Blew a head gasket!!
Discussion in 'General Tundra Discussion' started by TXTundraSC, Mar 24, 2021.
  1. Mar 24, 2021 at 6:26 PM
    TXTundraSC
    TXTundraSC [OP] New Member
    College Station, Tx
    2011 Tundra Platinum 4x4 s/c
    Magnuson S/C, trd exhaust, trd rear sway bar, trd front sway bar, toytec 2.5” level, debadged, toyo r/t 305/55r20
    Got gas this weekend and then check engine light came on with a misfire, cleared the code. Drove for another day and then check engine light flashing, 4LO flashing and trac light on...truck running really rough. Got it to the dealer and it’s a blown head gasket...we’ll see what insurance says tomorrow when the adjuster comes out. Tech says most likely happened under boost and caused early detonation
  2. Mar 24, 2021 at 6:47 PM
    Devildog183
    Devildog183 New Member
    Roger
    Kansas
    2019 Limited CM 4x4 2007 SR5 DC 4x4
    Man that sucks, sorry to hear that. What kind of engine management do you run?
  3. Mar 24, 2021 at 6:56 PM
    Vizsla
    Vizsla ☠️☠️☠️
    That does suck. Good job though, if you aren’t breaking stuff your limiting the fun factor. Might want to check the gas to be safe.
    TXTundraSC[OP] likes this.
  4. Mar 24, 2021 at 6:58 PM
    TXTundraSC
    College Station, Tx
    Here is a little proof
    Vizsla likes this.
  5. Mar 24, 2021 at 6:59 PM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    Why would insurance help with a head gasket issue?
  6. Mar 24, 2021 at 7:04 PM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
  7. Mar 24, 2021 at 7:05 PM
    Vizsla
    Vizsla ☠️☠️☠️
    So... What’s going on with the new build? More power!
  8. Mar 24, 2021 at 7:10 PM
    Vizsla
    Vizsla ☠️☠️☠️
    Maybe?
    *edit*
    Sorry, my bad, thought bad gas was obvious. Lol.
  9. Mar 24, 2021 at 7:34 PM
    TXTundraSC
    College Station, Tx
    With the supercharged application especially, early detonation (spark firing before cylinder is lifted)is caused by poor fuel quality and or water contaminated gas. This then will cause a head gasket to blow out.
    If everything goes well, supercharger will get serviced and coupler replaced. I will also be adding an Auburn LSD to the rear end while rebuilding the diff(original reason the truck was going into the shop)
  10. Mar 24, 2021 at 7:44 PM
    Vizsla
    Vizsla ☠️☠️☠️
    Sorry, the maybe was for the insurance questions. I could see the water from your pics.. Assumed others did also.
  11. Mar 24, 2021 at 9:04 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    Reg Cab Gang
    Rip headgasket
    Rip wallet
    :spending:
    Sumo91, TXTundraSC[OP] and Tundra2 like this.
  12. Mar 25, 2021 at 11:08 AM
    TXTundraSC
    College Station, Tx
    Got it covered!!!:yes:
  13. Mar 25, 2021 at 12:30 PM
    FirstGenVol
    East TN
    2002 AC
    By insurance? Again, I'm really curious why insurance would cover this. Please explain.
  14. Mar 25, 2021 at 12:34 PM
    AZBoatHauler
    AZBoatHauler SSEM#140/ASCM#3/2ndGenNaysayer/BAF140
    So.Arizona
    Through your policy or the gas station? What insurance carrier?
    FrenchToasty likes this.
  15. Mar 26, 2021 at 8:58 PM
    TXTundraSC
    College Station, Tx
    Have to have a good technician to explain why bad gas would cause a blown head gasket because of water contaminated fuel.
    The fuel sample proves the case as well. No pre-existing conditions, got gas then the next day the truck started to misfire because of coolant in the cylinder.
    I have been with Geico for 8 years and this is only my second claim, so that may have helped as well.
    Jack McCarthy and DZ_ like this.
  16. Mar 27, 2021 at 2:43 PM
    PaulB84
    PaulB84 On the spectrum
    2009 SR5 Crewmax
    I think you blew a few minds along with the gasket. Most folks have no idea this is the kind of thing that makes great insurance worth it vs minimal coverage with a crummy company.
    Glad it's on its way to whole again!
    FirstGenVol likes this.
