Boomer the 2020 SR5 Overland Build
Discussion in '2.5 Gen Builds (2014-2021)' started by dorton, Sep 2, 2020.
  1. Dec 30, 2020 at 11:42 AM
    TX_Battlewagon
    TX_Battlewagon New Member
    2019 Magnetic Gray Metallic Tundra TSS
    Yeah I just called CBI and surprisingly they answered the question. Should be coming out in about 6 months. So now I'm torn, order one today and get it sooner or wait the 6 months for the new hybrid bumper?.....
    dorton[OP] likes this.
  2. Jan 5, 2021 at 6:37 AM
    dorton
    dorton [OP] #RockCreekOverland
    North Carolina
    2020 Black Tundra SR5
    CBI Off Road Front Bumper, Rock Sliders, Skids, and Bed Rack. Prinsu Designs Roof Rack, CVT Hybrid Rainier Tent, Old Man Emu lift, Fuel Vectors, Yokhama 305/70r18s
    A little bit of info for folks that plan on doing 5 tire rotations, like me:
    A few miles after performing my first 5 tire rotation, my TPMS light started flashing, and then came on solid. When checking tire pressures
    through the multifunction display, no pressures were shown. I tried using the TPMS button located on the right lower dash area in front of
    the driver, using both Initialization mode and Registration modes with no luck.
    I ordered a new OEM sensor, and installed it in my now right rear wheel(only wheel with no sensor). Started the engine, and tapped the
    TPMS button 3 times in less than one second, thereby entering Registration mode, confirmed by TPMS light flashing, then staying solid.
    Left work, and within a mile TPMS light had gone out, and within 2 miles was now correctly displaying tire pressures.
    **FYI** According to Toyota if you put the vehicle in reverse it may take it out of Registration mode.
  3. Jan 5, 2021 at 6:39 AM
    dorton
    North Carolina
    That's a tough call. I'm very pleased with the one I went with, but I'd also be very pleased with the hybrid. I wouldn't be able to
    convince you one way or the other, as I really like both.
  4. Jan 5, 2021 at 7:09 AM
    TX_Battlewagon
    Yeah, I've been going back and forth with what looks best. I got another response from CBI yesterday saying the new hybrid bumper should be on the website within the next week so I will wait for pricing to make my final decision. BMC and new wheels and tires are ready to go now just waiting on a bumper and sliders.
    dorton[QUOTED][OP] likes this.
  5. Jan 8, 2021 at 11:45 AM
    dorton
    North Carolina
    I work in a Toyota dealer service department and we do a pretty decent amount of lifts.
    I had a set of new take-off leaf spring packs from a 21’ Tacoma that sparked a little curiosity. I’m currently running stock leaf pack, with 2” lift shackles. I’m determined to work with them until my truck reaches its final form(rear bumper with dual swing-arms with spare tire carrier).
    On my tacoma rear suspension went: old man emu standard > + ome extra leaf > ome heavy > dobinsons super heavy(better ride than factory).
    I want to only buy leaf springs one time....
    I measured the taco leaves, then tundra leaves. Same width, different lengths and thicknesses. I was able to take one of the thinner leaves from the taco pack remove a couple inches off each end, swap the plastic leaf pads, and install on my truck only needing longer center pins and new u-bolts.
    I don’t have a scientific way to measure spring rate but, with the springs arched upward I could apply 280lbs(my weight) to the perch area and compress them 2-2.5” individually. With equal weight on both, I could compress them 1-1.5” eyeballed.
    installed on the truck, I gained a little height (little more arch in the spring pack), and ride is great. I’m attributing the ride to the leaf thickness.
    Mixing and matching leaves is not new to truck builds or off roading, but definitely doesn’t seem to be as common as it once was.
    COTundra23, Vang530, Hbjeff and 2 others like this.
  6. Jan 8, 2021 at 11:57 AM
    Wallygator
    Loving your build so far man. Very nice!:thumbsup:
  7. Jan 12, 2021 at 12:23 PM
    dorton
    North Carolina
    Installed the soon to be released KCHilites FE4 leds recently on my CBI ditch
    light brackets, and got to go wheel and camp this past weekend.
    Ltaco17, myt1, COTundra23 and 3 others like this.
  8. Jan 15, 2021 at 11:45 AM
    TX_Battlewagon
    Finally made a decision and went with the full hoop CBI bumper after enough digging around. It was your video that drove my choice so I appreciate the inspiration.
  9. Jan 16, 2021 at 9:50 AM
    dorton
    North Carolina
    Awesome choice!!!
  10. Jan 17, 2021 at 7:09 AM
    tundranoob702
    tundranoob702 New Member
    2021 Tundra Trail Edition
    thats a nice truck!:yes:
    I just recently purchased my first truck. I have a 2021 black sr5 trail edition and have been overwhelmed on how many different paths to take when upgrading the suspension and tires (that dont rub).
    I was looking at the OME bp51 setup but was also curious on the non resi suspension kit from OME. Looking into overlanding the truck and as a daily.
  11. Jan 18, 2021 at 4:49 AM
    dorton
    North Carolina
    Thanks!
    The BP-51s are definitely awesome. I never ran them on my personal vehicle. I've got OME nitrochargers on my 86' 4runner(since 2013), my 07' FJ Cruiser had 150k on an OME kit, my 16' Tacoma had 150k miles on a mostly OME kit(rear springs were Dobinsons) and had such great service out of all of them I went OME again. If I were in UT,NM, AZ or somewhere else where I could off road at higher speeds more consistently, I'd probably look at something with remote reservoirs, but east coast the durability of the nitrocharger is more important than shock fade. They also ride well.
    Wallygator likes this.
  12. Jan 18, 2021 at 4:59 AM
    dorton
    North Carolina
    I'm always impressed with the bed space on this truck compared to the tacoma. With the Tacoma, on long trips with the fam, it took planning to fit everything.
    On the Tundra its not an issue.
    Wallygator, COTundra23 and TokerJoker like this.
  13. Jan 18, 2021 at 5:16 AM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Nicd build OP! Just ran across this before starting another week in the rat race. Good to see you enjoy the Tundra!!
  14. Jan 18, 2021 at 6:57 AM
    Blueknights75
    Ron
    Clayton, NC
    Beautiful truck OP! Definitely following this thread! What dealership are you at if you don’t mind me asking?
  15. Jan 18, 2021 at 7:40 AM
    dorton
    North Carolina
    Thanks!
    I'm at MidState Toyota in Asheboro,NC.
  16. Feb 27, 2021 at 8:21 AM
    dorton
    North Carolina
    I had the ExpeditionEssentials TPAM in my Tacoma and loved it. Recently they released the Tundra version, so I jumped on it.
    Install was simple and smooth. This mounting solution is incredibly stable. Mounting radios,
    ipad, phone...whatever...it's rock solid.
    Ltaco17 likes this.
  17. Mar 26, 2021 at 12:02 PM
    dorton
    North Carolina
    Got a little time with nature before things start turning green again.
    Nice spot for the night
    Nav and Commo mounted
  18. Mar 26, 2021 at 12:04 PM
    Ltaco17
    Ltaco17 New Member
    NC
    2023 TRD Pro
    285/75/18 Falken Wildpeak R/T color matched handles and mirrors.
    Looking good!!!
  19. Mar 31, 2021 at 7:46 AM
    #49
    COTundra23
    COTundra23 New Member
    Looking reallll good! How are the 612's holding up with the weight from that bumper?
  20. Mar 31, 2021 at 7:56 AM
    #50
    dorton
    North Carolina
    Thanks!
    So far, so good. When I decide which route I want to go on a winch, I'll be swapping them out though.
    COTundra23[QUOTED] likes this.
  21. Mar 31, 2021 at 7:59 AM
    #51
    COTundra23
    Good to know! I am about install the 612's and will likely be getting a bumper next but no winch so I am hoping the 612 will be sufficient!
  22. Apr 14, 2021 at 8:02 PM
    #52
    COTundra23
    Lookin good! What suspension are you running?
