Blackout Emblems 2018 tundra platinum
Discussion in '2.5 Gen Tundras (2014-2021)' started by DaRealMistress, Oct 5, 2018.
  1. Oct 9, 2018 at 7:37 PM
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    Awesome - I’ll have to try one. The adhesive on these emblems is nuts.
  2. Oct 9, 2018 at 7:39 PM
    Yotaman18
    Yotaman18 New Member
    Corey
    Houma, LA
    2018 Platinum 4x4 Bitching Blue
    Yeah I gave up on the fishing string.. ended up wrecking two credit cards to get them off lol15391391245567010043311167052582.jpg
    Skippy and jewsNbrews like this.
  3. Oct 9, 2018 at 7:41 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    So if painting interior finishes ? U should wet sand first?:bananadead:
  4. Oct 9, 2018 at 7:42 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Oh man it's that bad huh? Maybe I should hear them up first? This is good to know
  5. Oct 9, 2018 at 7:45 PM
    Yotaman18
    Corey
    Houma, LA
    Yeah.. the blow dryer is likely a good idea lol Took awhile to negotiate them off, and then even longer getting the glue off the back of the badges. Way more work than expected. Make sure you dedicate some time for this project.
    Pudge[QUOTED] likes this.
  6. Oct 9, 2018 at 7:53 PM
    Pudge
    CT
    I figured it would be a couple days from start to finish. What are you using for glue / tape to put it all back together and onto the truck?
  7. Oct 9, 2018 at 8:01 PM
    Yotaman18
    Corey
    Houma, LA
    I purchased some 3M tape to put it back on with, praying it is enough. Nothing like the tar from hell that was originally holding it on. It all snaps back together still pretty tight but I'll add some gorilla glue to be sure. Waking up at 5am to try and sticking it back together. Have to be at work for 7. If not it will be a couple weeks before I get another chance.
  8. Oct 10, 2018 at 3:56 AM
    Yotaman18
    Corey
    Houma, LA
    Sigh.. things are still a bit tacky this morning. Attempted to put everything together but also noticed a few spots I need to touchup. Guess It will be 2 weeks before they make it back on the truck. :(15391688791646433492339146771505.jpg
    But the color is pretty close.
    Pudge likes this.
  9. Oct 10, 2018 at 9:01 AM
    G2G
    G2G New Member
    Chicago
    2018 White Platinum Tundra
    How much shipped to 60060? Thanks Steve
  10. Oct 10, 2018 at 9:07 AM
    cpc0812
    cpc0812 New Member
    Cory
    2018 Cement 4 X 4 CM
    I put them on ebay and someone has already bid on them. Sorry.
    G2G[QUOTED] likes this.
  11. Oct 10, 2018 at 9:43 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    You only need this as they don't make blacked out Platinum plaques which you have to black out yourself, customize or leave off. Comes with tape:
    https://www.ebay.com/itm/FOR-2014-2...g2-9:sc:USPSFirstClass!60602!US!-1:rk:13:pf:0
    You could match it up with matte black tailgate TUNDRA inserts too.
    20lb fishing line worked great for me, then the wheel, and GooGone. I'd be worried wrecking my finish with a card. The line slides back and forth to cut between the glue, it doesn't contact the paint. I tried line from my kid's rod at first, too weak.
  12. Oct 10, 2018 at 9:48 AM
    G2G
    G2G New Member
    Chicago
    Yep just found these https://www.amazon.com/Eyecatcher-T..._rd_t=40701&psc=1&refRID=1T1MJXPPQ436WAAA48XT
    so i think I will pick them all up at once. Thanks
    JoshuaA[QUOTED] likes this.
  13. Oct 10, 2018 at 4:20 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I did the ones on my black Platinum, came out great.
  14. Oct 10, 2018 at 4:25 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Platinums dont have the 5.7 badge, they have a platinum badge in it's place.
  15. Oct 10, 2018 at 4:34 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Heat gun and 30lb test line. If having issues use line like a saw. Line will cut right threw it next time. Then put goo gone on cloth and hold over what was left. Makes it easy to remove and no wheel needed, just a little elbow grease. Then polish and buff before putting back on.
    WFD473 likes this.
  16. Oct 10, 2018 at 4:34 PM
    Baldmonkey22
    Baldmonkey22 New Member
    Quartz Hill, Ca
    i debadged on a hot day and the fishing line cut into my clear coat so i had to rebadge. 1st time in 20 years i've had an issue debadging,
    jewsNbrews likes this.
  17. Oct 10, 2018 at 4:36 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    The newer trucks I swear have the smallest amount of paint and clear on them. Some of the simplest things leave huge scratches. Or maybe I am just anal retentive
  18. Oct 10, 2018 at 4:41 PM
    Baldmonkey22
    Quartz Hill, Ca
    so am I, it was 2 small nicks but on MGM it shows up as light gray and i couldn't look past it.
  19. Oct 10, 2018 at 4:45 PM
    #49
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Yup...same color as me. See the simplest little things and can't look past it.
  20. Oct 11, 2018 at 10:36 AM
    #50
    G2G
    G2G New Member
    Chicago
    Did you color them urself? If so how did you do it? That looks great! I need some for my white Platinum.
  21. Oct 11, 2018 at 4:00 PM
    #51
    Omohundro
    Jody
    McMinnville TN
    Yeah I did them my self, took them apart like the ones above and painted them with SIM Trim black. They match the factory black emblems great.
  22. Oct 25, 2018 at 10:50 AM
    #52
    Yotaman18
    Corey
    Houma, LA
    @Pudge Still need another coat. But finally got back home to toy with them. line_1540489362011.jpg line_1540489343433.jpg
  23. Oct 25, 2018 at 11:05 AM
    #53
    Pudge
    CT
    Looks sick man. I need to do this asap!!! Thank you for the update
  24. Oct 25, 2018 at 11:12 AM
    #54
    Yotaman18
    Corey
    Houma, LA
    Get it done man! Lol Loving it but definitely find spray paint. Love the look but spray would have been a much cleaner finish and less of a PITA
  25. Oct 25, 2018 at 12:01 PM
    #55
    Omohundro
    Jody
    McMinnville TN
    Looks great
    Yotaman18[QUOTED] likes this.
  26. Oct 25, 2018 at 12:53 PM
    #56
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    Those look really good. Awesome job!
    Yotaman18 likes this.
  27. Oct 30, 2018 at 9:42 AM
    #57
    Yotaman18
    Corey
    Houma, LA
    Finally got them on the truck. Not perfect. But i love em.15409176300505836128688344010897.jpg 15409176836742563348091665022473.jpg
    Lux749, bmcdds, 4x4_Angel and 2 others like this.
  28. Oct 30, 2018 at 11:30 AM
    #58
    Omohundro
    Jody
    McMinnville TN
    Looks great
  29. Oct 30, 2018 at 12:54 PM
    #59
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Wow! That really turned out nice. Great job.
  30. Oct 30, 2018 at 1:23 PM
    #60
    Pudge
    CT
    Looks so good Corey. I have to do this now.
