Boost Auto Tow Mirrors
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2020Platinum, Apr 11, 2021.
  1. Jul 31, 2022 at 7:02 PM
    #121
    someguyinhtx
    someguyinhtx 2018 Lifted 4x4 CM
    Lifted 2018 Black 4x4 SR5 Crewmax
    6" Pro comp lift
    Wasn’t even that tricky. I had a pinched wire somewhere in the door.
    I plugged old ones back in and confirmed both switches worked fine.
    Removed excess wires and re-ran the harnesses clean (no power for the fold - just ran the blue and yellows and they work now.
    …except for drivers won’t fold. It makes noisee and you can see it trying to fold and then gives up.
    Sent a note to boost to ship a replacement.
  2. Jul 31, 2022 at 7:08 PM
    #122
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Ah you originally had power folding mirrors....yeah you shouldn't have even had a harness with the Boost mirrors.
  3. Jul 31, 2022 at 8:12 PM
    #123
    someguyinhtx
    6" Pro comp lift
    No - I didn’t but the Amazon gen 2 switch can supply power, no?
    still can’t get drivers to work.
  4. Jul 31, 2022 at 9:13 PM
    #124
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Absolutely it can.
    It sure sounds like the mirror is bad.
  5. Aug 1, 2022 at 6:07 AM
    #125
    jfox
    jfox New Member
    Richmond VA
    2015 MGM Limited
    Thanks. I finally figured it out with some trial and error. Found using a sewing needle and having someone gently pull on the wire at the same time makes it much easier. Got them rigged up and they are awesome! Thanks to everyone on this thread for making it much easier than I expected.
  6. Aug 1, 2022 at 7:50 AM
    #126
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    The video install that I watched said that the mirrors come with the wrong fuse/wiring and that you have to buy a different one off Amazon (if I understood correctly). Is that the case? Mine should be arriving today and I want to get them installed before next week's camping trip. I'd hate to tear things apart then get stuck. Thanks!
  7. Aug 1, 2022 at 7:51 AM
    #127
    JDR76
    JDR76 New Member
    WA
    These look great. Now you're making me second guess my decision to not go the painted route. :D
    Henry1jg and NCTundra18[QUOTED] like this.
  8. Aug 1, 2022 at 7:52 AM
    #128
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    It isn't wrong per se, it's just universal. It also will not fit in an OEM Tundra switch opening unless you modify it
    JDR76[QUOTED] likes this.
  9. Aug 1, 2022 at 8:17 AM
    #129
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Mine came with all the wiring harnesses I needed but my truck came with manual fold mirrors and that's also what I ordered from Boost.
  10. Aug 1, 2022 at 8:31 AM
    #130
    JDR76
    JDR76 New Member
    WA
    Thanks guys. I have the OEM power folding option, and ordered power folding mirrors from Boost Auto. Hopefully I can figure it out without too much hassle and rework.
  11. Aug 1, 2022 at 8:37 AM
    #131
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You won't have a switch or harness in your kit.
  12. Aug 1, 2022 at 10:37 AM
    #132
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    Couldn't find a definitive answer in the thread. Do these have the dimming feature at night?
  13. Aug 1, 2022 at 10:47 AM
    #133
    RobertD
    Robert
    DFW, Texas
    No they do not.
    Cpl_Punishment likes this.
  14. Aug 1, 2022 at 2:43 PM
    #134
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    You can buy replacement caps off their website and get them painted...
    :boink: :spending:
  15. Aug 1, 2022 at 2:44 PM
    #135
    RainMan_PNW
    Casey
    Clark County, WA
    Since you have OEM power fold (and memory), you HAVE to order from them with the same options picked. Otherwise you'll have a bitch of a time getting it to work with your switch and setup.
  16. Aug 1, 2022 at 2:44 PM
    #136
    RainMan_PNW
    Casey
    Clark County, WA
    Nope.
    I've not found a tow mirror yet with EC dimming
  17. Aug 1, 2022 at 2:48 PM
    #137
    JDR76
    JDR76 New Member
    WA
    I should be fine then, as the mirrors I ordered had the same functions/options as my OEM ones (except dimming, of course).
    RainMan_PNW[QUOTED] likes this.
  18. Aug 1, 2022 at 3:09 PM
    #138
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Toyota OEM mirrors have a dimming feature?
  19. Aug 1, 2022 at 3:12 PM
    #139
    JDR76
    JDR76 New Member
    WA
    Yes, and I'm going to miss that feature, but at least my side windows are tinted, so that will help.
  20. Aug 1, 2022 at 3:16 PM
    #140
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Is this some sort of 1794 feature I'm too much of an SR5 peasant to understand?
  21. Aug 1, 2022 at 3:19 PM
    #141
    JDR76
    JDR76 New Member
    WA
    LOL...
    They're standard on the Platinum and the 1794:
    https://pressroom.toyota.com/vehicle/2021-toyota-tundra/
    :D
  22. Aug 1, 2022 at 3:22 PM
    #142
    JDR76
    JDR76 New Member
    WA
    Yeah, I opted for the chrome ones. Didn't want to deal with getting them painted, and I've deleted enough chrome off the truck that I don't mind a bit on the mirrors. The painted ones look good, though...
  23. Aug 1, 2022 at 3:24 PM
    #143
    RainMan_PNW
    Casey
    Clark County, WA
    1794 and Platinum mirrors tie into the EC circuit in the rear view mirror and will auto-dim.
  24. Aug 1, 2022 at 3:26 PM
    #144
    RainMan_PNW
    Casey
    Clark County, WA
    I did my 2008 myself - color matched mirror caps (I had the actual OEM tow mirrors), fog light housings, "unibrow" and tail gate latch.
    2 coats plastic adhesion promoter
    2 coats primer
    light wet sand
    2-3 coats duplicolor
    2 coats clear coat
    bulldog93, RobertD and JDR76[QUOTED] like this.
  25. Aug 4, 2022 at 6:59 AM
    #145
    someguyinhtx
    6" Pro comp lift
    Boost support says they suspect the circuit breaker inside the mirror and are shipping another one. Apparently it’s an easy swap.
    It randomly folded when turning truck on Tuesday and but only once. Was a glimmer into my soon to be double folding mirror future.
  26. Aug 4, 2022 at 7:00 AM
    #146
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You'll be in heaven. Do you plan to do the auto fold mod?
  27. Aug 4, 2022 at 7:02 AM
    #147
    someguyinhtx
    6" Pro comp lift
    Yes. Have the relays on hand but after the drama decided to KISS until the as shipped setup worked. It was fun enough abandoning their switch wiring and swapping to the previous gen switch with fold button.
    Also - is there a backlit version of that gen 2 switch? Trying to manually find the unfold button for the mirrors is interesting at night.
    Just realized you’re in Conroe. I’m up there a ton. We should grab lunch or a beverage.
  28. Aug 4, 2022 at 7:46 AM
    #148
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Unfortunately, no to the illuminated switch question. I've looked and I'm pretty sure @RainMan_PNW has looked.
    Most definitely hit me up if you're in my neck of the woods!
  29. Aug 4, 2022 at 9:20 PM
    #149
    RainMan_PNW
    Casey
    Clark County, WA
    Yeah - no illuminated option. The one that you will see advertised on ebay from the “Auris” (European Corolla) is its own microprocessor and isn’t compatible with Tundra wiring from the testing I’ve done (I bought one and mapped the wiring over and it doesn’t have enough amperage capacity to consistently drive the mirrors).
  30. Aug 5, 2022 at 6:09 AM
    #150
    someguyinhtx
    6" Pro comp lift
    This just saved me hours of scouring the internets.
    texasrho83 likes this.
