Boost Auto Tow Mirrors
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2020Platinum, Apr 11, 2021.
  1. Aug 6, 2022 at 10:24 AM
    #151
    someguyinhtx
    someguyinhtx 2018 Lifted 4x4 CM
    Lifted 2018 Black 4x4 SR5 Crewmax
    6" Pro comp lift
    UPDATE for my non-folding driver's side. I sent Boost the video of the mirror struggling to close. They said they were confident it was the circuit breaker and sent a replacement.
    I pulled it off today and swapped the circuit breaker and it works fine now.
  2. Aug 6, 2022 at 10:25 AM
    #152
    someguyinhtx
    6" Pro comp lift
    Does the OEM one have backlighting, or no?
    Something like this:
    https://www.ebay.com/itm/1835698871...5idkM7gzS_UnuzCst1JNBZT383r_2RwQaAimoEALw_wcB
  3. Aug 6, 2022 at 2:00 PM
    #153
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    Install went well. Everything works except the right one won’t power fold. Double checked all wiring connections but I’ll check again.
    Cpl_Punishment likes this.
  4. Aug 6, 2022 at 3:08 PM
    #154
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You may have the same issue @someguyinhtx had
  5. Aug 6, 2022 at 6:59 PM
    #155
    JDR76
    JDR76 New Member
    WA
    Not sure if it means anything, but the power folded driver’s side mirror folds in a lot tighter than manually folding the passenger side mirror.
  6. Aug 6, 2022 at 7:26 PM
    #156
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Same.
    I reached out to Boost with pics and tape measurements lol. I was told it is normal. See below:
    JDR76[QUOTED] and RobertD like this.
  7. Aug 6, 2022 at 7:45 PM
    #157
    JDR76
    JDR76 New Member
    WA
    I’ll contact them on Monday. I’ve rechecked all of my connections and feel confident that I installed them correctly.
  8. Aug 6, 2022 at 8:44 PM
    #158
    someguyinhtx
    6" Pro comp lift
    I’ll bet you it’s a circuit breaker issue. See my posts a few above yours. They shipped me one out. Was about at 10 minute fix.
  9. Aug 6, 2022 at 10:09 PM
    #159
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
  10. Aug 6, 2022 at 10:12 PM
    #160
    RainMan_PNW
    Casey
    Clark County, WA
    Like Charles said, totally normal.
    Even the factory tow mirrors are that way - the angle (if looking down at the roof of the truck) of the mirrors is different to allow the driver's position to see out of them correctly.
  11. Aug 9, 2022 at 9:04 PM
    #161
    SFTundra
    SFTundra New Member
    Jimmy
    I had a question regarding the boost auto mirrors, I know the top section of mirror is power adjustable. How about the bottom section? is that manual only?
  12. Aug 9, 2022 at 9:05 PM
    #162
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Affirmative
  13. Aug 15, 2022 at 9:51 AM
    #163
    kaymonster
    kaymonster Member
    San Diego
    2018 Platinum
    Can confirm that these do not have true DRL, the LED strip only comes on when parking/headlights are on when installed as Boost recommends. Work around for me was to fuse tap into one of the Ignition slots, not the Tail Light fuse as they recommend. Now the LED strip is lit anytime the truck is on. The switchback blinker works just fine doing this as well.
    icodeintx, Henry1jg, Luckster and 3 others like this.
  14. Aug 15, 2022 at 10:20 AM
    #164
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Nice PSA :thumbsup:
  15. Aug 15, 2022 at 10:22 AM
    #165
    JDR76
    JDR76 New Member
    WA
    Working with Boost to get my issue resolved.
    I have a feeling that they sent me the wrong passenger side mirror. I think they sent me one that doesn't power fold. My driver's side mirror will ONLY fold via power - meaning I can't just grab it and fold it manually from the exterior of the truck. However, the passenger side mirror will not power fold, and instead will ONLY fold manually. I can easily grab it and push it to the folded in position.
    Can anyone else with the power fold option confirm that their mirrors cannot be manually folded in?
    Thanks.
    Jeff
  16. Aug 15, 2022 at 10:28 AM
    #166
    kaymonster
    kaymonster Member
    San Diego
    2018 Platinum
    Thanks. It wasn't crystal clear to me and I noticed several others seemed to be a little confused as well. Boost's website also kinda makes it confusing when they refer to them as "running lights". I called Boost and they confirmed no true DRL. I asked their thoughts on tapping into another slot, while they did say that is probably fine...they wouldn't go as far as recomending it as they have only validated the taillight slot (expected response).
  17. Aug 15, 2022 at 10:37 AM
    #167
    kaymonster
    kaymonster Member
    San Diego
    2018 Platinum
    My power fold mirrors can also be manually folded no problem.
    JDR76[QUOTED] likes this.
  18. Aug 15, 2022 at 10:39 AM
    #168
    JDR76
    JDR76 New Member
    WA
    Interesting. Thanks.
  19. Aug 15, 2022 at 1:19 PM
    #169
    JDR76
    JDR76 New Member
    WA
    Update:
    The great folks at BAP asked me today to remove the mirror and take a picture of the inside/mounting side of the mirror so they could verify that they shipped me the correct one. I removed the door panel, disconnected and unmounted the mirror, took the picture, then reassembled it. Luckily it works now! I am guessing the connector wasn't properly seated before and making a good connection, but it all seems perfect now. Yay!
  20. Aug 15, 2022 at 5:45 PM
    #170
    SFTundra
    SFTundra New Member
    Jimmy
    Thanks for the follow up. Can’t wait to order a set myself but waiting on a discount. These mirrors are like $1000 with all the add ons.
  21. Aug 15, 2022 at 6:26 PM
    #171
    RobertD
    Robert
    DFW, Texas
    They have been running sales during the major holidays. They range from about 10% off to 20% off for the Tundra mirrors. I'll post in this thread next time they email about a discount :thumbsup:
  22. Aug 15, 2022 at 6:56 PM
    #172
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Here's the full-priced damage with the configuration I went with
    If you're a vet they'll give you 5% off.
  23. Aug 15, 2022 at 9:13 PM
    #173
    JDR76
    JDR76 New Member
    WA
    They’re definitely spendy. I went with all of the options and they were over $1300.
  24. Aug 15, 2022 at 9:29 PM
    #174
    SFTundra
    SFTundra New Member
    Jimmy
    Oh wow, I guess I miscalculated it, $1400 is quite the cost for side mirrors but well worth it since I haven’t seen anyone regret the purchase. I’ll wait for the 20% off to knock off $200. How are you liking it so far.
  25. Aug 15, 2022 at 9:31 PM
    #175
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Best mirrors I've had thus far
  26. Aug 15, 2022 at 9:38 PM
    #176
    JDR76
    JDR76 New Member
    WA
    I’m still deciding. I miss the puddle lights and auto dimming. The running lights seem really bright at night, as do the reverse floods. They do vibrate more than my stock mirrors but it’s acceptable.
    These are the prices to pay though for a better view and in that, they deliver with fewer compromises than the competition.
    I think I just need more time with them.
    texasrho83, RobertD and SFTundra like this.
  27. Aug 16, 2022 at 6:17 AM
    #177
    RainMan_PNW
    Casey
    Clark County, WA
    That is how the truck is wired from the factory - if you install OEM tow mirrors they function the same way.
    kaymonster[QUOTED] likes this.
  28. Aug 16, 2022 at 6:20 AM
    #178
    RainMan_PNW
    Casey
    Clark County, WA
    Technically, you CAN manually fold them, but they resist pretty hard. The power fold mirrors have a safety mechanism that will still let them fold over manually if pushed hard enough to prevent from damaging the motor. This isn’t just in the boost mirrors - all of them will. But the resistance is significantly greater than a non-power fold mirror
    JDR76[QUOTED] and texasrho83 like this.
  29. Aug 16, 2022 at 6:43 AM
    #179
    JDR76
    JDR76 New Member
    WA
    Thanks. Once I got the mirrors functioning properly and cycled them with power, they both were no longer easy to fold, so I think all is as it should be now. I'm just so happy to have them working as they should!
  30. Sep 2, 2022 at 6:00 PM
    #180
    RobertD
    Robert
    DFW, Texas
    @SFTundra 20% of Boost products until 9/7 use code Laborday22
    texasrho83 and SFTundra like this.
