Blinking dash light
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cougar67, Aug 1, 2020.
  1. Aug 1, 2020 at 6:07 PM
    Cougar67
    Cougar67 [OP] New Member
    Hello,
    I have 2017 tundra and my dash is blinking and it won’t engage to drive or reverse can anybody help me with this problem please. I’m so nervous don’t know what is is.
  2. Aug 1, 2020 at 6:19 PM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Based on your temp guage, Im assuming it's cranking over and idling ok?
  3. Aug 1, 2020 at 6:21 PM
    Youngfrankenstein
    Youngfrankenstein New Member
    2015 4x4 CM SR5
    Can you put it in neutral?
  4. Aug 1, 2020 at 6:22 PM
    Youngfrankenstein
    2015 4x4 CM SR5
    And put the transfer case in 2 high or 4 high?
  5. Aug 1, 2020 at 6:23 PM
    Cougar67
    Yes it’s idling perfect it just won’t engage out of park, the shifter is locked. And the cluster lights are all on, high/low , abs light on and blinking.
  6. Aug 1, 2020 at 6:26 PM
    Cougar67
    No I can’t
  7. Aug 1, 2020 at 6:26 PM
    timsp8
    NY
    Stolen from another thread on here.
    Bakershack, Black Wolf and Elduder like this.
  8. Aug 1, 2020 at 6:26 PM
    Tierhog
    Tierhog SIG-AHOLIC
    Hmm. Possibly in limp mode. Fuses all good? Can you test for trouble codes?
    Good work Tim.
    timsp8 likes this.
  9. Aug 1, 2020 at 6:29 PM
    timsp8
    NY
    Maybe something with your evap. Try to put some gas in it. Do you know anyone with a code reader?
    Tundyfundy likes this.
  10. Aug 1, 2020 at 6:41 PM
    Youngfrankenstein
    2015 4x4 CM SR5
    Stupid question probably, but u do have your foot on the brake pedal, right?
  11. Aug 1, 2020 at 6:43 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    From the chart, there's only one diag for the ABS to be blinking, i would start with the ABS fuse first.
  12. Aug 1, 2020 at 6:44 PM
    Cougar67
    There’s no code
  13. Aug 1, 2020 at 6:45 PM
    Cougar67
    Yes, I do have my foot on the pedal
  14. Aug 1, 2020 at 6:47 PM
    Youngfrankenstein
    2015 4x4 CM SR5
    When the truck's T-case goes into neutral, is there an "N" on the dash? I can't remember. You can put it in any gear, but there is no feeling of the tranny going into gear?
  15. Aug 1, 2020 at 6:48 PM
    Youngfrankenstein
    2015 4x4 CM SR5
    If nobody pops i I can go check in my truck. What drive is the transfer case dial in?
  16. Aug 1, 2020 at 6:50 PM
    Doctor Flex
    Doctor Flex Just browsing...
    Utah
    2020 White 1794 TRD
    TRD Pro skid, Line-X, Tonneau, drivers grab handle, wireless charger, RB 20's, TRD Pro wheels, Gator Liners.
  17. Aug 1, 2020 at 7:30 PM
    Cougar67
    I can’t put it on N
  18. Aug 1, 2020 at 7:35 PM
    TILLY
    Massachusetts
    Did you check the ABS fuse?
  19. Aug 1, 2020 at 7:45 PM
    18" TRD Off Road Wheels
  20. Aug 1, 2020 at 7:46 PM
    Cougar67
  21. Aug 1, 2020 at 7:48 PM
    Cougar67
    I have all this light on and the 4Lo and 4Hi is blinking. I can’t not put in reverse or drive is lock in park.
  22. Aug 1, 2020 at 7:56 PM
    Youngfrankenstein
    2015 4x4 CM SR5
    Is it not coming out of park for some weird electronic reason, like the car thinks your foot is not on the brake pedal? Or are you on a steep driveway?
    Is the 4 wheel drive dial in 2H or 4H?
  23. Aug 1, 2020 at 8:07 PM
    TILLY
    Massachusetts
    What exactly is 2H. :monocle:
  24. Aug 1, 2020 at 8:09 PM
    Cougar67
    Is on 2wD
  25. Aug 1, 2020 at 8:14 PM
    Youngfrankenstein
    2015 4x4 CM SR5
    Hello Tilly. Your transfer case selector dial: 2H= 2 wheel drive/high, 4H= 4 wheel drive/high, N=neutral, 4L= 4 wheel drive/low (gear ratio).
  26. Aug 1, 2020 at 8:19 PM
    Youngfrankenstein
    2015 4x4 CM SR5
    Well crap Cougar67. Sorry. I am at a loss. I don't know. I thought it might be a T-case dial between gears and/or your were on a hill w/lots of pressure on the parking pawl.
  27. Aug 1, 2020 at 8:31 PM
    socaltundra951
    socaltundra951 Gentlemen Prefer Black Tundras
    Southern California
    Black CrewMax 5.7
    Gonna add this to the threads I keep an eye on, it's always good to know what the resolution to these turns out to be.
  28. Aug 1, 2020 at 8:37 PM
    TILLY
    Massachusetts
    Ahhh, no that's not how it works at all, at least on my 19. The selector gives you the option of 2WD, not (2WD Hi or Low), no such thing, 4H or 4L. Neutral being included in the process involves the trans being in neutral in order to switch to 4L.
    equin likes this.
  29. Aug 1, 2020 at 10:25 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    No code, but half the dash is lit up? That doesn t sound right. There should to be a code if a dummy light is lit up. I would dis connect the battery for several minutes. with battery still dis connected stick key in ignition, turn on, past acc, to on. Try to shift out of park
  30. Aug 1, 2020 at 10:36 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You said there are no codes? How did you check?
