Bolt in On Board Air Compressor Mount
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bannock452, Apr 6, 2018.
  1. Aug 16, 2018 at 10:28 AM
    #91
    Swamp_Dawg
    Swamp_Dawg New Member
    Greg
    2012 Silver Tundra TRD
    Four Wheel Pop Up Camper, Aluminess Ft Bumper, Warn VRS-12000 winch, KC 20” light bar, Bushwacker fenders
    I just tried to place my compressor in that spot. There is no way it would ever fit there. 2012 - 2nd gen tundra.
  2. Aug 16, 2018 at 2:14 PM
    #92
    point of impact
    point of impact New Member
    Ben
    2016 Tundra TRD Pro CM
    @Bannock452
    From the looks of it, there is still a little room in front of the compressor towards the air box.
    My 2 cents....
    If you make it fit tight but not touch the airbox, it would be better than siitting close to the insulation on the firewall (which may turn out to be a non issue) It may make servicing the air filter a little more difficult but shouldn't be a deal breaker.
    You can always torture test it by running the compressor and monitoring the temp of the insulation. The compressor may get hot but the fan on the backside will keep air moving back there so maybe that will keep the insulation from getting too hot. And who knows....maybe this will be a non issue. Hell I'm willing to try it if you want someone to guinea pig it for u.
  3. Aug 17, 2018 at 12:17 PM
    #93
    Bannock452
    Bannock452 [OP] New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    I did try to install it with the compressor already mounted. Definitely doesn’t fit in there since the legs are so long on the mount. But I never tried to remove he airbox or any other options like that. That’s a good idea tho. I believe the stock airbox is only a few bolts so might be worth it to have the extra clearance. Going to try that next time I get a chance!
  4. Aug 17, 2018 at 12:24 PM
    #94
    Bannock452
    Brandon
    Murrieta, CA
    That is a good point. I’m going to try and move the holes forward to move it closer to the airbox. Also thought about making it at an angle to drop the rear down too.
    Thank you for your input. I currently do not have the twin wired up but I think I can do that fairly easy once I get it fit right and I will do a test run. Also curious to see how much difference it makes from the single.
  5. Sep 4, 2018 at 9:11 PM
    #95
    Norcalocal
    Norcalocal New Member
    2016 TRD
    Count me in for the dual compressor mount. My compressor just arrived and I’m itching to get it installed. Thanks for the constant progress updates. Nice to see you’re doing quite a bit of R&D.
  6. Sep 7, 2018 at 9:59 AM
    #96
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    Are these or any other compressor mounts available? I just bought a single through the group buy, so now I need a mount for it.
    joonbug and dcsleeper408 like this.
  7. Sep 7, 2018 at 12:49 PM
    #97
    Bannock452
    Brandon
    Murrieta, CA
    What’s up guys! So FINALLY!! Today (Friday 9-7-18) I am in the shop making more of these mounts! Has been difficult to get into the shop lately since my boss has been busy with some family things and the holiday. But now we are good to go. Trying to make as many as possible this weekend until we run out of material. I will continue to come to the shop after hours and make more next week.
    Thanks again for hanging in there with me. I’ll post up some photos later today of the final mounts
  8. Sep 7, 2018 at 12:51 PM
    #98
    cooper4x4
    cooper4x4 New Member
    2016 Tundra SR5
    how much room is under the mount? I'm considering using one of these as a fuse block mount, but would need room underneath for wiring.
  9. Sep 9, 2018 at 4:29 PM
    #99
    Bannock452
    Brandon
    Murrieta, CA
    Im sure this would work fine for a fuse block mount. Probably the single mount will work fine for your needs? The single mount has roughly 1” or so under the mount. The twin is lowered so it’s very tight. Maybe 1/4”- 3/8” below the twin mount.
  10. Sep 9, 2018 at 4:34 PM
    #100
    Bannock452
    Brandon
    Murrieta, CA
    Was able to get 8 twin mounts made Saturday. Sanded drilled and bent up! So far everything is looking good besides one part... I messed up my measurement for the added leg for an extra mounting point. It came out too short so I’m not able to weld that leg onto the mount. No big deal tho I just have to make a few new legs. Once I get those legs made all I need to do is weld them on and these bad boys will be ready to go! Here’s some photos to show you what I’m talking about.
    Here is the added leg that was too short.
    aperezsh, Wrongside, sdde4n and 5 others like this.
  11. Sep 10, 2018 at 2:06 PM
    #101
    cooper4x4
    2016 Tundra SR5
    What are the dimensions of the mounting surface on the single?
    aperezsh and GiantsFanDan like this.
  12. Sep 10, 2018 at 2:12 PM
    #102
    cooper4x4
    2016 Tundra SR5
    Any way to get one with the cut out on page two of the attached pdf, instead of the ARB mounting holes? PM me if you don't want to clutter this thread.
    GiantsFanDan likes this.
  13. Sep 10, 2018 at 7:49 PM
    #103
    Bannock452
    Brandon
    Murrieta, CA
    The dimensions are 4 1/4” wide and 5 1/2 long on the top surface. Looks like it’s a good size for that part you need. All of my mounts have the holes in them already... but I can always fill the hole with weld and try to cut out that hole for you to those PDF dimensions. If your interested in trying that PM me and we can discuss more then.
  14. Sep 10, 2018 at 8:02 PM
    #104
    acmesupply
    acmesupply New Member
    2018 SR5 CM Silver TRD
    Hello Brandon, could you add me to your list of a double mount please. Thanks
  15. Sep 10, 2018 at 8:19 PM
    #105
    Bannock452
    Brandon
    Murrieta, CA
    Added. Thank you. I will send you a message when I have more ready to go.
  16. Sep 24, 2018 at 9:00 AM
    #106
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    I have the same intake on my truck, any chances I would be able to fit a twin mount back there or is the single my only option. I really need it to mount my extra electrical accessories without having to drill into the body.
  17. Sep 24, 2018 at 10:45 AM
    #107
    tundraoverland1
    tundraoverland1 New Member
    Las Vegas
    2015 White Tundra crewmax TRD 4x4
    IG: sfarrisjr88
    This makes me happy. Finally a picture of one mounted with the AFE intake box. How tight is the fitment with te AFE and the arb behind i?
  18. Sep 24, 2018 at 10:59 AM
    #108
    Cfincke
    San Antonio
    @cooper4x4 - I designed the following bracket for the bussman rtmr and had Power Trays cut and bend it. They have the file to make more, you will just have to locate and drill the mounting holes. Then in the future you could add a compressor using @Bannock452 mount
    Beesta, sdde4n and Bannock452[OP] like this.
  19. Sep 24, 2018 at 12:28 PM
    #109
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    Very tight! I had to remove the box installed the bracket and pump and reinstall. Is worked out great.
    Bannock452[OP] likes this.
  20. Sep 24, 2018 at 12:29 PM
    #110
    tundraoverland1
    Las Vegas
    IG: sfarrisjr88
    okay so no other issues with the mount or compressor hitting the intake box. i dont mind having to remove the box to install everything
  21. Sep 24, 2018 at 12:29 PM
    #111
    poheller
    Scot
    2018 platinum
    Not enough room for the double.
  22. Sep 24, 2018 at 12:29 PM
    #112
    poheller
    Scot
    2018 platinum
    None at all.
    TheBeast likes this.
  23. Sep 24, 2018 at 12:40 PM
    #113
    tundraoverland1
    Las Vegas
    IG: sfarrisjr88
    Awesome glad to hear that
  24. Sep 24, 2018 at 12:59 PM
    #114
    bsavoir
    bsavoir New Member
    Killeen, TX
    Thanks, then the single mount it will be.
  25. Sep 24, 2018 at 2:48 PM
    #115
    cooper4x4
    2016 Tundra SR5
    That's nice. Mind if I ask the price?
  26. Sep 24, 2018 at 2:51 PM
    #116
    cooper4x4
    2016 Tundra SR5
    How is the bottom secured?
  27. Oct 8, 2018 at 7:26 PM
    #117
    alyosha01
    alyosha01 New Member
    Hello Brandon,
    I want to be added to the list. I need a twin compressor bracket.
    Thanks a bunch!
    dcsleeper408 likes this.
  28. Oct 8, 2018 at 9:00 PM
    #118
    Bannock452
    Brandon
    Murrieta, CA
    Added to my list man!
    Also I have made a large batch of twin mounts this last weekend and am shipping twins at this time. I have plenty of singles ready to ship also. I will be sending messages to all of you on the list here soon. Thanks again for hangin in there with me!
  29. Oct 8, 2018 at 9:34 PM
    #119
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Heavy, unnecessary offroad stuff.
    Thanks again @Bannock452 ! So stoked to get this up and running.
    Cfincke and dcsleeper408 like this.
  30. Oct 8, 2018 at 10:03 PM
    #120
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Bannock452[OP] and dcsleeper408 like this.
