Blown Axles Seal
Discussion in 'General Tundra Discussion' started by BOBONTUESDAY, Sep 19, 2018.
  1. Sep 19, 2018 at 10:54 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Agreed. Should be on the dealership to change out seals correctly to fix the leak the first time. Not try something easy and when thats not right charge more for additional services.
  2. Sep 19, 2018 at 10:56 PM
    TheBeast The Beach
    some good info here.
  3. Sep 19, 2018 at 11:04 PM
    Totally agree Brian. So now if he pays out what the dealership wants, that is 1300.00 for two 8.00 seals to be replaced.
  4. Sep 21, 2018 at 8:30 AM
    BOBONTUESDAY
    BOBONTUESDAY [OP] Grocery Getter
    2016 Limited Trd
    Ok so little update at the stealership they're changing the same axle seal and the bearings. What a bunch of bull shit
    Bet you guys a burnt out Chinese light bar it doesn't stop leaking.
  5. Sep 21, 2018 at 12:55 PM
    I sure hope your paying for parts only and no labor.
    No way in hell any mechanic would be into the axle that far and not swap out a 7.50 seal.
    I learned that the hard way one time while swapping out a torque converter in my “hot rod” in high school. My dad told me to swap out the input seal. I didn’t want to spend the 2.50. Sure as hell, when I started the car back up, leaked like a broken water damn. So my dad laughed and said “son, I’m not half as stupid as you think I am, and this was the hard lesson you are learning tonight...”
    Instead of racing, mounting my girlfriend, and drinking (in no particular order), guess what I was doing?
  6. Sep 21, 2018 at 2:50 PM
    BOBONTUESDAY
    2016 Limited Trd
    Ok so final update till it leaks again lol.
    They changed the wheel bearing and seal this time. Which should.of been done the first time.
    Oh and yes some of the techs that work here apparently don't give a rat's ass.
    But apparently it's fixed I'm gonna put about 500 miles on it by.monday so we'll see if it still leaks.
  7. Sep 21, 2018 at 2:55 PM
    I was wondering if the bearing was going out and wiping the seal(s).
    Hopefully this fixes your issue, since you use the truck for work.
    BOBONTUESDAY[OP] likes this.
