Blown engine
Discussion in '3rd Gen Tundras (2022+)' started by northerntundra1, Oct 29, 2022.
  1. Apr 16, 2023 at 8:19 PM
    #331
    RookieEP
    RookieEP New Member
    2020 Tundra Limited TRD Magnetic Gray
    None
    Couldn’t it just be a bad supply of bearings
  2. Apr 16, 2023 at 8:48 PM
    #332
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    There are typically like 4 or 5 tolerance buckets in the engine. I would not be surprised if it ends up in finding some d**khead at the assembly line doing subpar job in using the wrong tolerance parts, because who cares?
    mayan and RookieEP[QUOTED] like this.
  3. Apr 16, 2023 at 8:55 PM
    #333
    Tom976
    Tom976 New Member
    Tom
    That first oil change the oil drained out like water. Wonder if this motor should really be on 0w20.
    Take a look at the raptor v6. 5w30 is the standard and 0w30 is for exteme environments.
    Tundrastruck91 likes this.
  4. Apr 16, 2023 at 8:55 PM
    #334
    catalac
    catalac New Member
    First post from OP “engine failure”… prove it or it didn’t happen.
    Mattedfred likes this.
  5. Apr 17, 2023 at 5:00 AM
    #335
    frozen_tundra
    frozen_tundra New Member
    2022 Tundra SR Crewmax Black
    The 3.5 Ford max torque hits at 3000 rpm. The Toyota is around 2000. The oil pressure I notice is very low around 1700 RPM. It holds 10th gear even going into 40 mph winds. Very impressive. I don’t think the Ford will hold gears like that - at least ones I’ve ridden in they don’t lug like that. To me that’s the difference between the 2, the Toyota will lug, it’s more of a stroker engine with a lower torque curve = much more stress on those bearings.
    Also look at Amsoils testing - they show pics of main bearings with conventional oil after 100k miles - they are toast. That’s why I think it’s the oil quality. This engine will be harder on bearings due to the torque curve vs the Ford the way I see it. And the testing Amsoil did proves that’s even a weak point in the Ford with low quality oil - it’ll only be worse in the Toyota engine.
  6. Apr 17, 2023 at 5:14 AM
    #336
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    @wedemmoez
  7. Apr 17, 2023 at 5:59 AM
    #337
    wedemmoez
    wedemmoez New Member
    2022 Black Tundra TRD Pro
    Toyota is talking to the owners of vehicles with failed engines. As of yet, we cannot determine a specific pattern that can help us identify why these have failed. The total number of failed engines is under 50, which makes it a 0.0003% failure rate. Not high enough for doomsday like some of the members here are calling for, but still nothing we're ignoring.
    We've got a whole team trying to track down the root cause of these failures, and as soon as I know information that I'm allowed to share, I will let y'all know.
    Spakylpm, Terndrerrr, t300 and 17 others like this.
  8. Apr 17, 2023 at 6:15 AM
    #338
    wedemmoez
    under 50 suspected bearing failures. I believe the turbo failure numbers are similar, but the ticket for that is with a different team so I don't have details.
  9. Apr 17, 2023 at 6:42 AM
    #339
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    Thank you for your post. I don't expect perfection but I do look for how companies respond. With both the Turbo and this bearing issue, Toyota is not hiding from the issue. As near as I can tell, they are taking the proper steps to take car of the customer and remediate the problem.
    It's hard not to compare and contrast to a nightmare I'm in the middle of with a new F150 that has electronic gremlins. 7th consecutive week in the shop and it simply can't be repaired. Ford is unresponsive on the buyback claim and I've got a $70K doorstop. For what I do, the F150 has a better feature set but their response to a problem is so far off the mark it's ridiculous.
    Knowing that Toyota is making solid efforts to deal with a problem makes it easy to switch to a Tundra.
  10. Apr 17, 2023 at 6:45 AM
    #340
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    As a serious question and not being a provocateur, is there any concern that a lot of these failures seem to be happening with as many as 45k miles on the trucks? I guess point being, there may be less than 50 at this moment but is there concern that the number could climb exponentially as more trucks are approaching that mileage range? Just going off that statistic that the average driver in the US drove 12,700 miles in 2022.
  11. Apr 17, 2023 at 7:31 AM
    #341
    wedemmoez
    I had so many issues with my 2021 Bronco and 2 different Ford dealerships basically tell me to go fuck myself. Tried escalating to Ford and they told me to go to a dealership that was 2 hours away. Ended up just selling the Bronco and getting my Tundra. I think Ford may be one of the worst customer experiences I've ever had.
    Terndrerrr and Tundrastruck91 like this.
  12. Apr 17, 2023 at 7:35 AM
    #342
    wedemmoez
    Definitely a concern, especially since the failures appear to be random. Luckily, Toyota has processes in place for stuff like this and we'll do our best to take care of our customers
  13. Apr 17, 2023 at 8:01 AM
    #343
    BoulderGT3
    Glen
    Well, at least I'm not alone. My F150 has gone from swapping telematics, APIM and gateway modules. The new ones don't talk to the old ones. The only electronics tech quit to go to another dealer. Nothing short of shocking.
    I don't own a Tundra yet but thanks for standing in there and not being invisible.
  14. Apr 17, 2023 at 9:10 AM
    #344
    AZBoatHauler
    So.Arizona
    They’ve already made 1M new tundras?? If not, your stat is BS.
  15. Apr 17, 2023 at 9:28 AM
    #345
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Toyota sells 100k or less Tundras a year. Much less figures for Sequoia, Lexus and TLC.
    AZBoatHauler likes this.
  16. Apr 17, 2023 at 9:29 AM
    #346
    AZBoatHauler
    So.Arizona
    1,000,000 * .000003 = what?
  17. Apr 17, 2023 at 9:34 AM
    #347
    Silver17
    Eastern PA
    How many units sold?
    160,000 x .0003 = 48 for example.
    SC4333, KNABORES and ryanwgregg like this.
  18. Apr 17, 2023 at 9:38 AM
    #348
    AZBoatHauler
    So.Arizona
    Expect .0003% makes the equation 160,000 x .00003 = .48 in other words half of one engine failure. We’ve got a few more than that documented.
    @Silver17 ’s equation would be for a .03% failure rate.
    des2mtn likes this.
  19. Apr 17, 2023 at 9:41 AM
    #349
    AZBoatHauler
    So.Arizona
    Yep - I’m the one not good at math. How would you calculate 10% of 1,000,000?
    1,000,000 x 10?
    DMC11 and des2mtn like this.
  20. Apr 17, 2023 at 9:45 AM
    #350
    AZBoatHauler
    So.Arizona
  21. Apr 17, 2023 at 9:50 AM
    #351
    Silver17
    Eastern PA
    Allow me to present it another way.
    48 failures \ 160,000 units sold = .0003 (not in a percentage) of the 160,000 units had a failure.
    To @AZBoatHauler credit
    I will say, saying .0003 In a percentage is technically .0003 x 100 = .03%.
    Terndrerrr likes this.
  22. Apr 17, 2023 at 9:52 AM
    #352
    AZBoatHauler
    So.Arizona
    Exactly.
    Kind of a big deal if the problem is 100x worse than the BS stats being spewed…
    Silver17[QUOTED] likes this.
  23. Apr 17, 2023 at 9:53 AM
    #353
    AZBoatHauler
    So.Arizona
    In before the “new math” peeps argue that a .03% fail rate isn’t 100x worse that a .0003% fail rate.
    des2mtn likes this.
  24. Apr 17, 2023 at 10:04 AM
    #354
    AZBoatHauler
    So.Arizona
    So you’re standing by this then?
    that’s the worst “I’m sorry I screwed the math up and was wrong” post I’ve ever seen.
  25. Apr 17, 2023 at 10:11 AM
    #355
    raylo
    raylo not so new member
    Frederick, MD
    Still very tiny numbers. And for those that seem to be hung up on all this, remember the 100 x zero is still zero. And 100 x "close to zero" is still close to zero.
  26. Apr 17, 2023 at 10:16 AM
    #356
    AZBoatHauler
    So.Arizona
    I’ll concede some effort but you still say 100,000 * .0003% is 30 when in reality it = .3
    Still comical you say I’m bad at math then demonstrate you don’t understand percentages but can’t win ‘em all.
    ryanwgregg likes this.
  27. Apr 17, 2023 at 10:28 AM
    #357
    AZBoatHauler
    So.Arizona
  28. Apr 17, 2023 at 10:33 AM
    #358
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Them damn engine bearings!! They bearing down on us!
    zorro and RookieEP like this.
  29. Apr 17, 2023 at 10:41 AM
    #359
    mass-hole
    mass-hole New Member
    Maybe its a combination. 0W-20 combined with 10k OCI's in an engine designed for work.
    One of the mistakes Ford made when designing the Ecoboost was that they assumed people were going to use them like trucks(at least thats how it appears). They designed the original 2011-2012 trucks to be worked, and they were designed really well TBH. The original intercoolers were fantastic. A lot of the early problems the Ecoboosts had could easily be attributed to the trucks not getting worked combined with longer OCI's. Their fixes to the problems the trucks had all dumbed the trucks down. They put plastic plates into the intercoolers to make them less efficient with more pressure drop, they had to change the tuning to run leaner at idle to keep fuel from building up in the oil, PCV changes, among other things.
    One thing Ford did early in the Ecoboost life was switch them from 5W-20 to 5W-30. This happened prior to the F150 getting the Ecoboost, but it was the same 3.5L but in the Flex/Taurus SHO/Explorer. My guess was this was to combat fuel dilution inherent in DI motors.
    cmiles97, ColoradoTJ and AZBoatHauler like this.
  30. Apr 17, 2023 at 11:00 AM
    #360
    Silver17
    Eastern PA
    If I was to again dare and attempt math in this thread, I might say it was 1 in 3,300 trucks…. At the moment anyway.
    zorro and AZBoatHauler like this.
