BMC w/295/70/18, Method NV305 and Camburg UCA?
Discussion in '2.5 Gen Tundras (2014-2021)' started by grichg, Oct 16, 2020.
  1. Oct 16, 2020 at 6:28 PM
    grichg
    grichg [OP] New Member
    rich
    anyone running that combo and NOT needing BMC? Bought the UCA today and sounds like i may or may not need the chop.
    tia
  2. Oct 16, 2020 at 7:43 PM
    Zero One Actual
    What lift do you have and what’s the backspacing on those Methods?
    grichg[QUOTED][OP] likes this.
  3. Oct 16, 2020 at 8:19 PM
    Tundrafan23
    Tundrafan23 New Member
    You should be fine with any lift over 2.5 inches, if I recall those NV305 have a +25 offset, if so you won't need a BMC
  4. Oct 16, 2020 at 10:15 PM
    grichg
    rich
    +25 on the wheels with 6112 at 3" lift
  5. Oct 16, 2020 at 10:16 PM
    grichg
    rich
    3" and yes plus 25
    thanks
  6. Oct 17, 2020 at 5:27 AM
    Zero One Actual
    I have the exact same lift and backspacing and you will not need a chop with that. I also have Total Chaos UCAs which helps a lot also. Do you have stock or after market upper control arms?
  7. Oct 17, 2020 at 6:48 AM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    Im at 3" lift on same 18x9, +25 wheels and 35x12.5 tires.
    No chop needed and still on stock upper arms.
    I have a set of RC arms to put on for better caster but havent gotten around to it yet since it drives so nice as-is.
    I even managed to get the mudflaps back on and ziptied them for clearence. They just barely touch at full lock and im fine with that.
    When I get the upper arms on and lowers cranked forward I should have plenty of clearence.
  8. Oct 17, 2020 at 7:54 AM
    grichg
    rich
    currently on stock UCA but installing Camburg UCA next week.
    Zero One Actual likes this.
  9. Oct 17, 2020 at 7:59 AM
    grichg
    rich
    what it looks like
  10. Oct 17, 2020 at 11:25 AM
    Zero One Actual
    Ya with the camburgs and caster adjustment, you will be totally fine.
    Truck looks sick.
  11. Oct 17, 2020 at 11:34 AM
    grichg
    rich
    ok, good info, thanks. Im loving it!
  12. Oct 17, 2020 at 1:41 PM
    Zero One Actual
    I’m on 285/75R18 Toyos with Method 315s and Total Chaos UCAs and Bilstein 6112s on top setting and have zero issues.
    Yes that’s gold.
  13. Oct 17, 2020 at 3:02 PM
    grichg
    rich
    aaaaaaaaalmost bought those :)
  14. Oct 17, 2020 at 3:24 PM
    Zero One Actual
    On your color it would look awesome. I know most Tundra folks aren’t gold fans like the taco and 4Runner community.
  15. Oct 17, 2020 at 5:40 PM
    tundra4466
    tundra4466 New Member
    2020 1794 4x4
    I’m running same tire size on +18 methods on 3” lift with spc uca and did not need the bmc either, just some mud flap trimming. I’m not sure if the camburgs adjust different though.
    grichg[OP] likes this.
  16. Oct 21, 2020 at 8:26 AM
    grichg
    rich
    Got all installed and Aligned. Pre-Alignment a slight rub then post was no rub by a Butt-Hair. Thanks for all the responses!
    TX_Inferno likes this.
  17. Oct 21, 2020 at 9:32 AM
    Zero One Actual
    Pics or it never happened.
  18. Oct 21, 2020 at 9:37 AM
    grichg
    rich
    is that how it works here lol.....
    I cant even sell anything due to lack of posts so hopefully these go towards that :)
    Will post a couple later
  19. Oct 21, 2020 at 9:40 AM
    Zero One Actual
    Don’t worry. One day you will be over a thousand posts thinking half of them are from the bathroom.
  20. Oct 22, 2020 at 12:16 PM
    grichg
    rich
    Boom
    marky671 likes this.
