Boost Auto Tow Mirrors
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2020Platinum, Apr 11, 2021.
  1. Dec 8, 2021 at 5:05 PM
    #61
    campergf23
    campergf23 2021 TRD Sport Premium DC
    Quebec, Canada
    None of my other turn signals are sequential, and I don't have any plans to change that. I figured the sequential may look out of place. I do however regret not getting powerfold. I have to fold my mirrors in parking at home now. (Would have had to fold the stock mirrors in as well. My garage is tight.)
  2. Dec 9, 2021 at 5:04 AM
    #62
    KyleBarnes
    KyleBarnes New Member
    Kyle
    2017 Tundra Limited
    Great post! I will likely be getting these now
    RogueAngler and RobertD like this.
  3. Dec 29, 2021 at 7:28 AM
    #63
    bwacrey
    bwacrey New Member
    Brad
    2021 LTD CM 4x4
    What was the final configuration that worked? I ordered the same mirrors and already have a gen2 switch.
  4. Dec 29, 2021 at 7:54 AM
    #64
    RogueAngler
    RogueAngler New Member
    @NESURFPRO
    2021 MGM TRD Pro DC
    Tint (3M) to VA limits TRD rear sway bar AJT Design chrome delete; all black TRD shifter Coachbuilder trd pro kit with Bora spacers Toyo OC AT3s CBI overland rock sliders Ordered: UpTop overland Alpha roof rack with Baha lights Considering: RSi SmartCap
    Could someone send me a link to the Gen 2 switch that could substitute for the Boost Auto provided auto mirror switch? TIA.
    Also, maybe for Rainman_PNW, does anyone know what wire to tap into in order to connect flood lights on Boost Auto mirror to interior doom and floorboard lights (instead of reverse)?
    Thanks for any guidance.
  5. Dec 29, 2021 at 8:15 AM
    #65
    RobertD
    Robert
    DFW, Texas
    What do you mean by auto mirror switch?
    If you are wanting the switch that fits the stock location but has the button to fold the mirrors in, try this.
    https://www.amazon.com/dp/B07Q572QBK
    In your driver footwell area, there should be a single bulb that illuminates when you open doors or unlock the vehicle. I tapped that when doing my side lights (not for my boost mirrors). Hope that helps
    Edit: here's a post that explains it better.
    https://www.tundras.com/threads/blue-ribbon-4x4-build-thread.71556/page-3#post-1903058
    bulldog93, bwacrey and RogueAngler like this.
  6. Dec 29, 2021 at 9:54 AM
    #66
    RogueAngler
    @NESURFPRO
    2021 MGM TRD Pro DC
    RobertD - super helpful. One follow-up -- the Amazon linked product references several Toyota models but not Tundra. Are you confident it fits the Tundra (looks like it will). Seems like that approach would be cleaner then adding the Boost Auto provided stad-along switch in my center console.
    It is also interesting that the comparable Sparks Part switch is $120.
    Search Results | Sparks Parts
  7. Dec 29, 2021 at 10:49 AM
    #67
    RobertD
    Robert
    DFW, Texas
    90% confident. Its the switch I ordered but its still in box because I ran into issues with my painting.
    I just didn't want to pay that much for a switch....
    RogueAngler[QUOTED] likes this.
  8. Dec 29, 2021 at 1:23 PM
    #68
    bwacrey
    bwacrey New Member
    Brad
    2021 LTD CM 4x4
    I’m planning to use that switch too. I got the switch on Amazon with the plug/wires. Still waiting on my mirrors to arrive. My plan is to use the wires that Boost Auto provides that go to their switch and I’m going to do in-line splices from the old connector to the new plug/wires. Colors don’t match, but just match pin to pin.
    Here’s my stock limited plug currently… missing 2 wires on right side. That’s where I’ll splice in ones from Boost that would go to their switch.A55EC3E6-36B6-4689-A8B8-7909B7B06818.jpg
  9. Jan 27, 2022 at 12:31 PM
    #69
    tnbndr
    tnbndr New Member
    New Berlin, WI
    2012 White Rock Warrior CrewMax
    So I have a 2012 Crew Max Rock Warrior with just power adjust and defrost. I ordered the KTJO dash switch with the power fold switch. When I took out the old switch, my wiring harness has 10 wires into the plug, the old switch is simply missing pins at certain locations. The new switch has all the pins, the harness has all the wires. Would simply getting a set of power fold mirrors and installing them, give me the power fold now with the new switch or would that be too easy?
  10. Jan 27, 2022 at 1:30 PM
    #70
    odin1701
    odin1701 New Member
    2021 Tundra LTD TRD OR MGM
    Man these look nice.
  11. Jan 27, 2022 at 2:32 PM
    #71
    RogueAngler
    @NESURFPRO
    2021 MGM TRD Pro DC
    Yup, pretty sweet. Zero vibration that I can tell. What a difference from stock with nothing but defrost.
  12. Jan 27, 2022 at 2:52 PM
    #72
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    It appears your pup approves as well!
  13. Jan 27, 2022 at 3:36 PM
    #73
    RogueAngler
    @NESURFPRO
    2021 MGM TRD Pro DC
    Luna aka Blockhead likes my Boost Auto mirrors almost as much as her softball and hardball.
    bulldog93, Dsptundra and dpast88 like this.
  14. Jan 28, 2022 at 2:02 PM
    #74
    handyman
    handyman New Member
    2016 Crewmax Limited in Sunset Bronze Mica
    BFG All-Terrain TA KO2 Tires, Pillar Grab Handle, Curt Front Hitch & Winch Mount, Smittybilt XRC-8 Winch, Escort Solo S3 Radar Detector, Tekonsha P3 Brake Controller, Galaxy DX 2547 CB Radio, Center Console Organizer & Tray, ESP Rear Seat Storage, SumoSprings, Pop & Lock Tailgate Lock, AMP Bed Step, AMP Side Steps, BacFlip G2 Tonneau Cover, and more pending.
  15. Jan 28, 2022 at 2:12 PM
    #75
    handyman
    handyman New Member
    Just consider it a challenge. I have less than 2-inches to spare getting through the garage door, with a tight turn while exiting to get out the driveway. Been doing it for 6 years now without a scratch. Of course, tomorrow is another day. :plane:
  16. Feb 11, 2022 at 8:12 PM
    #76
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I've pretty much decided to spring for these since everything on Amazon is long term out of stock and eBay doesn't have enough detail to know exactly what I'm getting. Buy once, cry once and whatnot.
    Here's what I'm thinking but am open to suggestions:
    Black
    Amber dotted (amber LED)
    I'm on the fence between signal & running 1.0 and signal and running 2.0.
    Low output flood (since I don't think my truck has these anyway)
    Can't decide if I need defrost for the lower glass as well or if upper only is sufficient only. I'm unlikely to tow in the winter.
    Manual fold
    No BSM
    #76
    RainMan_PNW and 2020Platinum[OP] like this.
  17. Feb 11, 2022 at 10:08 PM
    #77
    RobertD
    Robert
    DFW, Texas
    I didn't like their dotted so I did the amber strip. I also wanted them on as a drl so I did option 2. But you know your truck and I'm sure the options you picked will work.
    Mine are still boxed... I need to paint my caps and was trying to do it myself but ran into issues... hoping to get that corrected soon.
    #77
  18. Feb 12, 2022 at 6:49 AM
    #78
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I don't know if I've ever seen any in the wild with the dimmer 1.0 running lights. Maybe I'll spring for the extra $40 per mirror to get 2.0.
    RobertD[QUOTED] likes this.
  19. Feb 13, 2022 at 7:52 PM
    #79
    2020Platinum
    2020Platinum [OP] www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    You won’t be sorry, still love these things as much as the day I installed em…as for the options, whatever works best for you!…I will say having the defrost on the lower portion is definitely nice, I find myself using the lower glass a lot on the highway when switching lanes, virtually eliminates blind spot…let me know if ya need anything with the install!
    #79
  20. Feb 16, 2022 at 4:31 PM
    #80
    drgordon13
    drgordon13 New Member
    2020 Gray Tundra TSS
    Looking for a little advice...I have the same set up as you with the exact same wiring...I emailed boost and they told me the yellow and blue wires are both for the auto fold...I explained to them that I did not want to use the switch they sent as I don't really like it...they told me if I don't wire it just like they show in the video my warranty will be voided...
    I have two switches ordered (one will fit in the blank switch spots I have and the other is the OEM type with the folding mirror button added). I plan on looking at them and seeing which I like better....
    I also have a separate switch for the lights on the mirror because I do not want them to come on when I go in reverse...
    How did you end up wiring it? Looking for some thoughts before I get to work.
    On another note, the mirrors are installed and I love them, but the passenger top mirror vibrates bad over about 30 mph...I contacted them and they want a video...that is easier said than done...anyone else go down this road??
  21. Feb 18, 2022 at 12:07 PM
    #81
    drgordon13
    Hey Patrick...love all the videos...you have helped me lots over the past year! Was wondering if I could pick you brain on some wiring questions about my tow mirrors? I posted in this thread earlier but have not gotten any responses...I want to set mine up very similar to what you did in the Youtube install video...Thanks!
  22. Feb 20, 2022 at 7:19 PM
    #82
    2020Platinum
    Patrick
    Northeast PA
    Hey buddy!…don't mind helping at all, shoot me a message and I’ll see if I can get ya fixed up!…and thanks for supporting the channel!
  23. Apr 15, 2022 at 8:43 PM
    #83
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Well, I took the plunge and ordered mine. Almost $900 USD.
    RobertD and RainMan_PNW like this.
  24. Apr 16, 2022 at 7:04 AM
    #84
    drgordon13
    Nice! They are one of the best mods I have done! Let us know if you have any install questions. Patrick's video on You Tube is amazing!
    Cpl_Punishment likes this.
  25. Apr 27, 2022 at 7:53 PM
    #85
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    bulldog93 and RobertD like this.
  26. May 16, 2022 at 3:01 PM
    #86
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
  27. May 28, 2022 at 9:32 PM
    #87
    RobertD
    Robert
    DFW, Texas
    Email from Boost about their Memorial Day sale..
    SAVE 25% Off Pre-Built Tow Mirrors, Wireless Chargers, and Switchback Lights (no code needed)!
    Save 10% off everything else with discount code "USA22"!
    bulldog93 and RainMan_PNW like this.
  28. Jun 29, 2022 at 7:04 AM
    #88
    RobertD
    Robert
    DFW, Texas
    They are running another sale.
    SAVE 25% Off Select Products including Tow Mirrors, Wireless Chargers, and Key Fobs (no code needed)!
    Save 10% off everything else with discount code "JULY22"!
    bulldog93 likes this.
  29. Jun 29, 2022 at 10:49 AM
    #89
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Tundras are not included in the 25% off, are included in the 10% off.
  30. Jul 2, 2022 at 1:03 PM
    #90
    tbkane
    tbkane New Member
    2017 Tundra SR5 Double Cab
    Reverse power aux lights Boost auto fold mirrors Switched reverse lights Trying to switch power port to USB: failing
    anyone change the switch on the Boost aftermarket power fold option, but not to an OEM combined fold/adjust switch? The switch boost sent does not fit any of my blanks, and I want to switch out the switch for an AOB one that fits an open blank. Need help with wiring it.
