Blind Spot monitoring
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundraLuv, Nov 8, 2018.
  1. Nov 8, 2018 at 11:05 AM
    TundraLuv
    TundraLuv [OP] New Member
    Kent
    IA
    2018 Midnight Black Metallic Limited Crewmax
    Is there way to add the blind spot monitoring in the mirrors? It's one of the features I overlooked when I bought my Limited. It's where it lights up when another vehicle is on your right or left.
    trdprobped17 and 831Tun like this.
  2. Nov 8, 2018 at 2:55 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    I have the system on mine. My truck had damage to the resin bumper and I was told the sensor computer located on each side of the rear bumper (cover) costs $850 each (one on each side). Mine were fine. The switch was completely dead. The “computers” connect to the Parking sensor monitor harness (that I had to replace). I would check to see if you have the sensors already on your vehicle. They are very pricy. The truck comes with the lighting sensor mirrors which I had (the system didn’t work when I bought the truck) but when I replaced the harness and bumper extensions. It all worked fine. I was also told toyota would have to “recalibrate” the system. This was not necessary. I love having it. Great on the highway in traffic and sends an alarm for crossing traffic (from quite a distance). The system could be pricy if you don’t have the components but worth it I have found. Also, I am not sure if the lighted mirrors require a different harness as well. That’s about all I know.
  3. Nov 8, 2018 at 3:13 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    There are affordable after market systems available.
  4. Nov 8, 2018 at 9:29 PM
    NorCalTrdsport
    NorCalTrdsport New Member
    2018 MG TrdSport
    This literally saved my azz this morning on my drive to work. Merging from outside lane to the middle lane and someone was merging from the fast lane to middle towards my rear quarter panel... lit up and I just moved back over and pushed on. Pretty sure it wouldnt have played out so smooth without um in this particular one. Good luck on the hunt u have aftermarket options.
    831Tun and trdprobped17 like this.
  5. Nov 8, 2018 at 9:39 PM
    trdprobped17
    trdprobped17 New Member
    Crutchfield has several aftermarket blidspot systems for sale and they are all under $850. I added a second set of monitors to my 2Gen Tundra because it had a 6” lift and the stock system and just wasn’t reliable. You should check out the various systems online.
    831Tun likes this.
  6. Nov 9, 2018 at 12:42 AM
    Gibo244
    Gibo244 New Member
    KG
    Maui
  7. Nov 9, 2018 at 7:37 AM
    TundraLuv
    Kent
    IA
  8. Nov 9, 2018 at 7:57 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I did not know you would be able to get a 2018 Limited without it. Is it possible that it is not just turned off? Or is it really an option?
    It works with sensors in the rear bumper, so if you do not have those, and you have chrome bumpers, then it cannot be added without replacing the bumper caps also. It can get pretty expensive if you have to do all that.
  9. Nov 9, 2018 at 8:20 AM
    TundraLuv
    Kent
    IA
    It has this.
    Boerseun likes this.
  10. Nov 9, 2018 at 8:33 AM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Yea that’s odd. My 18 Limited came standard with BSM. Did your dealer swap out the stock mirrors with tow mirrors by any chance?
  11. Nov 9, 2018 at 8:41 AM
    Navi
    Navi New Member
    2019 CrewMax Limited
    The way i'm reading the pic you posted, it sure seems like you do have: LDA = Lane Departure. I'd say a call or return trip to the Dealer would be in order. Hope you live close to them.
  12. Nov 9, 2018 at 8:45 AM
    Boerseun
    Ferdie
    Sarasota Florida
    Yes, apparently it is an option.
    I would say go to the dealer and ask them how much it is to add this option. I have it on my truck and like it. It also comes with the cross traffic alert, which has actually been more helpful to me when pulling out of a driveway or parking spot where my view is blocked.
    That being said, just thinking what it may cost to add it, I would probably just learn to live without it. Sensors, bumper ends, mirrors, maybe some wiring to be replaced will add up quick. Sorry, it is not good news. Hopefully the dealer can give you better news.
  13. Nov 9, 2018 at 9:03 AM
    ToyotaTundraMike
    2015 Tundra
  14. Nov 9, 2018 at 9:03 AM
    TundraLuv
    Kent
    IA
    Thanks anyway. Will have to check out some aftermarket.
    Boerseun[QUOTED] likes this.
  15. Nov 9, 2018 at 10:49 AM
    Navi
    Navi New Member
    @Boerseun thanks for pointing out it's an Option, i thought it was standard on Limited. good to know
  16. Nov 9, 2018 at 11:46 AM
    Rakso
    Rakso Tundra + Tacoma=Winner
    Oskar
    18 CM Super White 4X4
    TRD sway bar, TRD filter
    Post a pic of your mirrors.
    If you're truck came with "convenience package" it should have it.
  17. Nov 10, 2018 at 9:17 AM
    TundraLuv
    Kent
    IA
    Photo of mirror
  18. Nov 10, 2018 at 12:14 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    Here is a shot of the dealer schematic for a 2016 Crewmax with the wire harness and computers ...
  19. Nov 10, 2018 at 12:15 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
  20. Nov 10, 2018 at 12:16 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
  21. Nov 10, 2018 at 1:40 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  22. Nov 10, 2018 at 2:37 PM
    TundraLuv
    Kent
    IA
    WOW! Where did you find that? Should a 2018 be pretty much the same I assume?
  23. Nov 10, 2018 at 3:41 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    From the service department at a dealer. The wire harness was a couple hundred as I remember. I got it for mech less from and online site for a dealer in California. OEM Toyota.
    I am forever looking for specs and this type of manufacturer diagram and have had very little luck. I am thinking to put out the suggestion that this site host tech manuals and repair manuals, owner manuals, etc. it would be an invaluable resource to members for repair and parts identification. I don’t know if this is not done due to some restrictions?
    I belong to a tractor site that has a library of tech manuals, (by series, model and year) and every thing you need for service etc for most tractors Donated by individual members. It’s an invaluable resource that has saved me so much time and effort! At the very least it points you in the right direction.
    I have been looking for a service and parts manual for my tundra for a while now! What I would give for that service managers electronic database! Maybe someone here has something. I have sometimes seen schematics provided in parts searches on some websites.
  24. Nov 10, 2018 at 3:43 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    I think they are pretty close. See post above. The service tech at your dealer will probably give you a copy. It’s what they use to ID your parts.
  25. Nov 10, 2018 at 3:52 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    I would run to the truck with a good light and looks inside the rear bumper corner. Use the spec sheet for the location. It’s a small box banter inside the corner extension facing the side( lane of traffic to the side) it’s about the size of a large cellphone and about 3/4 inches thick. Has 3 nuts attaching it. It might be black so hard to see.
    If you see that, Jump for joy! It’s probably the most expensive OEM part of the system. If not, pull out your wallet. LOL or go aftermarket. (You could also try your luck with an auto salvage place-never know)
    I love mine. Just an hour ago it picked up cross traffic from a good distance as I was backing out of a driveway I had never been at before.
  26. Nov 10, 2018 at 5:34 PM
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    I'd be willing to sell my mirrors. I had bsm on my limited but I've added aftermarket bumpers and completely done away with it. I have an entire hookup for it.
  27. Nov 10, 2018 at 5:45 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    Dang! Sir. That’s an awesome offer for this member looking to upgrade!
    Erichudgins[QUOTED] likes this.
  28. Nov 10, 2018 at 6:22 PM
    TundraLuv
    Kent
    IA
    Pm.sent
  29. Nov 10, 2018 at 7:18 PM
    Rakso
    Oskar
    TundraLuv[QUOTED][OP] likes this.
  30. Nov 11, 2018 at 7:30 AM
    TundraLuv
    Kent
    IA
    I made it out to my truck this morning. The verdict is that I don't have the hardware for BSM unless this last picture I took is it. I checked both sides and don't see anything resembling a box on each side of the bumper.
