Bolt in On Board Air Compressor Mount
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bannock452, Apr 6, 2018.
  1. Apr 24, 2021 at 8:56 AM
    #451
    NFARIDI
    NFARIDI New Member
    Were you able to get the right-side firewall bolt installed for the bracket?
    I am installing mine in the sequoia today and just cant seem to find a way to get my hand back there to thread it in. The two hoses in the sequoia definitely get in the way but so far I got the other 3 bolts in without issue. Wondering if it will be okay if I leave that one bolt out.
  2. Apr 24, 2021 at 10:42 AM
    #452
    Bannock452
    Bannock452 [OP] New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    That right side bolt is a serious pain!! I’ve taken my Compressor and bracket out several times and I struggle to get that bolt every time! It’s possible with some nice extension tools. Buts it’s definitely not easy. Fitting the mount itself without the heavy compressor to see how the bolt holes line up can help. Small flex of the legs can help line up each bolt hole.
    Unfortunately I couldn’t find any other way to change that design and still use that bolt. Hope that helps!
    NFARIDI[QUOTED] likes this.
  3. Apr 24, 2021 at 11:13 AM
    #453
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    What are you guys and gals using as a on/off button and location?
  4. Apr 24, 2021 at 6:52 PM
    #454
    NFARIDI
    NFARIDI New Member
    Okay glad I wasn't the only one having an issue with that bolt lol. In the end that ended up being the least of my problems.
    The 2008-2013 Sequoia's have the larger airbox as mentioned several times in this thread, which I completely forgot about in my excitement to finally install the compressor. Was reminded today that I cannot run the ARB Dual Compressor with the 2013 Airbox. Trying to figure out what my options are now..
    A- try to find a 2014+ airbox. (am i okay with just the upper and lower portions or I need the 2014+ air inlet pipe and all too?)
    B- maybe I can get a TRD intake for 2008-2013.
    C- potentially source another ARB compressor mount that sits over the fuse box (i.e., Rago)
    Also need to get a 45degree elbow NPT pipe as the ARB one doesn't clear firewall shroud.
    Here's some pics. Painted the bracket black as well.
    CH4x4 switch which ended up being defective. Had a broken pin inside for the power wire. Gotta reach out to them for a replacement.
    and where I got stuck because of my 2013 airbox:
    Blue Thunder, AZTundra and Drainbung like this.
  5. Apr 25, 2021 at 7:19 PM
    #455
    virgilus11
    virgilus11 New Member
    2022 Tundra Capstone
    1/2" front spacer 37" Cooper ATX
    Sorry for the late reply bud,
    Yes, I install it but I had to loose the black pipes and move them on the side. Patience and few special words will work.
    Just make sure you match the clamps back to the yellow marks when you put them back.
  6. Apr 26, 2021 at 6:51 AM
    #456
    NFARIDI
    NFARIDI New Member
    Ahh good advice. Thanks!
  7. Apr 27, 2021 at 9:33 AM
    #457
    Damie Street
    Edsel
    South Carolina
    Just ordered one from him via Instagram and venmo.
  8. Apr 27, 2021 at 9:34 AM
    #458
    Damie Street
    Edsel
    South Carolina
    What did you use to paint the mount with? I was thinking of powder coating.
  9. Apr 27, 2021 at 9:41 AM
    #459
    NFARIDI
    NFARIDI New Member
    You can use anything really. I ended up using POR15 TOP COAT. Just happened to be what I had lying around.
  10. Apr 28, 2021 at 11:43 AM
    #460
    Damie Street
    Edsel
    South Carolina
    Do the new mounts fit with the aFe cold air intake box?
  11. Apr 28, 2021 at 9:23 PM
    #461
    Bannock452
    Brandon
    Murrieta, CA
    Yes the larger updated compressor mount will fit with the AFe intake box. But will ONLY have enough clearance for the single ARB compressor just like these photos above. The twin compressor is too large. But the actual mount fits the same.
    Damie Street[QUOTED] likes this.
  12. Apr 29, 2021 at 7:44 PM
    #462
    kingalw
    kingalw New Member
    2020 TRD Sport
    Anyone know where you can actually find the twin compressor in stock? :) Need a compressor so I can buy a mount lol
    Damie Street likes this.
  13. Apr 29, 2021 at 10:48 PM
    #463
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    check out @sdhq_offroad , last time is was oogling in their showroom, I could’ve swore I saw some ARB compressors.
    -Jason
    FrenchToasty likes this.
  14. Apr 30, 2021 at 4:25 AM
    #464
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    4wheelparts.com is ooo, but you can still place an order.
  15. Apr 30, 2021 at 7:33 AM
    #465
    Blue Thunder
    Washington
    Amazon has it and I think SDHQ is the source. I’m tracking the price as it will swing wildly. It is a little high right now.
  16. Apr 30, 2021 at 9:18 AM
    #466
    kingalw
    kingalw New Member
    2020 TRD Sport
    Amazon has it "In stock soon" with delivery mid June. Already checked them out.
    Blue Thunder[QUOTED] likes this.
  17. Apr 30, 2021 at 9:43 AM
    #467
    Blue Thunder
    Washington
    Crap, you are right. Funny it doesn’t show as out of stock on my wishlist (unlike another item).
    Good luck!
    kingalw[QUOTED] likes this.
  18. May 4, 2021 at 6:45 AM
    #468
    Damie Street
    Edsel
    South Carolina
    Got mine in over the weekend and painted it black. Will hopefully get everything installed this week.
  19. May 29, 2021 at 6:05 PM
    #469
    farm&forest
    farm&forest New Member
    2021 Tundra SR5 TRD-Off Road Double Cab
    Dobinsons 2-3" Complete Suspension Kit w/ medium Dobs Leafs, Decked Drawer System, Leitner Forged ACS Rack, Line-Xed bed and Line-Xed Tyger Blade Steps, Wet Okole seat covers, VLED lighting, soon to add Swith Pro and auxillary lights
    I'm going to follow your setup. Thanks for the info. This is my first time fooling with air hose...Is the rubber stainless braided AN6 especially for air only or is it multi/purpose for fuel/oil. The listings on Amazon are labeled for fuel/oil. Anything I need (tool, know-how) to affix the fittings? Possibly there is a prefab product...just not familiar with air stuff.
  20. May 30, 2021 at 3:39 AM
    #470
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    It is a multi purpose hose air, fuel, oil, etc... Youtube the proper way to do the fittings. You could always see if your local NAPA could make the hoses.
    farm&forest[QUOTED] likes this.
  21. Jun 4, 2021 at 1:46 AM
    #471
    Nando_TRD760
    Nando_TRD760 New Member
    Pasadena CA
    @Bannock452 you still selling the trays? I was wondering if a Smittybilt compressor would fit.
    badmotofing3r likes this.
  22. Jun 4, 2021 at 8:17 AM
    #472
    Bannock452
    Brandon
    Murrieta, CA
    Yes sir I still have compressor mounts in stock and ready to ship. I can confirm if the smittybilt compressor will work as I’m not very familiar with that one. I believe somewhere on this page somebody had made that work but I could be mistaken for a different brand also. I can always send you over some photos and dimensions so you can check to see if this will work for you. Let me know and I can send you over some more info if you would like. Thanks!
    Drainbung likes this.
  23. Jun 4, 2021 at 8:27 AM
    #473
    Nando_TRD760
    Pasadena CA
    I was reading through the thread and just saw Viair but yes please send me more information.
  24. Jun 4, 2021 at 10:03 AM
    #474
    Explorer
    Explorer New Member
    Battle Ground WA
    2019 Silver Tundra SR5 TRD Offroad
    Let me know what you find out. I am looking to do the same thing.
  25. Jun 9, 2021 at 7:12 AM
    #475
    Guinnessman1384
    Guinnessman1384 New Member
    I’m interested if the Smittybilt 5.65cfm compressor will fit as well. Been wanting to mount it for awhile
  26. Jun 9, 2021 at 10:15 PM
    #476
    Explorer
    Explorer New Member
    Battle Ground WA
    @Bannock452 if I get you bolt dimensions and height of it would you be able to let us know? Or I could just buy one and see if it all works.
  27. Jun 10, 2021 at 12:11 PM
    #477
    Bannock452
    Brandon
    Murrieta, CA
    Yes I can definitely check some basic measurements for you guys to see if it’s in the ballpark.
    Or if anyone wants to test fit i can definitely ship out a mount to see if it works! It’s it’s not fitting I have no problem giving a full refund if the mount is sent back. We can start with some measurements to see where it’s at.
    Here are some of my measurements I’ve taken with the arb mounted. Obviously the firewall is angled so further out there is more room there is.
  28. Jun 22, 2021 at 8:43 PM
    #478
    Trabs00
    Trabs00 Lifetime Social Distancer
    Travis
    Seattle, WA
    2012 Black Tundra CM
    7" BDS lift King 3.0 Performance series with RR and adjusters 37" Yoko Geo MT Front bumper Demello Offroad Rear Bumper Expedition 1 ATC canopy AMP power steps Alu-cab RTT Alu-cab shadow awning Alu-cab shower cube
    Here's a few pics of my setup. I use my dual for airing up my 37's, and F & R lockers.
    Note: I have a 2nd gen so I swapped my airbox for a 3rd Gen to make things fit. On that note I have a 2nd gen airbox for sale...
    thanks again @Bannock452 for an awesome mount, quick shipping, and being active on this forum.
  29. Jul 26, 2021 at 12:19 AM
    #479
    Moeenulhaq
    Moeenulhaq New Member
    2020 Tundra TRD Pro
    @Bannock452 .. love your work. Would you be able to share dimensions of the top plate where you mount double compressor? I won't be mounting a compressor but need to mount warn winch Controller it's the perfect place away from dirt and water.
  30. Jul 26, 2021 at 4:53 PM
    #480
    Bannock452
    Brandon
    Murrieta, CA
    Hey! Thank you! Yes ofcourse the top plate is 11” wide total and about 6” of depth of usable top space. see photo below
    Hope that helps!
    tundra_20, AZTundra and Drainbung like this.
