boardude's [YODAGAN] Build
Discussion in '3rd Gen Builds (2014+)' started by boardude, Jun 14, 2015.
  1. Jan 12, 2018 at 5:34 PM
    #721
    TheBeast El CreepO
    got a pic of where you lift ? thanks broGAN
    4x4_Angel likes this.
  2. Jan 12, 2018 at 5:38 PM
    #722
    boardude
    boardude [OP] I am Batman
    Kris
    Tucson, AZ
    2015 Inferno Ex-Pro
    Your mom
    Thank man I appreciate it! I will def let you know
    4x4_Angel and Taco-Bender like this.
  3. Jan 12, 2018 at 5:40 PM
    #723
    boardude
    Kris
    Tucson, AZ
    2015 Inferno Ex-Pro
    Your mom
    Not sure about kings but a full 360 turn on the icons is about 1/4". I did 2 full turns and leveled it out pretty nicely.
    4x4_Angel and TheBeast like this.
  4. Jan 12, 2018 at 5:43 PM
    #724
    boardude
    Kris
    Tucson, AZ
    2015 Inferno Ex-Pro
    Your mom
    I lift in the center of my skid. Theres a support right under that bolts to the cross member. You could just jack right under the LCA
  5. Jan 13, 2018 at 9:00 AM
    #725
    KevinK
    KevinK SGU - High Speed Overlander
    Gilbert, Arizona
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    @boardude what is your typical bed weight? Do you have much in the bed on a regular basis? Do you change the weight based on how you’re using the truck (day trip, camping, whatever)?
    I need to understand the rxt settings options to see where I need to start once we get them.
    I’m terrible with names, are you in the Arizona Tundras Facebook group? I just realized you’re in Tucson. We’re in Gilbert.
    I’ll apologize now if we’ve already met five times... I was probably drunk.
    Wvmoonshiner and 4x4_Angel like this.
  6. Jan 13, 2018 at 9:51 AM
    #726
    boardude
    Kris
    Tucson, AZ
    2015 Inferno Ex-Pro
    Your mom
    Lol no worries I don't think we've met. I am on the AZTG but I don't go on much, FB in general, too much noise. I have seen some of your pics and videos on there :spy::spy::spy:. I'm in phx quite a bit, every week right now for work so trying to get to more meets up there.
    I usually don't have any weight in the bed when I'm DDing but that is probably going to change soon. Looking at the BAMF low profile bed rack. I do tow a boat and for lake/camping trips I'll have about 300 - 500 lbs in the bed plus another ~400 lbs in tongue weight. My current setup now handles it pretty well with limited squat so looking to get the same result.
    For the rxt options, this is from the install notes:
    Option #1: Standard (as shipped) = 30% reduced ride rate from stock. (+1.75” over stock unloaded) - Recommended for constant loads up to 250lbs.
    Option #2: Additional leaf #3 = 20% over standard ICON configuration. (+3.00” over stock unloaded) - Recommended for constant loads from 250-500lbs. (+250lbs = 2.00” lift | +500lbs = 1.35” lift)
    Option #3: Standard + Additional leaf = 40% over standard ICON configuration. (+4.00” over stock unloaded) - Recommended for constant loads from 500-750lbs. (+750lbs = 1.50” lift)
    I'm going to try option 1 with toytec shackles set at 1". If this doesn't give me the support that I need then I'll go to option 2 with the stock shackles. I have a feeling that 3" in the rear is going to be too high and I don't want a rake. Let the trial and error begin.
    TheBeast, 4x4_Angel and 831Tun like this.
  7. Jan 13, 2018 at 10:17 AM
    #727
    Cyrus
    Cyrus New Member
    Cyrus
    Maryland, USA
    2014 Tundra 1794 Edition TRD Supercharged
    Truly a great build!! Well done sir.
  8. Jan 13, 2018 at 10:22 AM
    #728
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    “Little ones.....”
    4x4_Angel and boardude [OP] like this.
  9. Jan 13, 2018 at 10:36 AM
    #729
    boardude
    Kris
    Tucson, AZ
    2015 Inferno Ex-Pro
    Your mom
    Thanks bud!
  10. Jan 13, 2018 at 3:31 PM
    #730
    KevinK
    Gilbert, Arizona
    Tundras to Sedona
    Right on - let me know next time you come up to phx. I’m in Gilbert and so are a bunch of other good folks. Happy Hour meetup maybe if you have time.
    I wonder how those springs will respond to the longer shackle. I’m interested in your results for sure. And thanks for posting their option descriptions!
  11. Jan 13, 2018 at 4:17 PM
    #731
    boardude
    Kris
    Tucson, AZ
    2015 Inferno Ex-Pro
    Your mom
    For sure man! We should plan for something next week or the week after that. I'll message ya
    4x4_Angel and KevinK like this.
  12. Jan 13, 2018 at 4:30 PM
    #732
    Eclipsed & Floating
    Voluptuous Whitey
    HMMMMMM!!! Do i move to California or Arizona...................
    This is the residing thought that continues to circle my brain and keep me awake recently
    831Tun and Samoan Thor like this.
  13. Jan 13, 2018 at 4:55 PM
    #733
    boardude
    Kris
    Tucson, AZ
    2015 Inferno Ex-Pro
    Your mom
    Think of it this way, AZ is the sister state of CA but cost of living is a fraction of the cost. Plus I'm in AZ so why is this even a question?!!?
  14. Jan 13, 2018 at 4:56 PM
    #734
    boardude
    Kris
    Tucson, AZ
    2015 Inferno Ex-Pro
    Your mom
    Not too mention if he wasn't building a new house I'm pretty sure @Sean266 would be moving here :D
  15. Jan 13, 2018 at 5:19 PM
    #735
    T-Rex266 T-Rex Staff Member
    If AZ had Kaiser we would be there :)
  16. Jan 13, 2018 at 5:22 PM
    #736
    Eclipsed & Floating
    Voluptuous Whitey
    They do have Kaiser rolls, with onions too
  17. Jan 13, 2018 at 5:24 PM
    #737
    Eclipsed & Floating
    Voluptuous Whitey
    Finding a job would be the first step. Do you have contacts down there that might prove fruitful? If so, i'm gonna take a serious look. If not, i'm still going to take a serious look. You're in Tuscon, right? How far is that from Flagstaff? My son needs a ski hill
  18. Jan 13, 2018 at 5:25 PM
    #738
    Grey Wolf
    Grey Wolf ELITE Grey Wolf Crew
    Aurora CO
    2007 Slate Metallic 5.7L Tundra DC SR5 4X4
    18"X9" FN BFD's rims, 295/70R/18E Cooper Discoverer STT Pro's, and S/T Maxx's, upgraded to Old Man EMU coil-overs/shocks. Toytec shackles. Custom dual true dual exhaust. Body Armor Rock Steps, Smittybilt X20 winch, DV8 winch bumper
    And firearm laws in AZ are night and day different than in Kommiefornicatia.
  19. Jan 13, 2018 at 5:31 PM
    #739
    Kaiser Permante. We get free benefits as my wife works for them and want to retain that :) can’t beat a $10 Co-pay, $5 scripts, etc
  20. Jan 13, 2018 at 5:31 PM
    #740
    boardude
    Kris
    Tucson, AZ
    2015 Inferno Ex-Pro
    Your mom
    This is true. We're still a bunch of Cowboys down here
  21. Jan 13, 2018 at 5:33 PM
    #741
    boardude
    Kris
    Tucson, AZ
    2015 Inferno Ex-Pro
    Your mom
    I'll have to talk with my freemason friends and see what they can do
    4x4_Angel, Taco-Bender and T-Rex266 like this.
  22. Jan 13, 2018 at 5:33 PM
    #742
    Grey Wolf
    Aurora CO
    Yeah, and people don't freak out when your out plinking with an AR type that can hold more than no rounds at all......
  23. Jan 13, 2018 at 5:34 PM
    #743
    Taco-Bender
    Taco-Bender New Member
    Tucson
    2010 DC 4x4
    We're from CA (Sacramento area) and visit friends and relatives often. All they talk about is how they're going to get from point A to point B in the least amount of traffic, how they're getting taxed out the A$$, and how they can't wait to retire and get the F out of there.
    The only thing we miss, even after 20+ years is the water recreation. Other than that, you can have it.
  24. Jan 13, 2018 at 5:35 PM
    #744
    boardude
    Kris
    Tucson, AZ
    2015 Inferno Ex-Pro
    Your mom
    Depends on what line of work you are in... I live in Tucson, work for a firm based out of Columbus, OH, and service clients all across the country. I do have strong ties with the Universities in AZ...
    Flagstaff is about ~3 hours north
  25. Jan 13, 2018 at 5:36 PM
    #745
    Eclipsed & Floating
    Voluptuous Whitey
    OK. that sounds terrible so i think that idea will be out the window soon
    zcarpenter92 and boardude [OP] like this.
  26. Jan 13, 2018 at 5:37 PM
    #746
    boardude
    Kris
    Tucson, AZ
    2015 Inferno Ex-Pro
    Your mom
    Nope, that's actually a good way to make friends out here lol
    4x4_Angel and Grey Wolf like this.
  27. Jan 13, 2018 at 5:38 PM
    #747
    Grey Wolf
    Aurora CO
    Even the water rec there was becoming way too crowded no matter where you went by the time I split in 2004.
  28. Jan 13, 2018 at 5:40 PM
    #748
    boardude
    Kris
    Tucson, AZ
    2015 Inferno Ex-Pro
    Your mom
    We have plenty of lakes around. We go to Apache and Roosevelt, a few hours from Tucson, many time throughout the year.. that's right, throughout the year since the weather is sooo nice.
  29. Jan 13, 2018 at 5:41 PM
    #749
    Eclipsed & Floating
    Voluptuous Whitey
    The reason i was thinking CA was to chase the NorCal crew and find me some ski hills....maybe move back to Tahoe was my thought process. But, then again, it's incredibly expensive and the CO mountains have kinda burned me out on the high cost of living thang
    boardude [OP] likes this.
  30. Jan 13, 2018 at 5:43 PM
    #750
    Grey Wolf
    Aurora CO
    NorCal is nice. The further away from SF the better, like way north near Oregon border, east or west.Think Shasta...:thumbsup::thumbsup::thumbsup:
    TheBeast, 4x4_Angel and boardude [OP] like this.
