Bolt in On Board Air Compressor Mount
Discussion in '3rd Gen Tundras (2014+)' started by Bannock452, Apr 6, 2018.
  1. Jun 11, 2019 at 8:02 AM
    #271
    escuzi_me
    escuzi_me Shut up baby, I know it!
    William
    Smyrna, TN
    2019 Super White TRD Pro
    :yes:
    Hurry up and msg me so you can take my money!
  2. Jun 12, 2019 at 3:57 PM
    #272
    boloson
    boloson New Member
  3. Jun 12, 2019 at 6:16 PM
    #273
    Rlynch356
    Rlynch356 New Member
    Let me know and I can PayPal you
  4. Jun 13, 2019 at 11:53 AM
    #274
    vanthesupreme
    vanthesupreme New Member
    Beaver, OK
    :spending:
    Bannock452 [OP] likes this.
  5. Jun 13, 2019 at 1:21 PM
    #275
    BigWalker
    BigWalker New Member
    Pete
    2019 tundra SR TRD
    haven't seen a message yet :pccoffee:
  6. Jun 14, 2019 at 5:35 AM
    #276
    Rider0120
    Rider0120 New Member
    Bucks County, Pa
    2018 White double cab SR 4x4 long bed
    Ranch Hand full replacement bumper
    Can’t wait my dual mount will be here Saturday!!!
  7. Jun 15, 2019 at 11:48 AM
    #277
    Rider0120
    Bucks County, Pa
    Just received my dual mount today!!!11BB6D6E-5DA5-4234-BFFF-D291D8CB68C3.jpg
    Can’t wait to order my arb compressor
  8. Jun 18, 2019 at 9:34 AM
    #278
    Wildtrout
    Wildtrout New Member
    Seattle
    2018 Tundra Crew Max
    OME BP51 Front and Rear, Complete de badge, ARE Z Series camper shell, Decked system, TRD CAI, painted hood bulge and grill surround, WeatherTech mats
    Install with the compressor was somewhere around $1100. Not sure if they’re advertising it yet.
  9. Jun 18, 2019 at 9:47 AM
    #279
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    Yikes
  10. Jun 19, 2019 at 4:31 AM
    #280
    BigWalker
    Pete
    2019 tundra SR TRD
    Received my mount yesterday, bolted right up. Mocked up compressor location, now to build flat interface plate and wire up
    E407E172-42F7-44BF-9BC2-9B9A9C11940A.jpg 02929B4A-1017-4909-9C50-DC45A0638A20.jpg
    azTony and Bannock452 [OP] like this.
  11. Jun 19, 2019 at 4:59 AM
    #281
    azTony
    azTony New Member
    Tony
    2018 Tundra Platinum
    None... yet
    Wish there were brackets available for the Extremeaire Magnum compressor and a 2 gallon tank. I am not equipped to make brackets but looks like I am forced into it. Gotta get my air going!
  12. Jun 19, 2019 at 8:25 AM
    #282
    BigWalker
    Pete
    2019 tundra SR TRD
    Check the magnum attach pattern to mine it might be they same dimensions. Then you can buy the bracket and just cutout a flat plate, and bolt it to both
  13. Jun 19, 2019 at 8:09 PM
    #283
    Mike19
    Mike19 New Member
    Chi town
    2019 SR5 Tundra Crew TRD Sport MBM
  14. Jun 19, 2019 at 8:18 PM
    #284
    fisherman951
    fisherman951 Just here for the comments
    Tony
    Riverside
    2017 crewmax 4x4
    What compressor is that
  15. Jun 20, 2019 at 3:39 AM
    #285
    BigWalker
    Pete
    2019 tundra SR TRD
  16. Jun 20, 2019 at 4:41 AM
    #286
    azTony
    azTony New Member
    Tony
    None... yet
    Can this bracket hold a 20 lb compressor without issue? What is the bolt pattern that comes on the bracket for the compressor? How much clearance from the bracket to the bottom of the hood do you have once the bracket is mounted?
  17. Jun 20, 2019 at 8:43 AM
    #287
    BigWalker
    Pete
    2019 tundra SR TRD
    Since the ARB twin weighs 17.4 lbs and the ExtremeAire Magnum is 20Lbs mine is the smaller model so it should close to the arb, Even at 15% increasingly of weight there should be enough margin so I am not concerned
    The Magnum is 2" longer and 1/2" taller at the the compressor head. just like my version you need to re-clock the head 90 degrees
    I have know hood interference
  18. Jun 24, 2019 at 12:29 PM
    #288
    Mike19
    Mike19 New Member
    Chi town
  19. Jun 24, 2019 at 2:23 PM
    #289
    BigWalker
    Pete
    2019 tundra SR TRD
  20. Jun 24, 2019 at 5:18 PM
    #290
    Mike19
    Mike19 New Member
    Chi town
    I bought one already, thanks.
  21. Jun 25, 2019 at 4:15 AM
    #291
    azTony
    azTony New Member
    Tony
    None... yet
    Any July 4th deals coming up?
    Berdine likes this.
  22. Jun 25, 2019 at 5:14 AM
    #292
    azTony
    azTony New Member
    Tony
    None... yet
    Anybody got the dimensions of the flat rectangular area of the compressor mounting surface? Just want to make sure my Extremeaire Magnum will fit. Based on @BigWalker's posts it looks like this will work
  23. Jun 25, 2019 at 6:16 AM
    #293
    BigWalker
    Pete
    2019 tundra SR TRD
    The BB plate is 11”wide X 4+” deep
    This is what i consider usable area. For the Magnum you will need to build a mounting plate the extends the 4+” to 5-6” since the two front mounting feet over hang
  24. Jun 25, 2019 at 9:14 AM
    #294
    azTony
    azTony New Member
    Tony
    None... yet
    @BigWalker, did you have to build this extension plate? It appears (I cannot find any drawings online) that mine and your compressor have the same footprint. I will contact the manufacturer.
  25. Jun 25, 2019 at 11:11 AM
    #295
    BigWalker
    Pete
    2019 tundra SR TRD
    Yes im building the plate, its very simple flat 3/16” aluminum plate 11” X 6”. It will be bolted to the BB mount and i will install nutcerts that the compressor bolts to
    The compressor bolt pattern is 7” X 5” c to c
  26. Jun 25, 2019 at 11:21 AM
    #296
    azTony
    azTony New Member
    Tony
    None... yet
    The Extremeaire Magnum and the Extremeaire High Output (your model I believe) have the same bolt pattern. Looking at your picture I assumed it was already mounted to the plate of the BB mount. Why did you have to build an additional plate?
  27. Jun 25, 2019 at 1:05 PM
    #297
    BigWalker
    Pete
    2019 tundra SR TRD
    The compressor has a 5” wide pattern
    The BB top plate is 4”
    Second the compressor does not sit far enough back so it is moved forward
    I will fab the plate tomorrow and take a few pictures
    Cheers
  28. Jun 25, 2019 at 9:59 PM
    #298
    Bannock452
    Bannock452 [OP] New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    Thank you for responding to these questions Pete! I appreciate it. And yes this mount will be able to hold over 100lbs of force if not maybe more. Did some stress testing in solidworks (shown in previous post photos) and rated the compressor weight to 100lbs and still no signs of weak points. Just a simulation but it’s way overkill. Thanks again and glad to see other compressors able to be used also.
  29. Jun 26, 2019 at 4:40 AM
    #299
    azTony
    azTony New Member
    Tony
    None... yet
    I am anxious to see @BigWalker's solution to the Extremeaire. I would like to see if there is something that could be done that could help your design be more flexible and open to a broader audience.
    How do I get one of the dual ARB brackets?
  30. Jun 26, 2019 at 5:42 AM
    #300
    Berdine
    Berdine Ironhide
    Binghamton, NY
    2016 MGM Crewmax TRD
    What compressor you mounting with it?
