Blinking dash light
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cougar67, Aug 1, 2020.
  1. Aug 1, 2020 at 10:56 PM
    Cougar67
    Cougar67 [OP] New Member
    With an OBD scanner, and is stuck in parking
  2. Aug 1, 2020 at 11:00 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    What kind of scanner? Many have very limited capability. With all the lights on your going to have stored codes.
  3. Aug 1, 2020 at 11:00 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    What have you checked so far?
  4. Aug 1, 2020 at 11:21 PM
    Youngfrankenstein
    Youngfrankenstein New Member
    2015 4x4 CM SR5
    I hope you are at your home buddy. How annoying. If you are at home, can you take the negative cable off of the battery, lock it up, go inside and have a beverage? See if a night w/no battery helps it reset maybe?
    Elevatormatt and equin like this.
  5. Aug 2, 2020 at 2:09 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Yup, reset ECU and hope for the best!
  6. Aug 2, 2020 at 5:43 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    @Youngfrankenstein is thinking back to when Toyota didn't expect you to read the owner manual. Now when you shift the transfer with a knob, the legend on the knob says "2WD" instead of "H2" range. Better for a clientele who doesn't need to know what's happening underneath.
    Tundyfundy likes this.
  7. Aug 2, 2020 at 9:02 AM
    Youngfrankenstein
    2015 4x4 CM SR5
  8. Aug 2, 2020 at 9:07 AM
    rcjh0891
    rcjh0891 New Member
    Joel
    DFW
    2018 Tundra Platinum Crewmax 4x4 MGM
    I thought I seen somewhere from another Tundra owner he experienced the same issue and it was a bad battery.
    Tierhog and Ruggybuggy like this.
  9. Aug 2, 2020 at 10:55 PM
    rrp0968
    rrp0968 New Member
    My brother had this issue of not coming out of park on a 4 Runner. Turns out the fuse for the brake lights was blown. Replaced it and all is good. I have not gotten my Tundra yet, should be here by early Sept. Do they have a slot next to the shifter that you can insert your key to get it out of park in a situation like this?
  10. Aug 3, 2020 at 6:12 PM
    Devdog86
    Devdog86 New Member
    Brad
    Pennsylvania
    2021 Lunar Rock Trd Pro CM
    This or a bad alternator. I had the same symptoms happen to me, not on a Tundra but in the end it was the alternator. Good luck.
  11. Aug 3, 2020 at 6:55 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Very curious to find out what caused it
  12. Aug 3, 2020 at 9:43 PM
    socaltundra951
    socaltundra951 Gentlemen Prefer Black Tundras
    Southern California
    Black CrewMax 5.7
    Rodents, perhaps? I've read similar symptoms after mice/rodents have chewed on things in the engine bay.
    zlaneb likes this.
  13. Aug 4, 2020 at 7:10 AM
    blueshound
    blueshound New Member
    2015 Red Tundra Platinum
    This happened to my Mercedes E350. Harshest part of winter, rodent went to seek refuge in my garage, saw those tasty German wires and went to town. Fired it up that morning, the dashboard lit up like a christmas tree. Fortunately it went into reverse and drive though. Drove it to get it fixed. $150 in wires and $2500 in labor, auto insurance covered it. I think they seen a thing or two. I finally traded that depreciating beast in and got the Tundra. Tundra doesn't fit in the garage so maybe it won't have the same problem.
  14. Aug 4, 2020 at 7:45 AM
    drowhawk
    drowhawk New Member
    '19 Tundra SR5
    Looks like a module is not playing nice on the CAN. We see this kind of crap on GM's all the time. No P codes, dash lit up like a Christmas tree, and really weird electrical bugs... I would scan it with something capable of communicating through factory CAN protocol and not OBD2. Guaranteed there's some weird U codes in there...
    glowblue likes this.
  15. Aug 4, 2020 at 8:43 AM
    Specialized
    Specialized New Member
    2017 Tundra DC TRD 4WD
    This happened to me a few years ago. Did you recently fill your tank? In my case, it was caused by bad gas. Very scary experience.
  16. Aug 5, 2020 at 9:02 PM
    TILLY
    Massachusetts
    Any updates OP? :monocle:
  17. Aug 6, 2020 at 3:57 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Truth! I had two GM cars that would go into limp mode randomly. Too hard to troubleshoot. Only fix was to disconnect battery to hard reset the ECM.
    This is most likely an electrical problem - bad fuse, battery, etc.
  18. Aug 6, 2020 at 4:57 AM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    :rofl::rofl:
  19. Aug 10, 2020 at 6:15 PM
    #49
    rcjh0891
    rcjh0891 New Member
    Joel
    DFW
    Any updates?
  20. Aug 10, 2020 at 6:49 PM
    #50
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Gone like the wind when the questions got tough.
  21. Aug 10, 2020 at 7:17 PM
    #51
    zlaneb
    zlaneb New Member
    Austin, TX
    i had rats chew up my main harness. It sucked to the tune of several hundred dollars. I did't get all the lights, but I couldn't get it over 45 MPH or to shift past 4th gear.
