Blown engine
Discussion in '3rd Gen Tundras (2022+)' started by northerntundra1, Oct 29, 2022.
  1. Oct 5, 2023 at 7:49 PM
    #481
    Porkchop253
    Porkchop253 New Member
    2023 Platinum Hybrid
    Trd lift. Heritage grill. Painted grill surround. Ceramic tint. Bfg ko2. Leer canopy.
    Yeah ok. Data thread huh? Glad I had nothing to offer
  2. Oct 5, 2023 at 8:46 PM
    #482
    Tom976
    Tom976 New Member
    Tom
    Toyota Motor Manufacturing, Alabama (TMMAL) builds more than 3,000 engines each day. Producing one-third of Toyota's engines in the U.S. TMMAL is the only plant to build four-cylinder, V-6 and twin-turbo under one roof.
  3. Oct 5, 2023 at 9:58 PM
    #483
    Kap1
    Kap1 New Member
    San Francisco, CA
    And what if 5-30 will cause any issues in this new engine? I don't believe that we have data to support that 5-30 is harmless over the long run 100-200k miles?
    digitalwiz likes this.
  4. Oct 5, 2023 at 10:14 PM
    #484
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    I am sticking with 0-20 under warranty, but the Land Cruiser 300 with the same engine call out 5W-30 in the whole rest of the world. They don’t GAF about economy or pollution in Saudi Arabia or Africa or even Australia for that matter.
  5. Oct 5, 2023 at 10:28 PM
    #485
    We have billions of miles of 5w30 driving that supports it. Turbo engines, NA engines, big engines, little engines, high compression engines, supercharged engines, you name it. 5W30 has been run in most cars and trucks for the better part of the last 30 years. What we don’t have is the same for 0Wanything. This engine is an engine. Just like any other engine. It’s made of metal and has the same construction as many that came before it. All that changed was EPA. There’s no tighter tolerances or whatever other BS people wanna say justifies it, they recommend the water thin oil to get better mpg for EPA cafe testing. That’s it. They turn right around and recommend 5w30 for “heavy towing” or other actual use of the truck and recommend more frequent oil change intervals too.
    MEWaters and AZBoatHauler like this.
  6. Oct 5, 2023 at 10:34 PM
    #486
    Kap1
    Kap1 New Member
    San Francisco, CA
    Ok, thank you.
    But who is actually running 5-30 on this board in their new Tundra engine? Sure, our new engine is same as any other one, but still...
    I hear all the talk but don't see anyone saying they run 5-30 without any issues and they got 30, 50, 100k miles without any problems?
  7. Oct 5, 2023 at 10:36 PM
    #487
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    My salesman said the same thing. The motor is already broken in.
  8. Oct 5, 2023 at 10:41 PM
    #488
    Black widow TRD
    Manuel
    The US manual states that it recommends 0w-20, but it not a must.
    I am now running 0w-30 full synthetic in my rig.
    My Mustang MY19, recommends 0w-20 for normal driving conditions, but for heavy duty/ racing conditions it recommends 0w-30. I’ve been running 0w-40 for the last 50k miles, changed every 3k, coz I run full E-85. Runs like a beast.
    Kap1 likes this.
  9. Oct 5, 2023 at 10:48 PM
    #489
    Kap1
    Kap1 New Member
    San Francisco, CA
    I ran 5-30 top grade Redline in my ram truck hemi instead of 5-20, I thought that I was smart... , but engine still died. So I'm a bit more hesitant to experiment now as it didn't really matter.
  10. Oct 6, 2023 at 4:25 AM
    #490
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I ran Red Line 10w40 and topped up with any diesel 15w40 oil I could find on the shelf in my Volvo calling for 0w30/5w30. It didn't stop valve stem seals leak and the engine died, after 15 years and 220k miles. Upon disassembly I found maybe 1/3 of the wear I found in a similar engine (same model, same year, very similar mileage) that was running recommended everything. Was seriously considering leaving the factory rod bearings in place, because they looked new, but replaced them anyways with a heavy duty version from diesel engine. Main bearings I didn't even touch, they had no wear. Bore wear was absurdly different - the other block was calling for the next size, mine was well within limits. Compression rings thermal gap differs in order of magnitude. No carbon in oil rings. I floored my Volvo every day, it also had a remapped ECU.
    What I learned is I have to run a thicker grade oil in my engines, 'cause I witnessed it provides a better protection and better engine longevity (heh, potentially), but it does not need to be the most expensive oil ever. So Pennzoil PU 5w30 in Toyotas and 5w40 in Volvo. Used to be Mobil 1 ECF in Volvo after rebuild, but it forms varnish and lay deposits, which never happened before with Red Line. Will see how Pennzoil is doing there.
    Would it be 10w40 from day 1, the engine would barely have any wear. I unfortunately got it at 80k and used a thin 0/5w30 oil for the next 70k.
    Also for those who want to stick with Toyota recommended 0w20 - consider Red Line. It is even visually more thick and viscous than Toyota 0w20. It costs significantly more, though.
  11. Oct 6, 2023 at 5:55 AM
    #491
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    Not disagreeing, but a lot of their 5.7L had lifter failures with the recommended oil. RAM’s issues are arguably much more widespread than Toyotas.
  12. Oct 6, 2023 at 6:23 AM
    #492
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Is it the case when a truck was left for a few week/months, hydraulic lifters drained and then the engine chatters? It is quite common for hydraulic lifters in any engine, just put a light load on engine until lifters fill with oil.
  13. Oct 6, 2023 at 11:05 AM
    #493
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    I think the lifters in question with the failed Ram 5.7L were also the variable displacement kind. At this point I don’t think anyone has figured out a grade of oil that can prevent those turds from failing.
    mountaingroan, digitalwiz and Kap1 like this.
  14. Oct 6, 2023 at 3:20 PM
    #494
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    Just for comparison, were you a service advisor at BMW when the M5x's were having the bearing issues in M3's? I had an effected car they replaced the rod bearings in house. Did BMW ever disclose what % ate the bearings?
  15. Oct 6, 2023 at 3:42 PM
    #495
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
  16. Oct 6, 2023 at 4:37 PM
    #496
    Coal Dragger
    Kung Fu Dick
    I wasn’t a service guy, I sold them.
    I sold a few of the V10 M5’s and one M6, but left shortly after for another career path that didn’t involve dealing with spoiled trophy wives, and pretentious yuppies who thought they were special. (Gotta insult the average BMW buyer)
    I kept in touch with the service guys for awhile after but probably not long enough to hear about rod bearing failures until later.
  17. Oct 6, 2023 at 4:45 PM
    #497
    BoulderGT3
    Glen
    The M3 bearing issue pre-dates the V10's. I was one of the guys you hated! :). However, I did start with not a thing and have great relationships at the dealers. I had the F150 from hell and I bought the shop guys donuts! Nobody wanted that damn thing fixed more than they did.
  18. Oct 6, 2023 at 6:21 PM
    #498
    Coal Dragger
    Kung Fu Dick
    Some of my former clients were great.
    Not many people back in those days buying M3’s, M5’s etc who weren’t car guys. Car guys I loved to do business with because they appreciated the vehicle for what it was, the engineering, and how it drove.
    The other 85% were douche bags buying as a status symbol to impress others or give the outward appearance of wealth. Often times there was very little substance there, but that didn’t stop a lot of people from playing pretend.
    The E46 M3 with the proper solid lifter S54 was also new enough at that time in the US market to not be manifesting bearing issues. I dearly loved the E46 M3, a proper M3 before BMW lost the plot. The only sticky point for a few clients was valve adjustments for the guys who put miles on, but that job was evidently not too horrendous.
    Any of the M cars should have had drastically shorter OCI’s if any longevity could be hoped for in an engine spinning 8K RPM.
    4genRunner likes this.
  19. Oct 6, 2023 at 7:39 PM
    #499
    2WD
    2WD New Member
    21 Army Green CM SR5 TRD Off Road
    I came from a Ram before Tundra and did loads of research on their lifter failures. It turns out it’s unrelated to cylinder deactivation.
    5.7’s in Chargers and Challengers with manual transmissions don’t even have cylinder deactivation, and they had lifter failures.
    A good YouTuber MOPAR mechanic (think “Chrysler Car Car Nut”, can’t recall his name) figured out it was the stock oil pump not providing enough oil pressure at idle. There was a strong correlation with high idle hours and lifter failures. Nothing to do with MDS.
    He recommended a bolt on retrofit for relatively low dollars - the Hellcat engine oil pump is compatible with the Hemi 5.7 and provides proper pressure. Chrysler was just too cheap to put that pump on all 5.7’s.
  20. Oct 6, 2023 at 10:02 PM
    #500
    Coal Dragger
    Kung Fu Dick
    That sounds very very MOPAR.
    2WD and Black widow TRD like this.
  21. Oct 6, 2023 at 11:05 PM
    #501
    Kap1
    Kap1 New Member
    San Francisco, CA
    With Ram hemi, it's a medium-high probability that your engine lifters may fail around 120k miles. And you'll have to replace manifold bolts every 30-50k miles.
    However, these chronic issues develop over time, make lots of warning signs/noises, and it's a very low chance that you'll be stranded somewhere far away from home like our 22-23 tundras with the engine bearing failures.
    2WD likes this.
  22. Oct 7, 2023 at 11:39 AM
    #502
    Kap1
    Kap1 New Member
    San Francisco, CA
    It seems to be happening anywhere 9k-30k miles. Up to march 2023 built as we know so far
  23. Oct 7, 2023 at 12:05 PM
    #503
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    Whew. Glad you clarified. When he said "our", I immediately thought, "@digitalwiz must have an engine bearing failure."
    It was not at all obvious he was using the word "our" to mean the 3rd gen Tundra issue, as opposed to the Ram lifter issue. :rolleyes:
  24. Oct 7, 2023 at 9:47 PM
    #504
    Kap1
    Kap1 New Member
    San Francisco, CA
    How many miles do you have on your truck yet?
  25. Oct 8, 2023 at 5:01 AM
    #505
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    FWIW, I checked Consumer Reports survey on the 22 Tundra, and it gets an excellent score (5/5) for reliability of the engine, transmission, and drivetrain.
  26. Oct 8, 2023 at 7:05 AM
    #506
    Consumer reports is a joke for car stuff. How can a brand new model get good reliability scores with literally no data available to make that claim? They probably ask Toyota how it's going and they get the same response we do. "Nothing to see here, all is well".
  27. Oct 8, 2023 at 7:14 AM
    #507
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    don't share this with the Gen2.5 owners - they will have an epic melt-down. Like Prairie Dogs a few of them found their way onto our lawn (aka Gen3) and began to leave calling cards of why would you ever own a Gen3. They want their cake and to eat it to....all good when initial reviews are good for them but can't be the same when it is another generation. Pot calling the kettle black.
  28. Oct 8, 2023 at 7:47 AM
    #508
    rruff
    rruff New Member
    No data? How do you think this thread came about? :confused: It's been out 2 years already.
    If people have issues that would show up in the survey... unless those issues are rare.
  29. Oct 8, 2023 at 7:53 AM
    #509
    “I bought a thing and it lasted a year or so. It is now reliable.” Said no one ever. What we have is predicted reliability, not actual. We don’t know how long any of these new components will last. If these components begin to fail at 3-5 years we will not consider them reliable trucks. What we’ve seen so far seems more like growing pains. A bad batch of turbo wastegates, maybe a bad batch of main bearings or a bad batch of poorly machined blocks. Maybe a bad batch of 10speeds with some quirks there. Some ECM tune issues perhaps. Nothing widespread. A majority of owners seem happy with theirs. Hopefully the few bugs get sorted as they tend to and moving forward it’s all happy stories. The sky is not falling.
    Silver17 and digitalwiz like this.
  30. Oct 8, 2023 at 8:03 AM
    #510
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Hank Hill, Tom976, MEWaters and 6 others like this.
