Blue Ribbon 4x4 Build Thread
Discussion in '2.5 Gen Builds (2014-2021)' started by BlueRibbon4x4, Jul 25, 2020.
  1. Mar 8, 2023 at 8:54 AM
    #961
    BlueRibbon4x4
    BlueRibbon4x4 [OP] Let’s color match it
    Geno
    2015 Blue Ribbon 4x4
    Thanks Rey!!
  2. Mar 9, 2023 at 9:44 AM
    #962
    rocsteady
    rocsteady New Member
    Dave
    New Jersey
    2021 Super White SR7 Double Cab SX
    Oh great, now I hate my door panels...damn you Geno.
  3. Mar 9, 2023 at 4:03 PM
    #963
    BlueRibbon4x4
    Geno
    :rofl::rofl:
  4. Mar 9, 2023 at 5:11 PM
    #964
    BlueRibbon4x4
    Geno
    Rear doors done and installed. Really dig the look, and the wife loves it.
    9891FFC6-5915-4D1F-9225-CA2E00227E23.jpg 034F085E-115A-4428-840D-AFEBD4B4B207.jpg 9A1F297D-08D3-4EBF-8B74-70674DE1B6F6.jpg
    bulldog93, GAknight, RobertD and 2 others like this.
  5. Mar 9, 2023 at 5:16 PM
    #965
    18" TRD Off Road Wheels
    Tell me you don't own a Pug without telling me you don't own a Pug. :rofl: That suede looks nice, probably feels amazing, but would not survive my dog.
  6. Mar 9, 2023 at 6:58 PM
    #966
    BlueRibbon4x4
    Geno
    I got a Pit and a Terrier. I’ve already figured out that the suede is a hair magnet. :rofl:
    bulldog93 and GODZILLA[QUOTED] like this.
  7. Mar 9, 2023 at 7:01 PM
    #967
    Oh, I bet. My little dog sheds like a couple hundred pound huskies. It's insane. That, and she stands on that portion of the door to look out the window. The Taco's OEM panel takes it well, but suede would be covered in gouges, hair, and snot. Did I mention she blows her nose on the windows? No? Well she does. :laugh:
    bulldog93 likes this.
  8. Mar 9, 2023 at 7:23 PM
    #968
    BlueRibbon4x4
    Geno
    :rofl: I figured a pug just blows her nose as a part of every day breathing. They sure are sweet as hell though.
  9. Mar 9, 2023 at 7:24 PM
    #969
    Correct on both accounts. :fistbump:
  10. Mar 11, 2023 at 10:54 AM
    #970
    BlueRibbon4x4
    Geno
    So I know that I breezed through the door panel stuff, so for the front doors I’ll be a little more thorough in my work explanation.
    First, I pulled the door panels, we all know @2020Platinum made the perfect video showing this, and who can compare with the sweet home Chicago(?) accent. I pulled off the upper interior padding and removed the door handle screws. For the rears, I just masked them, and then @RobertD told me to sack up and pry the silver cover off - a much better idea.
    7CCC7C89-C93C-4CA9-869B-DA0C5562B9FF.jpg 920748E0-CE58-42B9-B5FD-D505F43E3234.jpg
    Then I pulled all the torx screws holding the silver strip and upper upholstered panel. Using a sharp 3/8” bit, I drilled out the melted “rivets” holding these pieces. The upper upholstered panel has metal tabs attached to the window seal that need to be straightened out. Plastic bonder epoxy will be used to put these back together.
    A272FD40-7B4B-48C7-9E27-2CDA8A2ECB48.jpg 434426AB-5DEA-49E6-84FB-3E329666D982.jpg 75A4DBCF-5B45-471D-AD34-2429854006EF.jpg 79F3978C-99A7-404E-8F1B-B45AC6EC1A3C.jpg DAC39C40-67FB-468B-B6DE-FDFB7B81771B.jpg AE116583-8494-4ABC-925F-C95715D3F1D7.jpg 24495396-E1B0-4803-A3A5-46E920C32299.jpg FC003C74-BABD-4E4F-8060-8E614A22C7F1.jpg
    Then using a red scotch brite pad, I scuffed up the pieces till the shine was gone, so the paint has something to adhere to. Primer went down, and SEM will go down in a bit.
    5965B474-3828-4592-9815-0CDA081630C1.jpg BC8E4E7E-7608-4D4A-BD8E-98D4E08D470A.jpg B94CCDBE-6BCD-4033-A853-8D088CB88AB9.jpg
  11. Mar 11, 2023 at 6:54 PM
    #971
    BlueRibbon4x4
    Geno
    After painting with SEM and matte clear coat, I worked on the upholstered panels. After cutting the suede to size, I cleaned the panels with alcohol and sprayed the panel and back of suede with Gorilla glue spray adhesive. Then I just wrapped over the existing upholstery and trimmed it to size.
    95919940-CB44-41C9-AA98-4176B602ACF9.jpg C7F0E1A3-D8A6-4180-89E0-B9F0E5A7B882.jpg EA9FE82F-639A-49D1-844F-ECB1633580EE.jpg 810CFFD2-4D4F-474C-9502-E3030B50CE79.jpg 67B1426F-AB8E-4FE9-94CA-293A09946105.jpg 94DB08CB-4F62-475D-A13B-DB0BA1CEE598.jpg 844825EF-6FDA-424F-AC65-C9B97E162C0A.jpg 3EF7009C-558B-44B9-B5FE-5D4CA1302EA1.jpg
    aelarson, bulldog93, GAknight and 6 others like this.
  12. Mar 12, 2023 at 1:32 PM
    #972
    BlueRibbon4x4
    Geno
    Putting things back, making sure to line up the upholstered panel with the metal clips in the window guide, aligning the once silver strip with the guide pins, and snapping the door handles back together. The door handles came out super clean, thanks to @RobertD. Then mixing the plastic bonder epoxy and filling the old plastic “rivets”. Plastic epoxy is very important here, as I’ve used regular epoxy before and once dried, peels right off the plastic. Once the panels are installed back on the doors, make sure your windows go up and down freely. Years ago, I took the panels on and off and something snagged the inside of the window, scraping my tint. I took the door panel off, checked, found nothing, and put it back on and it was great. So who knows sometimes.
    I did get a question about the self-etching primer. It’s what I had on hand, and I didn’t put any thought because my mind was centered on the upholstery. Normal procedure is Bulldog adhesion promoter, then paint. I’ve used this self etching primer on many plastics, and it works great, leaving it very dry and sandable. Other paints I’ve run into that aren’t plastic friendly get really tacky and don’t seem to dry at all.
    I’m super happy with the result, and now my eye is searching for other places for the suede. I’m thinking about the area above the glove compartment, under the airbag.
    9268CA64-B6AA-4EBE-8C42-4FD65FDFC31C.jpg F0561D82-8E45-43C7-8F61-291261574C99.jpg 609C0AFB-1B95-46E3-8168-A5754D4AF15D.jpg E7504674-76F1-4D4C-94DF-2A8CE6A7F858.jpg CD0D3431-54A2-4C0D-B3EE-6AB187D63DE4.jpg DCA06036-2EE7-4A97-B334-7522A0E5EADC.jpg
  13. Mar 13, 2023 at 6:19 PM
    #973
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Lookin good Geno!
    BlueRibbon4x4[OP] likes this.
  14. Mar 13, 2023 at 6:57 PM
    #974
    BlueRibbon4x4
    Geno
    Thanks Patrick!!
    2020Platinum[QUOTED] likes this.
  15. Apr 1, 2023 at 3:01 PM
    #975
    BlueRibbon4x4
    Geno
    These havr been bugging me for a while. I welded the alignment cradles. I didn’t get the SDHQ kit, I just exposed the metal and welded the tabs so they wouldn’t flatten. Honestly I thought I took more pictures than this.
    610E8E70-43AC-45DF-9605-52C56965CDD5.jpg E88419C9-8BC9-440C-8D0A-4DD6F0592770.jpg
  16. Apr 1, 2023 at 3:02 PM
    #976
    BlueRibbon4x4
    Geno
    Also took her out to the poppy fields. They bloom like crazy here. 8648DECA-3C11-429D-9D5B-E79EBC79CEE2.jpg
    reywcms, bulldog93, GAknight and 2 others like this.
  17. Apr 2, 2023 at 8:40 PM
    #977
    BlueRibbon4x4
    Geno
    Don’t know when I’ll have time to install these, but grabbed some new-to-me 5160s!!!
  18. Apr 3, 2023 at 5:29 AM
    #978
    RobertD
    Robert
    DFW, Texas
    I bet it takes you less than an hour to get these on your truck!
  19. Apr 3, 2023 at 5:38 AM
    #979
    BlueRibbon4x4
    Geno
    Shit, really? I’ve never done the rears myself.
    GODZILLA and RobertD[QUOTED] like this.
  20. Apr 3, 2023 at 7:09 AM
    #980
    RobertD
    Robert
    DFW, Texas
    Yeah, it took me an hour to jack my rear, drop both wheels, swap from the black stock to the TRD Sports, put wheels back on, and then drop back to weight on wheels.
    And that was me solo and being slightly chicken since I'd never done anything like that. I bet it would take you less time :thumbsup:
    And I'm sure you'll find something to paint blue and still be faster:rofl:
  21. Apr 3, 2023 at 4:21 PM
    #981
    BlueRibbon4x4
    Geno
    Dang, thanks!
    RobertD[QUOTED] likes this.
  22. Apr 3, 2023 at 4:36 PM
    #982
    biebs96
    PA
    Hahaha I was going say something like… and yes after several days of curing time for the primer and paint, I’ve got the rear shocks back on. Hahahaha
  23. Apr 3, 2023 at 4:50 PM
    #983
    BlueRibbon4x4
    Geno
    biebs96[QUOTED] and RobertD like this.
  24. Apr 15, 2023 at 2:41 PM
    #984
    BlueRibbon4x4
    Geno
    5160s installed last week. Couldn’t tell much of a difference from the 5100s, but at least there’s reservoirs back there now. 9C8CDDB4-4880-46C1-9F85-25DDAF9EBCD3.jpg
  25. Apr 15, 2023 at 2:42 PM
    #985
    BlueRibbon4x4
    Geno
    Wooot!!! When did I buy it? After installing the 5160s. Ha!
    8ECCDA42-7B95-4FEC-AC03-0ACD7309AFBC.jpg E78873D9-DA0F-46C6-8E40-3E14810FD364.jpg
    J&ATundra, Cfincke, bulldog93 and 2 others like this.
  26. Apr 23, 2023 at 5:55 PM
    #986
    BlueRibbon4x4
    Geno
    Just a few small things. My shift surround was looking real crappy after painting it satin clear. The scratches were really showing, so I sanded it down and cleared with a matte finish.
    Also sanded the bare metal areas of the bumper from rubbing the bottom of the grille, and sprayed with self etching primer, then sanded the whole bumper and sprayed with Rustoleum professional black. Hopefully this week I can find some time to sand it again and spray the Raptor liner. The weather here is staying nice, hopefully the wind will stay calm enough for a day.
  27. Apr 23, 2023 at 6:46 PM
    #987
    BlueRibbon4x4
    Geno
    Hit the truck with this combo. Turtle Wax Ice Seal & Shine and the Ice Spray Wax. The Seal & Shine can be a little difficult to work with, but the results are awesome. And after trying so many spray waxes, this is my favorite. Goes on and comes off super easy, and leaves a great finish on top of the Seal and Shine. I use a light mist after every wash.
  28. Apr 27, 2023 at 6:46 PM
    #988
    BlueRibbon4x4
    Geno
    My hood bulge has started looking real worse for wear. The original finish was chrome, which I plastidipped and then coated (badly) with rattle can bedliner. The finish ended up like sandpaper, which I just lived with for the past few years. So I finally sanded the bedliner smooth, cleaned with alcohol, the sprayed with Rustoleum Professional Black and then matte clear. The finish finally matches the grille. Before and After.
  29. Apr 29, 2023 at 12:24 PM
    #989
    BlueRibbon4x4
    Geno
    Working on the Badlands jack mount. I used 1”x2” 3/16” square tubing, and 3/16 flat bar for the braces, which may be overkill, but I had it on hand from another project. The Badlands skid sits flat on the square tubing, and the cross braces allow for a ratchet strap to wrap underneath to strap the jack to the mount. Two rear corner braces hold the rear. Two front flat pieces tuck under the front valance, centering the jack and pressing the jack towards the rear braces. The jack post disassembles and gets strapped underneath the jack.
    Next I’ll drill some holes in the lower cross braces and drop 8 rivet nuts in the bed. That way I can pull the mount out easily if necessary. I’m going back and forth on the decision of a lock, I have an idea for one, but the jack will only be in the truck while off-road or while the topper is on.
  30. Apr 29, 2023 at 3:39 PM
    #990
    BlueRibbon4x4
    Geno
    That’s a wrap for today. This thing is buff as hell. Eight 3/16” stainless bolts into the rivet nuts (I checked underneath before drilling). The strap holds the jack down, probably could use another strap for safety.
    Next step, paint.
