking when smashing it in there? I haven’t figured out how I want to wire/activate the spot lights yet, but I’m just hoping they actually work once I get to that point. They’re nice mirrors with cool features, but for 10 Benjamins I expected a lot more quality control.
  12. Mar 21, 2023 at 7:30 PM
    #192
    RobertD
    Robert
    DFW, Texas
    Damn that sucks. Reach out to Boost and provide picture of all your issues. They have been pretty quick to respond when I've reached out. Hopefully they resolve all your issues to your satisfaction.
    Cpl_Punishment likes this.
  13. Mar 21, 2023 at 10:38 PM
    #193
    OnespeedTRD
    Don
    San Diego
    Yeah, I took pics and emailed them but it was after they closed. Hopefully I hear back from them tomorrow.
    Good news is I got them installed and everything seems to be working fine. One thing I noticed is the passenger side folds and unfolds much quicker than the driver side. Not a big deal, just something I noticed. I also tried to wire the flood lights to the footwell light so they would come on as you approach the truck, or when you hit the unlock button, but apparently that’s a constant hot so they turned on but didn’t turn off when you lock the truck. Ran them to the reverse for now but I’d really rather have them as courtesy lights than reverse lights. If anyone knows what wire to tap to do that I’d appreciate the tip.
  14. Mar 22, 2023 at 6:05 AM
    #194
    RainMan_PNW
    Casey
    Clark County, WA
    The angles of the mirrors are different (same goes for stock mirrors) because of the positioning of the driver. The passenger mirror has less distance to travel to fold than the driver’s side does, so it takes less time.
    Tonkatoytaco likes this.
  15. Mar 22, 2023 at 3:29 PM
    #195
    OnespeedTRD
    Don
    San Diego
    Makes sense, thanks for the info.
  16. Mar 22, 2023 at 3:35 PM
    #196
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    My OEM mirrors fold completely in sync, but my BAP mirrors definitely do not. I’m running my OEM ones now but will reinstall my tow mirrors soon.
  17. Mar 22, 2023 at 3:39 PM
    #197
    OnespeedTRD
    Don
    San Diego
    UPDATE: I heard back from Boost Auto and they took all the concerns and assured me that they'd address them with their production and QC teams. They came up with a solution to make it right, so at least they are responsive and stand behind their products.
    The only other minor gripe is the provided switch is the old tall size found in the Gen 1 trucks. Has anyone been able to swap it out with a smaller size switch with any success? Seems like a simple swap, but I'm not super savvy on how those switches work.
    RobertD and JDR76 like this.
  18. Mar 22, 2023 at 3:48 PM
    #198
    OnespeedTRD
    Don
    San Diego
    I tried to run them to the footwell light but only grabbed the positive wire. The lights came on but stayed on. Are you saying if I were to tap into both wires, then connect the single wires from each mirror they would turn on/off with the footwell light? Or would I have to run a separate ground wire from the mirror down to the footwell light and tap into positive and ground separately?
  19. Mar 22, 2023 at 6:58 PM
    #199
    RainMan_PNW
    Casey
    Clark County, WA
    Correct.
    You would need to disassemble the mirror and isolate the ground for the “reverse flood” lights and run that isolated ground down to catch the footwell light ground in addition to the positive wire.
    Many circuits in these trucks are “switched ground” controlled - they have a constant hot and then the ground leg of the circuit routes through the ECU or switch to control function.
    The factory standard size mirrors, yes. The passenger mirror is “fish eyed” and so the geometry of the two mirror housings is symmetrical and the angle of the driver’s line of sight is compensated for within the housing and with the glass distortion. The tow mirrors are not that way, so the angle of the housing relative to the centerline of the truck is changed to provide the correct view.
    RobertD likes this.
  20. Mar 22, 2023 at 8:40 PM
    #200
    OnespeedTRD
    Don
    San Diego
    Hmm, running a separate ground wire is too much work for now. Maybe at some point I'll run a separate switch that's not off a constant hot and has its own ground. I'll just run them off the reverse for now.
  21. May 23, 2024 at 6:30 AM
    #201
    Avi8or
    Avi8or New Member
    Johann
    MO
    2020 Limited Crewmax
    Does everyone with the power fold option find the folding mechanism to be reliable? I would need to fold them nearly daily when pulling into the garage. Wondering how long these are expected to last.
  22. May 23, 2024 at 6:38 AM
    #202
    RobertD
    Robert
    DFW, Texas
    I've had mine on for 1.5 years. They fold well. I definitely fold them in more then I thought I would but that is why I went power fold so I'd only have to hit a button. Like this past Friday I ended up in a parking garage thats entrance felt tight, so the mirrors were folded in, once thru the entrance barriers that were tight i opened the mirrors back out, and then I folded them in once I parked.
    Avi8or[QUOTED] and texasrho83 like this.
  23. May 23, 2024 at 7:18 AM
    #203
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah mine fold a lot with the auto fold mod I did c/o @RainMan_PNW
    Avi8or and RobertD[QUOTED] like this.
  24. May 23, 2024 at 11:08 AM
    #204
    JDR76
    JDR76 New Member
    WA
    I fold mine daily, as I always fold them when I park at work. Often at the grocery store and out on errands as well. No issues thus far.
    Avi8or[QUOTED] and RobertD like this.
  25. May 23, 2024 at 11:18 AM
    #205
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    I just ordered power fold with my truck not currently having power fold. Same thought process as above; I’ll probably have to fold them a lot since they’ll stick out more, and just hitting a button will help.
    Hope install is fairly straightforward. Need to find someone in the Nashville area to paint my paintable caps.
    RobertD likes this.
  26. May 23, 2024 at 11:22 AM
    #206
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Check out Casey's build thread for excellent info on putting them in.
    Terndrerrr[QUOTED] likes this.
  27. May 23, 2024 at 11:48 AM
    #207
    RobertD
    Robert
    DFW, Texas
    I painted mine in my garage, they are small enough you can easily do them with aerosol cans.
  28. May 23, 2024 at 12:06 PM
    #208
    Terndrerrr
    Music City
    6UR-FE
    Definitely. I consult the Rainman often.
    Yeah I guess I never thought of that. What brand of paint did you use, and was it a good match?
  29. May 23, 2024 at 12:15 PM
    #209
    RobertD
    Robert
    DFW, Texas
    @Terndrerrr I have a local automotive paint shop i use and they can mix, but I've also found DupliColor has a blue that matches my truck extremely closely. My mirror caps are finished with the Duplicolor aerosol cans, with the mirrors being separated from the truck you won't notice if they are slightly off. Unlike the front end stuff that butts right up to the rest of the truck.
    Big thing. Ensure you use a 2k clear, the mirror caps take a lot of bug impacts and rocks. So far I don't have any chips or damage to my mirror caps.
  30. Jun 13, 2024 at 6:38 PM
    #210
    ASUNC
    ASUNC New Member
    I just finished installing the Boost mirrors in my 2021 Limited, adding power fold and wanted to thank all the posters for the great tips. The Amazon switch upgrade worked perfectly, once I figured out removing and reinserting the pins in the connectors.
    Thanks
