Blackstone Labs.. Their thoughts on the best oil for 5.7?
Discussion in '2.5 Gen Tundras (2014-2021)' started by BAZZMAZZA, Jun 5, 2020.
  1. Jun 5, 2020 at 6:24 PM
    BAZZMAZZA
    BAZZMAZZA [OP] New Member
    B-ROCK
    2017 TUNDRA Crewmax
    Teammates,
    I wonder if Blackstone labs has a data base that could shed light on the best performing oil for the 5.7L V8? I know many of us on this forum send those samples in for analysis regularly. I would think they would have valuable data on the best performing oil. Im not an oil nerd by any means FYI.. I would imagine they would have a major influence in the choices we make for our Tundras if they voiced an opinion. Thoughts?
    Mountun Goat likes this.
  2. Jun 5, 2020 at 6:29 PM
    Have you called Blackstone? They would have that data. As you mentioned several members here use Blackstone but not enough to get a good statistical answer here.
  3. Jun 5, 2020 at 7:06 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    lewi3069 likes this.
  4. Jun 7, 2020 at 4:00 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    It would be worth asking. They probably have to know the oil they are testing. For example, Molybdenum is higher in Toyota oil. Measured in PPM(parts per million) almost are major oils are between <1 - 90 with most in the <20 category. One of the highest, Amsoil at 60ppm. Toyota Synthetic molybdenum is 787ppm. So knowing the oil and plotting wear indicator statistics for the different oils, they may have data.
    Having said that, they may not share. Let just say they tell you Mobil 1 shows the least wear. You switch from Toyota oil to Mobil 1 and blow up and engine (all hypothetical). Not sure if you could blame them.
    But imagine the values if they could show that oil A statistically shows less wear based on wear indicators.
  5. Jun 7, 2020 at 6:04 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    If you establish rapport with one of their techs, they might have a professional opinion based on the testing they've done. On a strictly informal and verbal basis, they might share that opinion. But if they want to keep their job, they will not.
    It's highly unlikely you will get anything in writing. Simply telling you a recommendation is surely against Blackstone's company policy, because it will expose them to liabilities, from both competing oil companies and from vehicle owners. If an owner later has an engine problem, and wants to claim Blackstone's oil recommendation caused the problem, there will be no written record of any such recommendation, and they will likely disavow they ever made any specific recommendation.
    omgboost likes this.
  6. Jun 7, 2020 at 10:12 AM
    BAZZMAZZA
    B-ROCK
    2017 TUNDRA Crewmax
    All very good points thanks for the input. I would imagine I am not the first to think of this considering so many car / truck enthusiasts out there. I will call tomorrow and see if they have an opinion but certainly don't expect them to give me one..
  7. Jun 7, 2020 at 10:19 AM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    The first two samples are with Mobil 1 and the two newest are with Valvoline. I'll submit a sample with the Castrol I put in the engine during my previous oil change next week; it's been about 7,000 miles since my last oil change at this point.
    omgboost and JohnLakeman like this.
  8. Jun 7, 2020 at 10:31 AM
    1engineer
    1engineer New Member
    Appalachians
    2019 Tundra Limited TRD Off Road.
    Lol there is no "best" oil for our Tundras. Consider the guy in Phoenix, consider the guy on the North Slope in Alaska, consider the guy who drives 40K a year on interstate, consider the guy who drives all city miles, consider the guy who tows 8K daily, consider...
    I hope you understand there is no best oil for every application.
    With that said, Blackstone did publish an article that said there is no best brand, they all did a good job. Maybe it was an interview but I know it exists.
    SOB, jordoncloutier and chugs like this.
  9. Jun 7, 2020 at 11:26 AM
    computeruser6
    Dirk
    Escondido
  10. Jun 7, 2020 at 11:56 AM
    JohnLakeman
    Thanks for the data @computeruser6.
    I prefer and have used both Mobil1 and Valvoline motor oils in different applications. Currently, I use Mobil1 Extended Performance in the Tundra, and plan to change from 0W20 to 5W30 viscosity at the next change. In Texas heat, a little extra viscosity is not going to hurt anything imo. In your tests, the Mobil1 does seem to have the edge over the Valvoline in regard to remaining molyddenum ppm.
    nixon and Hoff like this.
  11. Jun 7, 2020 at 1:10 PM
    1engineer
    Appalachians
  12. Jun 7, 2020 at 1:10 PM
    1engineer
    Appalachians
    Thanks!
  13. Jun 13, 2020 at 5:16 PM
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    What's the cost to have a sample analyzed. Had a sample bottle but gave to a friend during his last oil change on a Porsche Boxster and he hasn't ordered another bottle yet to replace. Have two vehicles I would like to get started checking oil. Tundra not to worried but a 2000 Porsche that has a engine/oiling historic problem that I would like to catch before catastrophic failure
  14. Jun 13, 2020 at 5:22 PM
    omgboost
    East Coast
    $30 and TBN is extra $10
  15. Jun 14, 2020 at 9:21 AM
    brandostundra
    brandostundra New Member
  16. Jun 14, 2020 at 11:30 AM
    computeruser6
    Dirk
    Escondido
    I'm sending Blackstone the Castrol "Edge" 0-W20 oil sample today.
  17. Jun 14, 2020 at 11:35 AM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    What he said, too many variables.
  18. Jun 14, 2020 at 12:12 PM
    1engineer
    Appalachians
    Lol Cult of Amsoil!
    Again, I nor anyone else, as long as OEM specs are followed, has ever seen an engine oil fail due to brand of oil, as long as the oil is certified.
    Zebruaj, nixon, ColoradoTJ and 2 others like this.
  19. Jun 14, 2020 at 1:00 PM
    computeruser6
    Dirk
    Escondido
    Why?
  20. Jun 15, 2020 at 1:08 PM
    brandostundra
    Yes you should always follow OEM spec and make sure any oils you use has the certification emblem and rating that is required for your application.
    Yes the cheapest stuff on the shelf at walmart is certified and will work in your application , but you can do much better and your engine will love you for it.
    Why Amsoil (im my opinioon)
    Not all oils are created equal, oils are made of base stocks and additive packages. Different brands use different base stocks and different additives , some far superior than others.
    According to my Amsoil sales rep , When comparing synthetics, you can no longer trust the terms "full synthetic or 100% synthetic, some now refine petrolium group 1-3 base stocksinto synthetics and get away with labeling them as full symthetic ?, I believe this goes back to a lawsuit that Mobil 1 vs Castrol regarding base stock and specific wording or something .
    A true 100% synthetic will be PAO Synthetic group 4 (Polyalphaolefin). Any oil company using PAO will be proud to mention that they do, .
    Some poeple only use the brand that the automaker recommends , because they think it was specifically made for their vehicle . Automakers save money everywhere they can to make as much profit on the vehicle when it sells, every penny counts. It is a contract between oil companies and car makers, its a business decision , basically "If you use our oil in every car you build, every oil change you perform, we will give it to you at $... per qt".
    Their goal is to make your car last 36k miles thats it. If the automakers were to warranty your engine to 100k or more, believe me theyd be using and recommending different higher quality oils.
    Same with Mobil 1 , very good oil and comes as factory fill in many higher end vehicles and super cars, again a business decision (contract with oil company and automaker).
    I have been using synthetic since the early 1980's starting with Baker Precision, Redline , Mobil 1 and finally Amsoil in everything ive owned.
    I spend hours talking to my Amsoil rep about various tests and comparissions new products , news etc, spent hours reading watching and talking to people.
    These are obviously my opinions , Dont take my word for it , do your own research , read , watch videos, check out the test charts.
    Just dont go to your Walmart or local Quickie Lube for oil advise.
  21. Jun 15, 2020 at 1:15 PM
    ckkone
    ckkone New Member
    SLC, UT
    All that really matters is you change it at the right interval and use the right weight, what brand really does not matter. Supertech, Amazon Basic, Kirkland, Amsoil, Mobil 1, etc... don’t make a lick of difference.
    WILLINH, Zebruaj and 1engineer like this.
  22. Jun 15, 2020 at 1:22 PM
    brandostundra
    Yes the correct weight is important.
    but change interval depends upon the oil being used. Your supertech or Amazon oil might be good for 3000 - 5000 miles, but Amsoil and possibly others last 15000-25000 miles (with the correct hi milage filter , or just changing filter and topping off oil) .
    Some oils break down , some dont.
    I have never done this test , but would be curious to compare Amsoil used for 25000 miles vs to a basic motor oil brand new in the bottle
    Brand DOES make a difference
  23. Jun 15, 2020 at 1:24 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Oh look, more Amsoil copypasta
  24. Jun 15, 2020 at 1:34 PM
    ninjajay
    Spoolston, TX
    I’ve only done 3 Tundra samples with blackstone, two with M1, one with Pennzoil. All came back great. 7-9k intervals.
  25. Jun 15, 2020 at 1:36 PM
    brandostundra
    Love my Amsoil!
    my older 2001 Tundra has 274,000 on it and still running strong, clean and never had any issues. Amsoil in engine, trans, and rear end
    runs like it did when new, can still hook up a trailer and confidently tow 6000 lbs trailer almost anywhere
  26. Jun 15, 2020 at 1:48 PM
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    2020 Tundra Platinum
    The problem is Amsoil no longer shares how much PAO they use in their SDS and they only list the anti-oxidant
    Benzenamine, N-Phenyl-, reaction products with 2,4,4-Trimethylpentene. More troubling is that they used to list PAO on their SDS and they stopped a few years ago. Why? So you have to take their word for it that they use PAO and even if they do how much? They are one of the only oil companies that does not list PAO % on their SDS. Mobil happily reports how much PAO (1-DECENE, HOMOPOLYMER HYDROGENATED) is in their products. If you look at the % PAO in 0W-20 Mobil 1 EP it's 60-70% and it's a much better price point. I'm not saying Amsoil isn't good - we just have no idea what's really in it and as one of the only companies to "hide" this information I again ask why?
  27. Jun 15, 2020 at 1:54 PM
    omgboost
    East Coast
    Hyundai has 100k warranty. They recommend Quaker State oil. I rarely see the brand get thrown out there.
  28. Jun 15, 2020 at 1:57 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Plenty of people who use Mobil 1, Castrol, Valvoline, and many others can say the exact same thing. The dealership I bought my truck from does my oil changes. I don’t know or care what they put in it. I just drive the shit out of it. If anything happens, I have a lifetime power train warranty.
    PWMDMD likes this.
  29. Jun 15, 2020 at 1:59 PM
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    I've seen hundreds if not thousands of UOAs and the only thing that becomes clear is any mainstream oil that meets your vehicle's requirements from the manufacturer will do just fine. I have NEVER seen two oils from a mainstream brand that both meet the specs for a well-running engine over the same OCI give significantly different results....NEVER.
  30. Jun 15, 2020 at 2:01 PM
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    Because it doesn't really matter....
    1engineer likes this.
