Blown head gasket or just short driving?
Discussion in '2nd Gen Tundras (2007-2013)' started by ajnc, Mar 17, 2021.
  1. Mar 18, 2021 at 1:08 PM
    #91
    Professional Hand Model
    Hand Protectors
    Thanks for the feedback. Glad everything is good.
    Your fluid may still be Hot/Warm even off for a few hours. My early assumption with your pics was Low Coolant at pre-start cold. I’ve learned something new today about the 5.7L that it sucks in from the rez on cold starts and then normalizes back up to the Full Line when Hot.
    I’d be interested if you could observe the coolant level in cold condition tomorrow morning and then immediately after start up to see if things change. We like to keep a good argument going. :rofl:
    Jrharvey02 likes this.
  2. Mar 18, 2021 at 1:43 PM
    #92
    ajnc
    ajnc [OP] New Member
    Haha funny you say that. I initially posted that arguing about coolant on the internet was insane, but removed it, because I realize it kind of fun. I'll report back tmrw with initial coolant level, and then immediately after starting. The suspense is gonna be intense.
  3. Mar 18, 2021 at 1:50 PM
    #93
    Hand Protectors
    I’ll be up bright and early waiting. Might not even sleep!
    Leo's first likes this.
  4. Mar 18, 2021 at 1:56 PM
    #94
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I thought I had blown my head a few months ago, truck was overheating, slowly losing coolant, etc. turned out there was a hairline crack in the radiator that was barely leaking out and eventually got to the point it wouldn't hold any pressure and would overheat. From your symptoms I think your truck is fine.
  5. Mar 18, 2021 at 2:01 PM
    #95
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Well shit! I'll eat some crow! I've never seen some shit looking like milkshake in the cap no matter how short the drive is!! But hey at least your good to go!!!
  6. Mar 18, 2021 at 2:50 PM
    #96
    AZBoatHauler
    So.Arizona
    The suspense was too much to handle - here are some observations.
    Cold start - coolant 75F
    marked cold level with a black dot in middle of overflow container.
    coolant 102F
    Level appears unchanged.
    125F
    fluid up approx 1/2”
    Coolant 150F
    level up approx 1” from cold.
    Coolant 175F
    Level up approx 1.5-2” from cold.
    Full operating temp - saw thermostat open around 185, temp dropped to 175 then back up to 190F
    level up approx 2-2.5” from cold.
    My truck had been sitting almost 48 hours before starting. Fluid level did not drop at anytime I was observing from cold start to operating temp.
  7. Mar 18, 2021 at 3:57 PM
    #97
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    Appreciate the effort into this. Can I ask, it looks like you turned your ignition on and then measured the temperature of the coolant as it got warmer, meaning the engine was left on? What I experience (and I assume the OP) is to crank the engine on and then turn it off after 15-30 seconds or whatever, certainly don’t let it run otherwise the problem doesn’t occur. My coolant gets sucked out once the engine is turned off after only being on for seconds.
    AZBoatHauler[QUOTED] likes this.
  8. Mar 18, 2021 at 3:59 PM
    #98
    AZBoatHauler
    So.Arizona
    You are absolutely correct on the procedure of what I did.
  9. Mar 18, 2021 at 4:00 PM
    #99
    Jrharvey02
    You let it run?
  10. Mar 18, 2021 at 4:01 PM
    #100
    AZBoatHauler
    So.Arizona
    I got a coolant temp and level prior to start-up. Then started the truck and drove my way to the store stopping through my neighborhood to snap a pic as the coolant reached the temps referenced in my post above. Did not shut the truck off until it was at operating temp.
    After it cools all the way I’ll check the level start it again and do a cold shut down.
  11. Mar 18, 2021 at 4:57 PM
    #101
    Hand Protectors
    This is better than Seinfeld!
  12. Mar 18, 2021 at 5:35 PM
    #102
    Jrharvey02
    If anybody else is interested in performing this experiment on their 5.7...Here’s exactly what I do when I’m able to practically drain my coolant reservoir to empty:
    Make sure truck has been off overnight (cooled down completely)
    Start engine
    Throw it in reverse and back up 8 feet
    Throw it in park and immediately shut engine off
    Check coolant reservoir
  13. Mar 19, 2021 at 4:40 AM
    #103
    ajnc
    Huh. I woke up like it was Christmas morning, ran downstairs and tried this. And it didn't work. I backed up literally about 8 feet, shut it off, and ran to the front and the level stayed between high and low. Exactly where it was when I checked before I moved it at all. I even kept the hood popped so I didn't waste any time fumbling around. I then tried running it for 30 seconds without moving the truck, shut it off. No luck.
    Obviously i'm not saying it doesn't do this in your truck. But it doesn't do it in mine for some reason. We need a larger sample size
  14. Mar 19, 2021 at 5:11 AM
    #104
    ajnc
    The only reason i'm still here. I wish I was more into my truck. I'm gonna miss you guys when i'm gone haha
  15. Mar 19, 2021 at 5:12 AM
    #105
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    I rest my case. Again.
    It happens like that on everybody's truck, except for those extremely low on coolant. Learned how it works on a (OMG) 22RE, a mere speck of an automotive engine; it was not quite half the size of the mighty 5.7L 3URFE.
  16. Mar 19, 2021 at 5:25 AM
    #106
    JohnLakeman
    You live in Nevada where relative humidity is next to nothing. The only way any moisture could get inside your engine IS from the cooling system. There's no scum inside my oil fill cap either, and Central Texas has humidity.
    jeremyd[QUOTED] likes this.
  17. Mar 19, 2021 at 5:44 AM
    #107
    ajnc
    I live next to the ocean. And every morning dew is dripping off everything I own until the sun burns it off. So, there is that.
  18. Mar 19, 2021 at 5:44 AM
    #108
    Hand Protectors
    Yeah. Harvey must have a special edition 5.7L that nobody else has where his sucks coolant during quick starts shut offs. I like the enthusiasm of everyone here getting excited on coolant level checks like it was Christmas morning. I barely slept last night with excitement!:rofl:
    Seriously, Harvey probably needs to add some coolant in his rez or has another problem. That altitude thing might be an x-factor?
    Tundra2 and JohnLakeman[QUOTED] like this.
  19. Mar 19, 2021 at 5:46 AM
    #109
    Hand Protectors
    Thats two members confirming fluid doesn’t suck in. We need a poll! You should start one at the top of your post.
    Tundra2 likes this.
  20. Mar 19, 2021 at 6:04 AM
    #110
    JohnLakeman
    I don't know if altitude would have any effect, but @Jrharvey02 has some strange **** going on, and I believe he's been lucky so far. I'm not sure just adding coolant to his reservoir will get the job at this point.
    Based on his last post of expecting to find air in the radiator tank, he needs to open the radiator cap and pour coolant in until at least above the radiator cap shoulder in the neck (or overflowing the neck, whichever comes first), and THEN fill the reservoir to full. If there's any additional air left in his cooling system, he can then expect the coolant level in the reservoir to be BELOW the FULL mark after the first heating/cooling cycle.
  21. Mar 19, 2021 at 6:10 AM
    #111
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Maybe the thermostat is stuck open .
  22. Mar 19, 2021 at 6:10 AM
    #112
    Hand Protectors
    Yeah. I bet when he follows your advice then he won’t see the coolant suck anymore.
  23. Mar 19, 2021 at 6:11 AM
    #113
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    That’ll blow .
  24. Mar 19, 2021 at 6:23 AM
    #114
    JohnLakeman
    All I can say long-distance is his system is not operating normally. His cooling system is AT LEAST low on coolant, but that may be collateral damage from another cause. Needs to get it checked out.
    Well, coolant IS actually sucked back in the radiator when it cools, but not after the reservoir level gets too low.
    As usual, I have found the perfect YouTube video illustration "because it might be helpful to some of ya'll" (OMG, it's a 22RE): :D
    https://www.youtube.com/watch?v=-TLgBopNqv4
  25. Mar 19, 2021 at 6:25 AM
    #115
    Hand Protectors
    We’ll be back to normal with nothing to discuss.
    Lovetrucks[QUOTED] likes this.
  26. Mar 19, 2021 at 10:50 AM
    #116
    AZBoatHauler
    So.Arizona
    Part II
    64F coolant temp this morning prior to startup. Top mark is operating temp level, lower mark is yesterday’s cold start level.
    New cold start level marked.
    Started the truck backed in and out of the driveway and shut it down. Coolant temp 69F and fluid in the overflow at the same level.
    My 5.7 does not appear to aspirate any coolant during cold shutdown.
  27. Mar 19, 2021 at 11:52 AM
    #117
    Hand Protectors
  28. Mar 19, 2021 at 12:09 PM
    #118
    Jrharvey02
    Welp, I guess I was wrong and you were right, John and “Golden Hands”. I’m really not sure what to think of this whole situation. Here’s a pic of my coolant level after a drive this morning. I’m hesitant to take my truck into the dealership because I feel like I’m “making” this problem happen. I mean, what exactly do I tell the service dept. “my coolant reservoir drains to nill after truck is started for 30 seconds but 99.9999% of the time (including heavy towing) the level is fine? I guess Ill just keep monitoring it like I have been the past (almost) 3 years...I’m really hesitant to add any fluid, I like my level being where it’s at in the pic...?
  29. Mar 19, 2021 at 12:11 PM
    #119
    AZBoatHauler
    So.Arizona
    Just pop the radiator cap when the engine is cold to make sure it’s full and/or top off there. Worse thing to happen if you overfill is pushing some out the overflow. NBD. :anonymous:
    What elevation are you at?
  30. Mar 19, 2021 at 12:15 PM
    #120
    Hand Protectors
    Where is my apology?:rofl:
    Jrharvey02[QUOTED] likes this.
