Blue Ribbon 4x4 Build Thread
Discussion in '2.5 Gen Builds (2014-2021)' started by BlueRibbon4x4, Jul 25, 2020.
  1. Aug 7, 2022 at 5:35 PM
    #751
    BlueRibbon4x4
    BlueRibbon4x4 [OP] Let’s color match it
    Geno
    2015 Blue Ribbon 4x4
    So these wired connectors go where the bulb goes for the stock license plate lights. I wired the new license plate lights to the connectors, and plugged them into the stock bulb holders. I got some 3/4” heat shrink tubing to go over the bulb holder so I could keep the harness. I just made sure the polarity was correct, and shrunk it all together. Ended up being pretty quick and easy.
    02AAAC6E-D0A4-4D5E-A7ED-64C9DC36BE5C.jpg 648B4620-48CE-441E-A05F-5BD86CF8D4E7.jpg 515E3FCE-2674-4643-97D2-949FE502D7B1.jpg EB598CC0-8960-4F8F-8EAF-2736FC5ACFA0.jpg EBF7F952-EAD6-4B3C-AC3E-646A0AEA197C.jpg 7F23B5EE-1844-4665-87F7-9857068AFFFE.jpg
  2. Aug 10, 2022 at 3:40 PM
    #752
    BlueRibbon4x4
    Geno
    Been a while since I took the dawgs on a run. Their favorite thing. D1F42331-D70E-4C68-A2E7-6A855A1AF146.jpgF342F351-37A6-4A64-BB80-24885BDEE13C.jpg
  3. Aug 14, 2022 at 11:37 AM
    #753
    BlueRibbon4x4
    Geno
    Dual workshop today. Refurbishing the table I built for my mom a few years ago and getting the air chuck ready for the new bumper. 112BA570-CF30-47A1-88A8-CA96C85C95C7.jpg
  4. Aug 14, 2022 at 3:37 PM
    #754
    BlueRibbon4x4
    Geno
    The Westin bumper has holes drilled for parking sensors. I don’t have them, so I used one for the air chuck to my compressor, and solid grommets are on the way for the other holes. Also got that 35” tire back under the truck.
    The air line leak is also gone. When I originally installed the air system, I cut all the hoses with a blade. This made all the cuts slightly oblong, and I thought this is where the leak came from, thinking the seals weren’t perfect in the fittings. When I would switch the compressor on, the pressure switch would turn off the compressor after a few seconds, so the lines wouldn’t burst. But it would kick on and off because of the leak. I grabbed a $3 tube cutter and recut the lines. No leak, and the compressor only comes on when I attach the inflator to the tires.
    82135425-24FE-40C8-BC7F-1ED9EDF44FA6.jpg 295DA6C9-718A-4BE7-B6BD-C5BF970E2BD7.jpg 5ADD512F-4D61-4906-9D8D-0F1B82EEA38A.jpg 83AC59A3-CA62-42DD-9AAF-C03AF9DA3607.jpg
  5. Aug 14, 2022 at 4:34 PM
    #755
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Can we talk more about that table? :threadjacked:
    RobertD likes this.
  6. Aug 14, 2022 at 4:56 PM
    #756
    BlueRibbon4x4
    Geno
    Yep! What’s up? Also fixing up this old chair that goes with it. I built them for my mom a few years ago. Just need sanding and new finish. Gonna burn the eyes and nose on the chair too. 4FF25D89-BA4E-462C-B90A-5BB7C3BB6F45.jpg
  7. Aug 14, 2022 at 6:00 PM
    #757
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Didn’t really have any specific questions, just looks cool as hell! Nice work!
  8. Aug 14, 2022 at 6:04 PM
    #758
    BlueRibbon4x4
    Geno
    Thanks! I finished it up, my mom just sent me this picture. She absolutely loves this stuff. EB6C1A29-693F-4C46-BA0E-0F171C990F8D.jpg
  9. Aug 20, 2022 at 4:01 PM
    #759
    BlueRibbon4x4
    Geno
    Fixing the ugly area above the rear bumper and under the tailgate. The Westin bumper sits a little lower than the stock one because the design would make the tailgate hit it while lowered. Right now I have about 1/2” clearance Clarence while the tailgate is down. I got two pcs aluminum flat bar, 2”x1/8”x36”, and a few M6 x 1” screws to fit in the stock threaded nuts on either side (thanks to @Tundra234). Trimmed, sanded, primer and Rustoleum Professional matte black, and taped off and sanded the middle area on the body where the hole for the spare tire wrench goes. The outside of each piece is held by the screws, and the center with the 3M double sided tape. I may throw a self tapper in the center later when I feel like the tape won’t hold.
    While putting this together, I noticed my taillight was loose. Seems one of the tabs broke off and was only being held by one screw. A quick repair with plastic epoxy, and she’s back in business.
    Last pic is just a porn still frame my GoPro took at about 60mph.
    BB0A6F1D-331E-4C4A-BE2A-B194929577BD.jpg 82DC5167-FDBD-424B-9B76-403A487811DB.jpg AF447B49-C3C9-47A3-B550-D4E4CC436532.jpg 9A8FDD62-9615-4090-A912-B1C847768170.jpg FC0AB97C-2AE7-41F6-9D0E-D35DFE851C57.jpg C60123CC-0F98-4F67-B362-49B53ADA3F49.jpg
  10. Aug 20, 2022 at 4:04 PM
    #760
    Looks much better!
  11. Aug 20, 2022 at 4:06 PM
    #761
    biebs96
    PA
    You know they make lights that thread into those threaded locations?
    Not sure if you are big fan of additional lighting o_O but it’s just a thought.
    Oznium Brightest Light Bolt - Flush Mount 12V LED Light for Bumper, Grille, Cars Interior, Dash, Ambient Lighting, Motorcycle w/Sleek Aluminum Housing & Screw Nut (6 mm Black, Blue LED) https://www.amazon.com/dp/B01AFU4QF4
    I went with red and run them as an always on rear DRL
  12. Aug 20, 2022 at 4:53 PM
    #762
    BlueRibbon4x4
    Geno
    Thanks for the info!
  13. Aug 20, 2022 at 4:54 PM
    #763
    BlueRibbon4x4
    Geno
    Looks good! Thanks for the heads up. :thumbsup:
    biebs96[QUOTED] likes this.
  14. Aug 21, 2022 at 7:02 AM
    #764
    BlueRibbon4x4
    Geno
    Went on a night run last night. Had a good time, but was behind someone with limited experience. They kept trying everything in 2wd, kicking up rocks and dirt at every incline. I didn’t learn from this and was following too closely coming back down the mountain. He kicked up a shit ton of rocks and debris that landed on my hood. I’m kicking myself now, but I learned an important lesson. It’s ok if the person in front has a large lead. I wasn’t right on his ass but I knew I was too close for how he was driving.
    So enough bitching and back to work - is there any way to fix this mess???
    4CC95EFD-F914-4A1A-8680-A25472E74EA7.jpg 40E49AFA-B5CD-48B0-A9A9-29A94F6F36F2.jpg 2F7060C7-7B42-44AF-B7BA-BCD0CB4B52A3.jpg 88847B79-A868-4991-A671-C6AC70B5322F.jpg
    bulldog93 likes this.
  15. Aug 21, 2022 at 10:06 AM
    #765
    RobertD
    Robert
    DFW, Texas
    :sorry:
  16. Aug 21, 2022 at 10:07 AM
    #766
    RobertD
    Robert
    DFW, Texas
    Guess its time to mix more color match Raptor liner and spray the bumper caps and your hood?
    BlueRibbon4x4[OP] likes this.
  17. Aug 21, 2022 at 10:23 AM
    #767
    BlueRibbon4x4
    Geno
    I don’t know man. I may see if it can be repaired. It’s not as bad as I thought, now seeing it in the sun. But I’m also only on two hours sleep, so my attitude is pretty good about it right now even as cranky as I am.
    RobertD[QUOTED] likes this.
  18. Aug 21, 2022 at 10:35 AM
    #768
    18" TRD Off Road Wheels
    Glad you have a good attitude, but please tell me you coached the guy a little and showed him the damage? Slinging rocks at the guy behind you is bad enough, but it also tears up the trails.
  19. Aug 21, 2022 at 10:42 AM
    #769
    BlueRibbon4x4
    Geno
    I did not coach him at all. You’re correct, it tears up the trail and he’s gonna do it to the next guy. But when it happened, I did not have a good attitude. I had to be quiet, I was too riled up to be civil and it took quite a while to calm myself down. I also couldn’t see the damage yet, but knew it was somewhere under the layer of silt.
  20. Sep 3, 2022 at 1:30 PM
    #770
    BlueRibbon4x4
    Geno
    Guess what!?! Broken. Again.
    I’m making the next uppers out of metal. That’s it. I got too much time invested to ditch the idea.
    bulldog93, GODZILLA and TRDFerguson like this.
  21. Sep 3, 2022 at 1:47 PM
    #771
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Liking for the pup, not the broken liner. That’s a bummer.
  22. Sep 3, 2022 at 1:49 PM
    #772
    BlueRibbon4x4
    Geno
    Thanks. Shop dawgs.
  23. Sep 3, 2022 at 2:10 PM
    #773
    RobertD
    Robert
    DFW, Texas
    :censored:
  24. Sep 12, 2022 at 9:16 PM
    #774
    BlueRibbon4x4
    Geno
    Hit the dunes of Pismo beach with a few other yotas. Tons of fun, a few rescues. Pulled one dude out of a huge bowl, and the Victory 4x4 bumper gave in. Used my winch and pulled it away from the stock bumper. I used a snatch block and latched the other end to the shackle mount on the bumper. There’s about a 1” gap now, and from underneath you can see where thenmetal just bent outward. I think I’m gonna bend it back and add a few gussets so it doesn’t happen again. I have another related mod coming up as well, and I think it’s gonna be sweet.
    833E0B37-692F-4988-8FE7-1CB6A2833F7F.jpg 838BF08F-5F8B-41E3-915C-29E98D118ECF.jpg CFE89969-041F-47CC-99F8-E9CF94985C7B.jpg 854D96E0-CCE9-4AB9-B9F6-4CDC86D04307.jpg 95154AA1-37C9-4E16-9732-F7DD79F3CC69.jpg 8732AD58-09BB-4CC3-9005-3B90D3083C17.jpg D8C526C5-8658-42E6-86FF-91525CF1503A.jpg 3A500F9E-BBA7-47F2-82F2-29A86C3023F7.jpg
  25. Sep 13, 2022 at 4:55 AM
    #775
    Ouch! Hope you had a ball out there, though.
  26. Sep 13, 2022 at 6:55 AM
    #776
    BlueRibbon4x4
    Geno
    Hell yeah. Had a blast. This was gonna happen at some point, I suppose.
    GODZILLA[QUOTED] likes this.
  27. Sep 13, 2022 at 7:05 AM
    #777
    Just means you need to upgrade to a full bumper that you can customize and paint match, right? :boink::evil:
  28. Sep 13, 2022 at 4:13 PM
    #778
    BlueRibbon4x4
    Geno
    I got a little something up my sleeve.
    RobertD and GODZILLA[QUOTED] like this.
  29. Sep 13, 2022 at 4:14 PM
    #779
    :popcorn:
    RobertD likes this.
  30. Sep 16, 2022 at 4:43 PM
    #780
    BlueRibbon4x4
    Geno
    Ok story time!
    My bumper got jacked up while pulling a 4Runner out of a sand pit in Pismo. It got more jacked when I got yanked out of a stuck spot. It’s pulled out about an inch on the driver side, and about a 1/4 inch passenger.
    Before this happened, I had a plan to keep my Victory bumper and ditch the center plastic valance and bumper ends. Then I’ll weld bars to the left and right of the Victory bumper to imitate the rear Westin bumper. I’ll add a small horizontal panel that will hold the fogs, then add a flat panel behind the bars that I can color match.
    My plan is to fix the bumper by bending the mounting points straight, then adding some beefy gussets (there are none!!!) to the inside of these mounts.
    The hoops that will get welded to the side are going to basically be a rough draft. If I like them, I can use some nice .188 DOM material, but for now I’m using stripped galvanized post. In my past experience I’ve built bumpers out of wood and needed to build them twice to get them looking really nice. I realize this will make the bars purely aesthetic, but so were the other bumper ends, and this mod is gonna only cost me about $100.
    A5F3FFEE-E300-4FC5-8273-B0EFD5C62737.jpg 7CC782CC-A761-42F5-9A1D-3BEDCF88B3FB.jpg 82FB8AFE-A550-41CC-9754-AA6F3D306E44.jpg D6F2D4AC-F0F2-4E5A-947E-834EF796E36F.jpg 4F3E483A-FE6E-4E18-8613-12C2589E5F92.jpg D1614EE2-3171-4545-8D61-FB30845C8092.jpg 56FFA106-5C5D-47F2-BA2D-0F3834190132.jpg
    bulldog93, GAknight and RobertD like this.
