Blue tooth Mic problems W/ new head unit,..
Discussion in '1st Gen Tundras (2000-2006)' started by Jy8466, May 24, 2019.
  1. May 24, 2019 at 1:12 PM
    Jy8466
    Jy8466 [OP] New Member
    2012 TUNDRA SR5
    Calling for help just put a Android head unit I'm my '12 tundra having problem with the mic, the head is not compatible with the factory Mic, it gives a static & echos on the other end of the phone, so i brought a new Mic and installed with the harness that came with the head unit and still having the same static echoes, and recommendatilns,...
  2. May 24, 2019 at 1:17 PM
    VTYOTA
    VTYOTA I DECLARE BANKRUPTCY!!
    Howard
    'Merica
    2014 SS CM TRD
    What head unit and where did you put your mic? I would imagine it would feedback/echo if it is too close to the speakers.
  3. May 24, 2019 at 1:20 PM
    TheBeast The Beach
    make sure MIC is pushed all the way to back of rear Head unit. I installed mine top left corner of the windshield.
    could also be a bluetooth issue between your phone and head unit. check bluetooth settings on head unit and phone
  4. May 24, 2019 at 1:23 PM
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
  5. May 24, 2019 at 1:32 PM
    Jy8466
    2012 TUNDRA SR5
    I installed the mic in the same location my existing mic, up in the ceiling console,...
  6. May 24, 2019 at 1:41 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I have a similar issue with my kenwood mic. I thought the factory mic was perfect. I wish someone made an adapter to use that for aftermarket units
  7. May 24, 2019 at 2:39 PM
    Jy8466
    2012 TUNDRA SR5
    Yea right such a head ache,...
