boardude's [YODAGAN] SC Build
Discussion in '2.5 Gen Builds (2014-2021)' started by boardude, Jun 14, 2015.
  1. Dec 8, 2017 at 8:02 AM
    #571
    boardude
    boardude [OP] I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I can't wait!! Fronts go on tomorrow!! :transformer::yay:
    4x4_Angel and blue16[QUOTED] like this.
  2. Dec 8, 2017 at 8:06 AM
    #572
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Looking forward to seein pics!
    boardude[QUOTED][OP] likes this.
  3. Dec 8, 2017 at 8:41 AM
    #573
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Not going to be able to sleep tonight
  4. Dec 8, 2017 at 10:19 AM
    #574
    TheBeast The Beach
  5. Dec 8, 2017 at 3:24 PM
    #575
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Man, that's gonna be sweet (not that it's not already).
    Hey, after you get all this goodness dialed in and you're maybe looking to dump your Pro setup, I may be interested.
    I'm just down the street too. Easy peasy :anonymous:
  6. Dec 8, 2017 at 5:12 PM
    #576
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Yeah I can't wait! The Pro suspension will def be up for grabs so I'll let you know for sure.
  7. Dec 8, 2017 at 5:15 PM
    #577
    Taco-Blender
    AZ
    2010 DC 4x4
    Appreciate it. Thanks
  8. Dec 8, 2017 at 6:58 PM
    #578
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    Epic brother looking forward to the pics and adventures
  9. Dec 9, 2017 at 6:23 PM
    #579
    TheBeast The Beach
    sooooo...must be night time in AZ now... :spy::spy:
  10. Dec 9, 2017 at 6:25 PM
    #580
    Stewie
    Stewie New Member
    2016 Crew Max
  11. Dec 9, 2017 at 6:38 PM
    #581
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    I’m still waiting for the final product too.....
    :drool: :popcorn:
    boardude[OP] likes this.
  12. Dec 9, 2017 at 8:17 PM
    #582
    TheBeast The Beach
  13. Dec 9, 2017 at 9:34 PM
    #583
    Eclipsed & Floating
    Voluptuous Whitey
    I bet he doesn't really have new suspension.....................
    boardude[OP] and joonbug like this.
  14. Dec 9, 2017 at 11:06 PM
    #584
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  15. Dec 10, 2017 at 10:46 AM
    #585
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Fronts all done with perfect alignment!!
    Here's some pics from the install and also some tips for @joonbug and anyone else looking at installing these themselves.
    From previous experience it's easier to unbolt the sway bar when the truck is on the ground before you lift it and disconnect the links. The ends of the sway bar need to be trimmed so it doesn't make contact with the lower shock. Seems overkill but these things are beefy and as soon as you throw them on you'll see exactly where it could cause some major damage if not.
    Then one of the bump stops on each side needs to be trimmed down
    Once these were grinded down for more clearance we threw in the drivers side coilover. The first thing we noticed was the top collar was positioned in a way that the elbow that fed the resi was pointed towards the side of the upper arm which would cause clearance issues. Called up Joey and he mentioned that the collar could be spun around to reposition the elbow. This is way easier to do when the coilover is out so something to think about before you install. He also mentioned that the passenger and driver could be switched since these are fitting oriented. After looking at the two it was actually easier to install the passenger on the driver side. So big thanks to @olsin6 for the quick help!
    Once these were in place we found it easiest to bolt the bottom of the shock first and then jack up the LCA so the shock would move into place so we could screw in the top. These screw downwards into the top so this made it a lot easier than trying to hold up the shock.
    And BOOM! Oh yeah, go get yourself an 11mm hex socket for the sway bar link. They provide new bolts for the upper link and it's an 11mm, why 11mm? I have no clue since every kit I've seen only goes to 10mm lol.
    Cranked up the drivers side about 1/4" to account for the yota lean and it's almost sitting perfectly level. I'll probably adjust it again once the RXT springs and shocks go on.
    So far the ride quality up front is noticeably better! My rear still kinda bucks around from the AAL so that takes away from it a little. Can't wait to get the rears on!
    ColoradoTJ, monaco730, Newm and 16 others like this.
  16. Dec 10, 2017 at 10:56 AM
    #586
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    :eek: Oh lawd!!! :drool::drool::drool::drool:
    Thanks for the tips Kris.
  17. Dec 10, 2017 at 11:15 AM
    #587
    Taco-Blender
    AZ
    2010 DC 4x4
    :drool::drool::drool::drool: is right!
    That's one sweet truck.
  18. Dec 10, 2017 at 12:10 PM
    #588
    TheBeast The Beach
    very nice. does the kit comes with different sway bar links ? even with Kings the sway bar end is really close from the shock body.
    I had a thread on it so I guess the Icons is even closer if you have to grind them.
    https://www.tundras.com/threads/front-sway-bar-end-links-and-king-coilovers.16785/
    MY guess is you can probably get rid of the sway bar seeing how your suspension is now able to handle pretty much everything.
  19. Dec 10, 2017 at 12:20 PM
    #589
    TheBeast The Beach
    it's a tight fit. Did everything clear at full droop ? I bet it will ride amazing when the rear is on and you fine tune everything
  20. Dec 10, 2017 at 12:42 PM
    #590
    Eclipsed & Floating
    Voluptuous Whitey
    Holy crap!!!! I guess you weren’t blowing smoke!!
  21. Dec 10, 2017 at 12:59 PM
    #591
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Yeah new sway bar links were included. They are lower profile I think to make more clearance with the bottom of the shock.
    TheBeast[QUOTED] likes this.
  22. Dec 10, 2017 at 1:01 PM
    #592
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Yeah it's super tight but we cycled the suspension as much as we could. Since most of the suspension moves together it stays clear but I can see why it has you grind down a few things lol
  23. Dec 10, 2017 at 1:01 PM
    #593
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Would I ever lie to you bumper bro?!
  24. Dec 10, 2017 at 6:55 PM
    #594
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    Hey @boardude nice truck!! First one I’ve seen with 3.0’s
    Just wondering why you don’t run it without the front sway bar? When I removed mine I noticed an improved/smoother ride on and off road.
  25. Dec 11, 2017 at 2:07 PM
    #595
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Yeah I'll most likely rip it out here shortly. I tow and drive highways often which is why I think I've kept it on this long
    jc153[QUOTED] and TheBeast like this.
  26. Dec 11, 2017 at 2:17 PM
    #596
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    I'll pay you in beer if you help me install mine whenever i get it
  27. Dec 11, 2017 at 2:46 PM
    #597
    TheBeast The Beach
    @joonbug :spy::spy::stirthepot:
    joonbug and dcsleeper408 like this.
  28. Dec 11, 2017 at 3:03 PM
    #598
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Haha. It's like the same convo from his build thread.
    joonbug and TheBeast[QUOTED] like this.
  29. Dec 11, 2017 at 3:03 PM
    #599
    TheBeast The Beach
    3.0 crew....:spy::spy::threadjacked:
    joonbug and boardude[OP] like this.
  30. Dec 11, 2017 at 3:05 PM
    #600
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Done! Better yet get a keg and throw a Tundras.com mod and bbq!
