Blown engine
Discussion in '3rd Gen Tundras (2022+)' started by northerntundra1, Oct 29, 2022.
  1. Oct 2, 2023 at 9:03 AM
    #451
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    I'm still interested to see if there have been any reported engine failures on the MY22 or MY23 Sequoias or the Lexus LX600s. Their all the same engine AFAIK.
    The sales volume of those models (I assume) are much lower than the Tundra, but there should be a few failures by now, if it was a design issue specific to engine. If there are no failures on those models, then I would assume the problem was isolated to the Tundra manufacturing line...which would likely point to bad batch of bearings. :notsure:
  2. Oct 2, 2023 at 9:10 AM
    #452
    Polo08816
    Polo08816 New Member
    2014 BMW 335i
    Well, I'm not sure they assemble the engine on the Tundra manufacturing line, do they? I would imagine the long blocks are just installed on the Tundra manufacturing line.
  3. Oct 2, 2023 at 9:11 AM
    #453
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    Which could very well mean they don't intend to fix it... because it is rare enough to not be worth the trouble. How much trouble I wonder? If it's a bad supplier, part out of spec, this should be easy.
    I would hope that they would in order to protect their reputation of reliability, but who knows...
    BoulderGT3 and EmergencyMaximum like this.
  4. Oct 2, 2023 at 9:20 AM
    #454
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    In good old days that discovery would warrant and TSB or TJ.
  5. Oct 2, 2023 at 9:35 AM
    #455
    EmergencyMaximum
    EmergencyMaximum Synthetic member
    This.
  6. Oct 2, 2023 at 9:36 AM
    #456
    KroppDuster
    Bilstein 5100s
    TBH, I don't know where the full long block is assembled. I assume in the same plant but not on the actual manufacturing line. I'm pretty sure the LX600 is assembled in Japan. The Seqouia is assembled in the same San Antonio plant as the Tundra. I guess regardless of the assembly location, if it were a design issue with the oil passages of the block, then it should impact all blocks equally, no?
    Kap1 likes this.
  7. Oct 2, 2023 at 9:40 AM
    #457
    Hadelson
    Hadelson New Member
    Allentown - Pennsylvania
    23 Tundra TRD Pro. Fun Ride 2019 RS3 Roush SC Mustang
    Toyota Quality Management process. They know exactly what manufacturer, lot and vehicles installed. Unless TQM process broke down not completing records.
    Should also have mean rate failures based on total Tundras built. This keeps the failure rate much lower vs. using the number only for Tundra units build with bad bearings.
    Most likely much lower than we think and as such adopting fixing on case by case basis.
    Either way, Toyota keeping tight lid on communication.
    IMO, should offer extended warranty coverage for these failures.
    Jodster71, 22whatwedo and Kap1 like this.
  8. Oct 2, 2023 at 9:45 AM
    #458
    Kap1
    Kap1 New Member
    San Francisco, CA
    So I'm not so sure if the LX600 engine is exactly the same as the one we have in Tundra. Same engine? Yes, but not necessarily built in same plant as Tundra engines.
    According to the Car Care Nut, in his review of LX600 couple weeks ago, he said that it's not the same as Tundra engine because it's not assembled at the same plant (I'm guessing Lexus engines may be built in Japan?).
    Not entirely clear information but that's what I picked up from the car care nut during his mechanical review of LX600.
    Ps I see you mentioned this same information in your next post..
    Terndrerrr likes this.
  9. Oct 2, 2023 at 9:45 AM
    #459
    Hadelson
    Hadelson New Member
    Agree
  10. Oct 2, 2023 at 10:00 AM
    #460
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    Yes, same engine, the V35A-FTS. But they are not built in the same places or with parts from the same suppliers. The MIJ V35A-FTS that goes into the 300 series and LX600 is built in Japan, and its turbos are supplied by IHI Japan.
    The MIA engines get their turbos from IHI America, which are built under license from IHI Japan.
    I haven’t looked in a while, but I don’t recall any V35A-FTS failures over on the Land Cruiser forum. This leads me to believe the issue is isolated to the ones built here.
  11. Oct 2, 2023 at 10:14 AM
    #461
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    FWIW, someone posted here saying they were from Saudi Arabia and talking about the same types of failures in the LC300 and LX600 (MIJ V35A-FTS).
    https://www.tundras.com/threads/off...discussion-thread.125154/page-10#post-3309093
    Posts #274 & #276.
  12. Oct 2, 2023 at 10:54 AM
    #462
    40man
    40man New Member
    Sounds right.
    The 5.7 in the 200 Land Cruiser was built in Japan.
    The Tundra 5.7 was built in Alabama.
  13. Oct 2, 2023 at 10:57 AM
    #463
    silk
    silk New Member
    2023 Lunar Rock TRD
    reading through the posts I see it mentioned that the engine failure or builds from 03/2023 and earlier are suspect to failure? I have a 03/2023 build, what data is available to confirm this?
    Thanks
  14. Oct 2, 2023 at 11:06 AM
    #464
    KroppDuster
    Bilstein 5100s
    Nothing more than what you've read here that has been shared by the impacted owners themselves. Or, if you're on social media, in the Tundra groups on Facebook.
    There is no "official data" from anywhere, least of all from the place it would matter most: Toyota. There is only 1st party recounts or anecdotal information shared by 3rd parties that they heard from someone else.
    EmergencyMaximum and KNABORES like this.
  15. Oct 2, 2023 at 11:20 AM
    #465
    Henfield
    Henfield New Member
    Interesting discussion. The way the OP described the failure and subsequent spun bearing diagnosis/discussion is very reminiscent of the Ram Ecodiesel engine failures due to spun bearings.
  16. Oct 2, 2023 at 11:35 AM
    #466
    EmergencyMaximum
    I think toyota just stays quiet hoping it will slowly simmer and die off. A bunch of nobodies chatting about issues on the forum or social media doesn't amount much:argue:
    Kap1 likes this.
  17. Oct 2, 2023 at 12:44 PM
    #467
    silk
    silk New Member
    2023 Lunar Rock TRD
    Well .. we may seem like nobodies today, however we are their future customers.
    Black widow TRD and vtl like this.
  18. Oct 2, 2023 at 1:11 PM
    #468
    KroppDuster
    Bilstein 5100s
    Or lack thereof.
  19. Oct 2, 2023 at 2:04 PM
    #469
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Got my oil analysis back....20k miles on an 11/21 build truck, 5k on oil. Went from 5ppm of Silver in my previous analysis @15k miles, to 11ppm @20k miles. Lets see if this is an indicator of a failing/failed bearing.
  20. Oct 2, 2023 at 2:12 PM
    #470
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    It’s the JB4!!
  21. Oct 2, 2023 at 3:13 PM
    #471
    KroppDuster
    Bilstein 5100s
    Funny you mention the tuner. When looking into it, this link popped up high in the search results. Basic summary: the guy recaps his convo with Blackstone about 7ppm of silver and it (possibly) being an indicator of bearing failure. On the tuner front: Looks like he’s running a Stage 2 tune via (I’m guessing) one of the BrenTuning flash modules. I’m assuming this guy is driving a turbo Impreza since this on the NASIOC website.
    https://forums.nasioc.com/forums/showthread.php?t=2757118
    Not the same situation, but similar enough to make me wonder. Turbo engine, high ppm of silver, tuned engine, etc.
  22. Oct 2, 2023 at 4:10 PM
    #472
    Terndrerrr
    Music City
    6UR-FE
    4genRunner[QUOTED] likes this.
  23. Oct 2, 2023 at 4:44 PM
    #473
    eddiefromcali
    Eddie
    100% Stock
    Seems to be limited to MY 22 non hybrid. Don't think we've seen an SR blow up yet
  24. Oct 2, 2023 at 4:46 PM
    #474
    4genRunner
    Southwestern MO
    Pretty sure there is at least one MY23.
    Kap1 and AZBoatHauler like this.
  25. Oct 2, 2023 at 5:00 PM
    #475
    AZBoatHauler
    So.Arizona
    Plenty of hybrids and some 2023s have destroyed themselves. I haven’t seen a SR failure.
  26. Oct 2, 2023 at 5:23 PM
    #476
    eddiefromcali
    Eddie
    100% Stock
    I missed the hybrid for sure then. I might have seen 1 23 but the majority are 22s...not sure if its because they have the most miles or what
  27. Oct 2, 2023 at 6:52 PM
    #477
    Black widow TRD
    Manuel
    Actually, I was joking. The additional boost should not lead an engine to its demise. Unless the amounts of boost are extremely high on an old engine
    I was joking in regards to the JB4. I some additional boost kills this engine, there are other factors that will kill this engine.
    My in-line 6 N54 TT BMW 335, was put thru the wringer a lot more than this Tundra.
  28. Oct 2, 2023 at 9:47 PM
    #478
    Porkchop253
    Porkchop253 New Member
    2023 Platinum Hybrid
    Trd lift. Heritage grill. Painted grill surround. Ceramic tint. Bfg ko2. Leer canopy.
    Here is my experience so far. Went in to get my second fob programmed and had them look at a potential oil leak. Literally had one drop on my garage floor. They kept my truck over night and was told the next day it needs a new motor. Freeze plug was not machined correctly and caused the drip from the oil galley. Basically bad block. Short blocked the motor with 5300 miles. 2023 hybrid. Dealer was top notch in taking care of me so props to them.
  29. Oct 5, 2023 at 10:24 AM
    #479
    AZBoatHauler
    So.Arizona
    We just needed to talk about it for it to happen. @koz69 - no tuning or other engine mods on your SR, correct?
    4genRunner and Mattedfred like this.
  30. Oct 5, 2023 at 10:30 AM
    #480
    I tagged you in another thread if you could post the details in the first post please. This is a data collection thread.
