Boerseun's 2018 TRD Sport
Discussion in '2.5 Gen Builds (2014-2021)' started by Boerseun, Feb 6, 2018.
  1. Dec 31, 2019 at 1:45 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    how much did you pay? I need one.
  2. Dec 31, 2019 at 2:04 PM
    Boerseun
    Boerseun [OP] MGM XP-Series
    Ferdie
    Sarasota Florida
    Just over $100. Maybe $110. Through Megazip.
    georgiey22[QUOTED] likes this.
  3. Dec 31, 2019 at 2:18 PM
    CNE0207
    CNE0207 New Member
    Arvada, CO
    2020 Cement CM Limited
    Looks awesome man. Nice work.
    Boerseun[OP] likes this.
  4. Mar 8, 2020 at 1:07 PM
    Millski
    Millski New Member
    2020 Sport Premium Crewmax
    Nada
    How much of a gas hit was it with that lift and tires?
  5. Mar 8, 2020 at 2:34 PM
    Boerseun
    Ferdie
    Sarasota Florida
    @Millski , about 3 MPG when calculated straight from the odometer, but if you keep in mind that the odometer is now off due to the bigger circumference of the wheel (by about 7%), it is probably only 2 MPG since I actually travel further with every rotation of the wheel.
  6. Mar 8, 2020 at 2:37 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Congrats!
  7. Apr 22, 2020 at 8:59 AM
    Boerseun
    Ferdie
    Sarasota Florida
    One of those WOW moment little mods that makes a huge difference.
    JDM ASTAR LED turn signal upgrade.
    BEFORE:
    AFTER:
  8. Apr 22, 2020 at 9:35 AM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Sharp looking fastest truck, like mine! Great choice. LOL
    Boerseun[QUOTED][OP] likes this.
  9. Apr 24, 2020 at 5:43 AM
    gupster88
    gupster88 New Member
    Brett
    Charleston, WV
    2019 Toyota Tundra SR5 TRD Off-Road
    Wow, that turn signal upgrade did make a big difference!
  10. Apr 24, 2020 at 6:01 AM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    same as the OP, I had mine replaced, big difference.
  11. Apr 24, 2020 at 6:07 AM
    gupster88
    Brett
    Charleston, WV
    I’ll be adding this to my to-do list for sure!
  12. Aug 23, 2020 at 2:41 PM
    Boerseun
    Ferdie
    Sarasota Florida
    Did a little painting today. I used VHT Plastic paint. Will see how it holds up.
    IMG_20200823_150921.jpg IMG_20200823_155950.jpg IMG_20200823_165435.jpg IMG_20200823_172815.jpg
    Also installed this:
    Edit 10/11/2021 update on "scoop sticker"
    RobertD likes this.
  13. Mar 31, 2021 at 3:12 PM
    LAPlatinum
    LAPlatinum New Member
    Great looking truck borther! If you don't mind me asking what 3"/1" set up do you have?
  14. Apr 1, 2021 at 5:24 AM
    Boerseun
    Ferdie
    Sarasota Florida
    @LAPlatinum , thank you. I love this truck.
    My leveling lift is just a Rough Country spacer in the front and blocks in the back. It is actually 3"/1.5". I only had 1.5" lean, so the 3"/1.5" puts it exactly level.
    I use the truck every day on construction sites (200 to 500 acreas of ploughed over land development projects) so it gets mild offroad use very regularly and I have not had any issues with the setup. That being said, since the Bilstein 5100 setup would be only a couple hundred bucks more I would probably do that, or something similar to that, next time in lieu of the spacers; just because... as I said I don't have any issues with this setup.
    LAPlatinum[QUOTED] likes this.
  15. Apr 1, 2021 at 11:50 AM
    LAPlatinum
    For sure I get you brother. When I saw pictures of your truck i was like this guy right here has great taste and knows how to take care of their truck. I've been doing alot of research on here about lifting and honestly im still not sure what route to go. At first I was thinking the TRD Pro shocks, 6112/6150 combo, or falcons. Just keep it simple leveled may do a uca for better adjustment, keeping my stock 20 i actually like em just get some bigger tires on them and were good. not trying to spend money on the other brands but i get it you get what you pay for.
  16. Apr 1, 2021 at 1:03 PM
    RobertD
    Robert
    DFW, Texas
    How's your engine cover holding up? I'm thinking about painting mine soon. Any tips or things you would have done differently?
  17. Apr 5, 2021 at 7:04 PM
    RobertD
    Robert
    DFW, Texas
    When you used your VHT, did you use any primer or just spray the red/silver straight onto the black cover?
  18. Apr 5, 2021 at 7:48 PM
    Boerseun
    Ferdie
    Sarasota Florida
    @RobertD I just sprayed straight onto the plastic. The VHT is formulated for that.
    RobertD[QUOTED] likes this.
  19. Apr 5, 2021 at 7:51 PM
    #49
    Boerseun
    Ferdie
    Sarasota Florida
    Sorry, I didn't see this post until now. The VHT is very easy to work with. Just make sure your masking tape sticks good, especially around bends it tends to lift. And start with very thin mist coats. It helps to seal the edges of the tape without bleeding underneath it.
  20. Apr 5, 2021 at 7:53 PM
    #50
    RobertD
    Robert
    DFW, Texas
    Awesome, thanks! Honestly if anyone around carried the blue VHT I would have tried this past weekend to paint it. Appreciate the advice and for sharing what you did. It really makes a difference in the engine bay.
  21. Dec 6, 2021 at 5:40 AM
    #51
    Boerseun
    Ferdie
    Sarasota Florida
    For my records
    100,000 miles 12/5/2021
    3 years 10 months±
    RobertD likes this.
  22. Sep 23, 2022 at 10:48 AM
    #52
    Boerseun
    Ferdie
    Sarasota Florida
    And so it comes to an end. I am sure going to miss the 2018, the V8, the memories...
    But it was time to move on to the next one.
    ToyoMafia and Taco-Spike like this.
  23. Sep 23, 2022 at 10:56 AM
    #53
    Taco-Spike
    Two Trucks
    Congrats!
  24. Sep 23, 2022 at 11:23 AM
    #54
    RobertD
    Robert
    DFW, Texas
    It will be fun to see what you do with this one!
  25. Sep 23, 2022 at 1:04 PM
    #55
    Boerseun
    Ferdie
    Sarasota Florida
    Nothing serious planned yet. (2018 did not really have anything very extravagant either - just small touches)
    I will start a build page and see where it goes. The XP package already added a bunch of little things that I would have done to a standard SR5 anyways.
