Boomy exhaust?
Discussion in 'Performance and Tuning' started by CreekDweller, Nov 10, 2019.
  1. Nov 10, 2019 at 7:30 AM
    CreekDweller
    CreekDweller [OP] Not so new ...
    2020 MGM 1794 TRD Off-Road
    After several months of mostly lurking, on Wednesday night I took delivery of a 2020 MGM 1794. I'm still in the 'honeymoon' period with less than 200 miles so far but I have a question I hope someone has the answer to.
    I have the stock (regular) exhaust which seems to be very boomy at some RPMs, including highway speeds where it is steady and fairly annoying. It is not the tires. I believe it is the exhaust because the sound is distinctly coming from the rear of the truck and not the engine compartment. And it varies with engine speed so that sometimes it isn't even there. I wondered it the muffler or exhaust pipe might be making contact with the frame ....
    I thought there was a fairly recent post on this subject but I've done searches and can't find any posts about it. So, has anyone else had a boomy exhaust and if so, figured out how to get rid of it? Or might it be something else?
  2. Nov 10, 2019 at 7:34 AM
    18" TRD Off Road Wheels
    I came to this thread expecting you to be asking for recommendations on a new exhaust. I was all set to recommend DiryDeeds. Though, technically, I would still recommend asking @dirtydeeds because he's an exhaust guru.
    Primalbryan, Sas, RLHULK and 2 others like this.
  3. Nov 10, 2019 at 8:41 AM
    17TundraDCEd
    17TundraDCEd New Member
    Ed
    SE Pa
    2018 White SR5 Crewmax
    Rear Sway Bar
    Tailpipe resonator will make a Tundra with stock exhaust sound like a Prius. Speaking from experience on a previous Tundra.
    The OEM system does have some drone.
    That said, give it a little time, because I feel the engine does break in (mechanically and computer “learns”) with some miles and runs smoother, which also smoothes out the exhaust note.
  4. Nov 10, 2019 at 8:43 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Stock exhaust......boomy?
    I couldn't even hear anything from my stock exhaust.
  5. Nov 10, 2019 at 9:10 AM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
  6. Nov 10, 2019 at 10:11 AM
    Stocky Balboa
    Stocky Balboa New Member
    OC , CA
    2018 Limited TRD 4x4 CM - Cement
    Minor stuff- Tint, rear sway bar , pedal commander, TRD drop in filter DD Exhaust, Bilstein 6112/5160, stealth 32” lightbar, Cali Raised Offroad fog light replacements.
    congrats on the new ride.
    Fairly new owner here too. My stock exhaust did have an odd drone type sound. All went away with DD 8” exhaust w/ resonator.
    GODZILLA likes this.
  7. Nov 10, 2019 at 10:16 AM
    CreekDweller
    Good replies. I have the single exhaust and not the TRD dual pipe system, so an H pipe connector is not possible. I think I'll take Ed's suggestion and wait a bit for the engine to finish break-in and see if the drone goes away. Thanks for the input.
  8. Nov 10, 2019 at 10:43 AM
    Is it possible to do the H pipe in the mid section? Even the single exits start out as two separate pipes that merge in the muffler. I have no idea, I'm not a mechanic by any stretch.
  9. Nov 10, 2019 at 11:03 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Give Keith a call at 1-760-877-4234, he'll educate you on everything about your Tundra exhaust.
    dirtydeeds and GODZILLA[QUOTED] like this.
  10. Nov 10, 2019 at 11:06 AM
    I already bought a 10" BAMuffler from him, so I'm good. :thumbsup:
    dirtydeeds likes this.
  11. Nov 10, 2019 at 3:00 PM
    CreekDweller
    Will do this.
    One thing that is odd is that some stock systems drone and some don't. Maybe it will all settle down after break-in.
  12. Nov 10, 2019 at 8:13 PM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    Just curious. Is there are certain speed range, or rpm, or driving condition that you notice it? In my experience, 50 to 65 mph in high gear and light throttle to maintain or fluctuate speed (especially on an incline) was the sweet spot for drone. The engine rpm is low, and the truck kind of lugs.
  13. Nov 11, 2019 at 6:17 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    There’s no break in. The exhaust is welded together.
  14. Nov 11, 2019 at 6:19 AM
    dirtydeeds
    Keith
    USA
    They all do this. The tune in the ecu determines its severity. It’s caused by how much valve overlap there is, and when it occurs.
    a helmholtz resonator will make it stop.
    760-877-4234
    Gimme a call in a few hours today.
    FrenchToasty and GODZILLA like this.
  15. Nov 11, 2019 at 8:20 AM
    CMB
    CMB New Member
    Cecil County MD.
    Reach down and shift to a lower gear to keep from lugging, you bought the Sequential Shifter; you have more choices than "D":thumbsup:
    Rex Kramer and dirtydeeds like this.
  16. Nov 11, 2019 at 8:43 AM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    Right foot works too.;)
  17. Nov 11, 2019 at 12:16 PM
    CMB
    CMB New Member
    Cecil County MD.
    Yep, if you'd rather shift with the throttle instead of gears.
