Blocked up ac vents
Discussion in 'General Tundra Discussion' started by TundraTRD08, Jun 27, 2023.
  1. Jun 27, 2023 at 11:02 PM
    TundraTRD08
    TundraTRD08 [OP] Somehow I fit 37s on a level
    Wesley
    08 Super White TRD Off-Road on 37s
    3.5' RC lifted struts with RC UCA Alcan rear leaf spring upgrade with 300lbs added weight+1" lift built in. Adjustable Alcan Shackles set to add an extra inch which equals to a 2" lift in the rear. 37” Maxxis RAZR M/Ts with 1.5” spacers 8” BAMuffler Tuned by Bully Dog Tuner
    Before you say anything about the blower motor, I swapped the blower with another tundra that blew harder, and had the same result. How in the world could I go about making it blow harder. Also, it has a new cabin air filter.
  2. Jun 28, 2023 at 2:57 AM
    2mchfun
    Moving more air across the evaporator doesn't necessarily make it cooler. There is a sweet spot somewhere where the air has just the right amount of exposure to the evaporator. More or less than that sweet spot and it becomes less cool. You might have a clogged drain and the evaporator might be icing over which will reduce airflow significantly and also not be very cool. Check to see if it's dripping out.
  3. Jul 4, 2023 at 4:38 PM
    TundraTRD08
    Wesley
    It
    drips out plenty, and temperature is not the issue. Just the amount of air coming out of the vent is not as much the other tundra I swapped motors with. This also doesn’t matter if it is cold or hot
    2mchfun[QUOTED] likes this.
  4. Jul 4, 2023 at 4:43 PM
    2mchfun
    Maybe you have something blocking part of the intake vent.
    TundraTRD08[OP] likes this.
  5. Jul 4, 2023 at 4:44 PM
    TundraTRD08
    Wesley
    That’s a possibility. It’s a farm truck, so it’s probably pretty caked up with dirt
  6. Jul 4, 2023 at 4:45 PM
    2mchfun
    A little bit of lubrication on the motor bearings might get it to turn the fan just a little bit faster.
  7. Jul 4, 2023 at 4:46 PM
    2mchfun
    Maybe leaves, grass, etc. Good luck!
